Pages: 1
Hey guys!
I'm the main dev behind SpacedLinux.com
My goal is to make an EASY TO USE devuan rolling distro that just works out of the box on all hardware.
And so far I think we've mostly nailed it (other than a recent AMD xorg deprecation, which I'm still researching how to resolve best).
If you guys have a better devuan rolling desktop out there somewhere: Let me know.
We've had about 7,000 downloads since inception in July, and were at one point #28 on distrowatch, even beating FreeBSD.
I'm currently working on seamless samba/windows networking, and fixing the AMD/xorg deprecation, maybe by moving to xlibre. Still in the research stage on both projects.
Version 10.26 should work pretty well on all hardware without issues.
It works better on real hardware than in a VM, although the VM should work fine as well, it's really designed for direct hardware and display integration via Compiz/Mate.
Cheers guys, and thank you for my favorite base OS: Devuan Ceres
Hi. I'm a giant nerd.
OpenAirShips.com SpacedLinux.com VoxaAI.me SuperMox.me rhYciv.org rhYmusic.com
I posted some thoughts in this thread: https://dev1galaxy.org/viewtopic.php?pid=66038#p66038
But one thing I forgot to mention, been working with Devuan-Mate + Xlibre since last year, and only issues I had were that it didn't want to play nice with compositors on my old hardware, and secondly they've dropped some packages for older AMD hardware (mostly pre-2010 stuff).
i've been living on devuan stable for a while now but what is happening with amd in devuan ceres?
https://github.com/crhy/spaced/issues/298
I'm still investigating.
i see, just gonna throw a couple of thoughts, linux mint uses the lightdm slick greeter since the mint team considers the gtk greeter unstable and unsuited for production use, there have been a lot of changes in the kernel in regards to amd graphics since last year so it is completely possible that a config that worked in an older kernel will not work with the most recent kernel in ceres, what message does xorg put out when one of these installs switch to a different tty and try to run startx?
on a tangent, how are you doing sound? what gathers detractors from pipewire is the fact that for the 3 programs (pipewire, pipewire-pulse, wireplumber) to work correctly they need to be "user services", systemd does that via user units, runit can do user services, openrc also has user services (but i think only devuan ceres got a version of openrc that can do user services), i personally ended up writing my own implementation of user services that works completely independent of any init to have pipewire "just work" on my setup.
@crhylove I believe you mentioned Spaced Linux includes or make it easy to install the proprietary Nvidia drivers. Do you already have a deb packaged version of the 580.178.04 drivers that are necessary to solve the 90 CVEs found recently in older versions of the Nvidia drivers such as those available in the debian repos?
See: https://dev1galaxy.org/viewtopic.php?id=8244
“Either the users control the program – or the program controls the users” Richard Stallman
From the locked thread:
"..this is a desktop OS for normies. Not for us hardened sysadmins..."
Why are you working on and marketing a derivative to make it "easier" for Joe Average?
What's in it for you?
@blackhole: Just trying to make the world a better place. And Spaced Linux is only one part of it. Check out OpenAirShips.com if you are brave.
Oh, and by the way, I released 10.26.3 today and I think I fixed the amdgpu issue. And definitely fixed the Windows/Samba stack.
10.26.6 is out now. Lots of improvements.
10.26.7 is building. Found a few more upstream issues, patched them (some were already patched in Debian), should be the best release ever.
i'm still curious how do you go about user services or are the xdg-autostart provisions in MATE DE enough for the spaced UX?
Somehow you seem to have missed the brief that github is a Microsoft venture. Don't be there.
Yeah, I know. But all my stuff is on there. I'm making plans to make github obsolete. It's at the top of my list.
Curious about your choice to use Alacarte (the Gnome menu editor), instead of Mozo which is made for Mate?
Yeah, I'm not really happy with any of the menu editors to be honest. I should probably try Mozo. I'll do some work on that before the next release.
New Spaced Monitor looks to be a nice improvement from btop/nvtop.
Pages: 1
