#1 2026-02-17 21:03:53
einpoklum
Is there a Devuan derivative targeting old hardware/laptops?
I need to install a Linux distribution on an old laptop with a 2640M CPU and not that much memory (4GB or 8GB). I would like to make it a distribution that is geared towards older hardware, its default desktop environment takes up little memory, but is still reasonably polished. And - I would like it to be non-systemd, so probably Devuan-based. If it weren't for the system requirement, I'd probably try something like Lubuntu (anti-X is even lighter, but its user experience is not friendly enough for my taste).
Does such a distribution exist?
#2 2026-02-17 22:12:38
Re: Is there a Devuan derivative targeting old hardware/laptops?
Google tells me that cpu is in the i7 family. You should be able to run devuan on that with no problems. If it only has 4G ram, choose lxde, mate or xfce or any window manager. Just don't open too many tabs on your web browser.
I have devuan on a machine with 4G and Intel(R) Celeron(R) CPU  J1900  @ 1.99GHz. It's slow, but it works. I used that machine to install each devuan desktop environment in a qemu VM to compare their memory use. Here are the screenshots: https://git.devuan.org/fsmithred/screenshots
#3 2026-02-17 22:17:42
brocashelm
Refracta is pretty good and lightweight, but not so much that it sacrifices usability. Comes with Xfce and no metapackages, so you can tinker with it further if it's not to your liking. Comes with ps_mem.py, which accurately measures the memory consumption of processes (must run as a super user).
Browsers usually take up a chunk of RAM. Use something like Pale Moon or NetSurf for a lighter footprint. Sylpheed or Claws Mail for a graphical e-mail client.
#4 2026-02-17 22:18:15
einpoklum
I suppose I'll be able to run it, but how snappy do you expect it to be?
I'm not a big fan of XFCE and Mate; I like LXDE, but - haven't they gone over to Qt? i.e. isn't it LXQt now?
#5 2026-02-17 22:19:18
brocashelm
No, LXDE still exists in many distros (Debian included). It's just that they switched it over to GTK3, so it will consume a bit more of your system resources. Stick to the Daedalus release for now, which is also the last to support 32-bit CPUs.
#6 2026-02-17 22:22:20
brocashelm
In fact, if you want something even lighter, give Exe GNU/Linux a shot. That one is like Q4OS with using TDE (Trinity Desktop Environment, based on KDE 3.5), but without any Systemd. Uses Refracta's installer.
Also, see this article comparing the different DEs (hasn't been updated in years, but much of the information is still true to this day).
#7 2026-02-18 01:55:50
dzz
ExeGNU and Refracta have similar resource usage. Trinity Desktop is not officially supported in Debian/Devuan, an issue for many although it has run well on Devuan for 10 years. Preference for style is a major factor.
Best option of course is a base debootstrap install and build what you want from there without "recommends" (that's how ExeGNU images are built).
Numerous lightweight options to choose from! But those live images give at least a preview of what is possible and are installable.
lxqt: Although qt-based it doesn't have the overheads of full-on kde plasma. One of many lxqt reviews:
https://itsfoss.gitlab.io/blog/lxqt-100 … ktop-ever/
i7 with 8GB ram? Definitely on my wishlist!
re browsers: The more marginal ones seem more prone to "fingerprinting". Using librewolf here currently (identifies as firefox but maybe a false sense of security)..  just mind how many open tabs on a low-end machine.
#8 2026-02-18 09:55:58
Not only do I run Devuan/XFCE on my 'main' computer, (i3/8GB ram), but also on Dual Core with 4GB, it even runs quite happily on 2GB Dual Core Thin Clients that I have, I'm just a normal user, internet, music, videos, spreadsheet, etc. smile
#9 2026-02-19 11:10:13
Devarch
Any lightweight Debian distro, e.g. https://distrowatch.com/table.php?distribution=lilidog and migration https://www.devuan.org/os/documentation … libur.html
It is as easy as this.
Or generously shared config for WM from this forum https://dev1galaxy.org/viewtopic.php?id=5742
Or just https://antixlinux.com/ which can be aslo switched to use Devuan's package base.
Plenty of options.
#10 2026-02-20 16:48:27
einpoklum
> Any lightweight Debian distro, e.g. ... lilidog
This thread says lilidog has been sunset. Hasn't it?
#11 2026-02-20 18:33:53
ceeslans
Not quite. The lilidog forum is no longer existing, but development of lilidog (and the barebone 'beardog') is continuing.
Lately, new versions (based on debian13) were released: https://distrowatch.com/12724
#12 2026-02-20 20:58:31
einpoklum
Fair enough... but since it's been suggested to me to try Devuan vanilla with a more lightweight window manager, I'll first go with that and see if it sticks. Starting with LXQt (just because it was the default choice before LXDE). I should try that underlying-Debian-to-Devuan conversion procedure sometime.
#13 2026-02-20 22:17:54
pcalvert
Although it's not a Devuan derivative, my plan is to install Alpine Linux on old laptops. I was given a couple of old Chromebooks, and one of them only has 2 GB of RAM. It doesn't make much sense to me to install Devuan on it when I can use Alpine instead.
Another one is called Luxxle.
#14 2026-02-21 10:41:58
My Chromebook runs Devuan/XFCE no problem, it is a 2GB ram 16GB eMMC machine, which I mainly use for a quick booting internet connection when I just want to look something up, of course, I could have installed less on it, but it works perfectly, except for sound, with Devuan. wink
#15 2026-02-21 14:30:40
trinidad
Lilidog is still in active development. If you want a labwc Debian Wayland minimal try Waydog.
https://dbts-analytics.com/waydogrev1.html
TC
Often unawares.
#16 2026-02-22 08:15:41
@trinidad who would want a headache waiting to happen?
That's what wayland is...
#17 2026-02-22 08:54:18
waiting to happen?
Breaking news: It happened some time ago, and the majority of distributions and desktop environments are using it.
Personally I don't think wayland is ready to replace X, but many seem to like it and that's a perfectly valid choice.
As for the OP: Sandybridge with 8GB of RAM will run pretty much any current distro acceptably well. The biggest problem will be, as always, the demands of a modern standards-compliant web browser.
If it only has 4GB installed, look into upgrading it. Most machines of that generation can take at least 8GB, usually up to 16. AI insanity notwithstanding, used DDR3 DIMMs are dirt cheap.
#18 2026-02-22 10:12:57
Babarosa
I am running Devuan 5 i386 on an AsRock K7VT4A Pro Motherboard with an AMD Athlon XP 3000+ and 2 GB RAM :-)
The system runs perfectly well and stable, and the reaction time of applications is more than acceptable and useable.
The only weakness is, as steve_v already mentioned,
...the demands of a modern standards-compliant web browser...
Web browsing works, is slow and using more than two tabs is not a good idea.
To my mind, the OP shouldn't face any problems given the specs of his machine :-)
Ad aspera ad astra
#19 2026-02-24 08:17:55
@Babarosa I wonder if palemoon would work on that device. I am sure firefox would be too heavy though. And obviously use ublock origin legacy from their addons.
#20 2026-02-26 00:56:21
I have run Vuu-do on a machine from 2005 that has 1 gb of ram, and it runs fine. I run Devuan every day on a machine with a simple dual-core APU at 800 mhz with 4 gigs of ram and never have a problem.
But if you need translations you would need to look elsewhere as Vuu-do don't do that. Vanilla Devuan works great for that.
