As you might know already, two weeks ago Nvidia announced a long list of high-severity CVEs that affect all but their latest drivers.
See here: https://nvidia.custhelp.com/app/answers … /a_id/5861
The minimum driver version that has fixes for those CVEs is 580.178.04
Debian is stuck on 550.163.01 even for unstable, there is no sign of the 580 branch drivers (or any even newer branch), not even in experimental: https://tracker.debian.org/pkg/nvidia-graphics-drivers
To be fair Debian doesn't officially support the Nvidia drivers as they are in the non-free repo so if they want they can just ignore this (although it looks very bad having such important drivers with so many CVEs in an official repo).
Nvidia themselves provide an official repo with driver packages for Debian 13, but the oldest driver branch in this repo is 590 which only works for newer cards (GTX 16xx onwards): https://developer.download.nvidia.com/c … 13/x86_64/
Switching to this repo could be a good solution for anyone with newer cards (GTX 16xx onwards).
I have a GTX 1050 so I need the 580.xx driver branch.
Nvidia has the 580.178.04 driver (the version with all CVEs fixed) both in their Ubuntu 24.04 and in their Debian 12 repos:
https://developer.download.nvidia.com/c … 12/x86_64/
https://developer.download.nvidia.com/c … 04/x86_64/
I read that some people installed the 580.xx drivers from the Debian 12 repo on Debian 13 and apparently it worked for them.
OTOH Ubuntu 2404 seems to be more version-aligned with Debian 13 / Devuan 6 than Debian 12.
Do you think that on Devuan 6 it might be a better idea to try the 580.xx drivers for Ubuntu 2404 or the ones for Debian 12?
Or should I continue to wait and hope that the Debian Nvidia driver maintainers eventually catch up and make the patched 580.178.04 driver available in Debian 13 backports?
Is there any chance that this will happen within the next few weeks?
What are other Devuan 6 + Nvidia users here planning to do?
“Either the users control the program – or the program controls the users” Richard Stallman
After further investigation I found that apparently even the 580.xx drivers in the official Nvidia repo only include the open source kernel drivers and therefore are not suitable for cards older than the GTX 16xx.
The proprietary kernel modules have been removed. The open kernel modules are now the only kernel module flavor provided.
https://docs.nvidia.com/datacenter/tesl … dates.html
Therefore for cards older than the GTX 16xx series (that require the proprietary kernel modules) the only options are either use the generic unpackaged Linux driver from the Nvidia driver download page ( https://www.nvidia.com/en-us/drivers/ ) with all the mess that causes on the filesystem, or wait and hope that the Debian maintainers make the drivers available as deb package in backports.
Or does anyone here have a better idea?
90 vulnerabilities listed...
Unfortunately, the old advice still stands. As Debian "freeze" the stable release, the Nvidia proprietary driver will most likely remain at that version. So the usual course of action is to install from the Nvidia shellscript (and reinstall from that after every kernel update). As it's a proprietary driver, no backporting of any security fixes is possible.
I have always taken the view that Debian simply should not have packaged these from day one, as this is old ground we have been going over for the last 20+ years.
The Debian wiki article discourages Nvidia hardware and also highlights the "planned obsolescence" aspects - but this is also relevant to AMD and Intel, which it appears to endorse.
I have seen somebody claim that MX Linux supports older NVidia graphics. They are said to patch the drivers and adapt them to newer kernels.
I have no personal experience with MX.
I stay away from that special graphics company since I started with Linux more than 20 years ago.
Hi
I did a bit of reading as I have a 4k screen on my laptop with the same card, but no idea if this would work. I haven't got round to trying to set up the Nvidia card on it at all.
1. The Cuda drivers are proprietary not open source.
2. The Nvidia guide talks of creating a preferences.d file to ensure pinning is applied to ensure only the 580 version is used when later updates are run https://docs.nvidia.com/datacenter/tesl … cking.html
3. The log file here explains why the pinning method is advised by Nvidia https://forums.developer.nvidia.com/t/d … nts/353805
4. The NVDC section of the Debian wiki advises to use the pinning method with caveats. https://wiki.debian.org/NvidiaGraphicsD … 2_.26_D-13
This might or might not help. I am new to Devuan and not a developer, but sharing incase of use
Hi
Another thought following your point re the mess using the Nvidia run files causes. That is use of containerisation.
Reading this post, developers are using that concept by putting the driver in the opt folder https://forums.developer.nvidia.com/t/c … /124836/15
However they are having to use the the utility prefix, open gl prefix and 32 bit compatibility libraries to avoid messing up the usr bin folders and the usr libraries. The prefixes used and what they do is in the Nvidia installer code options section https://github.com/NVIDIA/nvidia-instal … on_table.h
We can see in this post that a user called wild tux https://forums.developer.nvidia.com/t/l … tall/46411 had to set x prefix back to usr.
These links help infer the risk of having X11 items sandboxed and hence why the defaults for these are not to sandbox to avoid a display server crash
This is far as I have got. I then started getting a bit lost. It would need someone with more experience to advise if this kind of approach has any legs
I'm not getting my hopes up. This shows the issue has been raised formerly on the Nvidia side for months https://github.com/NVIDIA/cuda-repo-man … er-sign-up
I have solved it by installing the 580.178.04 drivers from the official Nvidia repo for Debian 12 following these instructions from the Debian Wiki:
https://wiki.debian.org/NvidiaGraphicsD … dc-maxwell
The only other thing not mentioned in those instructions that I had to do is append nomodeset in /etc/default/grub to the GRUB_CMDLINE_LINUX line and then obviously run update-grub as root.
My concerns that the 580.xx drivers from the official Nvidia repo no longer included the proprietary kernel modules (as stated in the Nvidia docs I linked to in post #2) were unfounded, that statement must refer to the newer driver branches that only support cards from the GTX 16xx and newer, which don't require the proprietary kernel modules anyway.
Of course using drivers built for Debian 12 on Debian 13 / Devuan 6 is not the cleanest solution but everything seems to work fine so it's a usable solution.
It's still better than installing the generic Nvidia Linux drivers that don't come as package and therefore cause a mess of unmanaged files on the filesystem.
Still, it would be great if the Debian packagers responsible for packaging the Nvidia drivers would wake up from their slumber and make a proper Debian 13 package of the 580.178.04 driver, having outdated and highly vulnerable packages (90 high-risk CVEs!!) in the Debian repos simply looks very bad for Debian.
I have been using mostly Nvidia for the past 18 years as both their hardware and their drivers (and software ecosystem around it) are superior to anything GPU related from AMD and Intel.
Of course if you only use generic desktop apps (browsing, office apps) that doesn't matter much, but if you need good video decoding/encoding, cuda and other such things then Nvidia was and still is the best choice.
TBH I never had issues with Nvidia drivers with other (not Debian based) Linux distros in the past, the packagers of others distros (at least of those I used) were more proactive and made sure that they had up-to-date and fully usable Nvidia drivers available in their repos.
Hi, brilliant and thank you for sharing
Question , the part around "Since 2026-02-01, Debian-13 rejects signatures using SHA1 used in the NV D-12 repo. Additionally, D-13 migrated signature verification tool from gpgv to sqv that does not accept additional options from apt sources. To workaround it all, you need to......"
Does that compromise security in any material way for a home laptop user, and did you have to follow this part of the guide?
Appreciate your advice. Cheers
in my view to company is over-evaluated;
i like ATI and consider them the superior designs (but am not real knowledgeeable in the technical side of things), but have to agree that nvidia has some excellent "benchmarks" and they seem to command the market for some time now; lets see how long that will last.
for linux users, overall, i still prefer the AMD cards, hands down.
(might be biased since i tend to buy "small").
unwarranted comment.
I followed every step of the guide, with guides like this skipping steps usually leads to failure.
I don't see how the first steps would compromise security in a meaningful way, after all that's what Debian 12 allowed, and you are only allowing the SHA1 signature for the Nvidia key, not in general, at least that's how I understand it, if anybody has better insight please let us know.
But if it makes you uncomfortable then just disable the Nvidia repo again right after installing the drivers from there.
One thing I noticed that I still had to do manually after installing the 580.178.04 drivers from the official Nvidia repo for Debian 12 is the following symlink otherwise the GLX module would not load:
# ls -la /usr/lib/xorg/modules/extensions/
total 13452
drwxr-xr-x 2 root root 4096 Oct 17 20:26 .
drwxr-xr-x 6 root root 4096 Sep 20 18:33 ..
-rw-r--r-- 1 root root 302312 Sep 13 18:44 libglx.so
lrwxrwxrwx 1 root root 33 Oct 17 19:41 libglxserver_nvidia.so -> libglxserver_nvidia.so.580.178.04
-rw-r--r-- 1 root root 13462128 Jul 7 14:06 libglxserver_nvidia.so.580.178.04I only noticed this because I looked at the /var/log/Xorg.0.log which had this error:
Failed to load module "glxserver_nvidia" (module does not exist, 0)I guess that's a bug of the Nvidia package for Debian 12 as surely it should have created that symlink during installation of the package.
Thank you! I'll read about it and try it out. Thank you for sharing your knowledge on this
Dynamic linking includes some version handling and it is common practice that after placing a lib in the lib collection(s), one runs ldconfig for reasons that are somewhat explained in
man ldconfigldconfig will then establish the "soname" link that the dynamic linker (ld.so) requires. There is also the documentation
man ld.sothat really represents 101 knowledge for us who want to understand.
I'm familiar with ldconfig, but this is a private library used only by the nvidia xorg driver, not a shared library in the library path.
In any case shouldn't apt/dpkg run ldconfig automatically after installing a package that requires this?
I have never run ldconfig manually after installing packages on any Linux system.
I checked with dpkg -L and the symlink is part of the package, I have no idea why it wasn't created automatically during package installation:
$ dpkg -L xserver-xorg-video-nvidia|sort
/etc/nvidia/current/nvidia-drm-outputclass.conf
/usr
/usr/lib
/usr/lib/xorg
/usr/lib/xorg/modules/drivers
/usr/lib/xorg/modules/drivers/nvidia_drv.so
/usr/lib/xorg/modules/extensions/libglxserver_nvidia.so
/usr/lib/xorg/modules/extensions/libglxserver_nvidia.so.580.178.04
/usr/share
/usr/share/X11
/usr/share/X11/xorg.conf.d
/usr/share/X11/xorg.conf.d/nvidia-drm-outputclass.conf
/usr/share/doc
/usr/share/doc/xserver-xorg-video-nvidia
/usr/share/doc/xserver-xorg-video-nvidia/changelog.Debian.gz
/usr/share/doc/xserver-xorg-video-nvidia/changelog.gz
/usr/share/doc/xserver-xorg-video-nvidia/copyrightLast edited by tux_99 (2026-10-17 23:40:32)
Found another thing that needs to be done post-installation of the 580.178.04 drivers from the official Nvidia repo.
The 580.178.04 drivers put a file called nvidia.conf.dpkg-new in /etc/modprobe.d/.
This file blacklists the FOSS nouveau drivers, but it needs to be renamed to nvidia.conf to be activated.
After renaming it update-initramfs -u needs to be run as root to update the initrd.img.
Can anyone explain to me why the Debian Nvidia package maintainers are still working on packaging the 555.58.02 drivers, which have been end-of-life and out of support since June 2025 and which are affected by the 90 high-severity CVEs?
I'm referring to the following update:
"[2026-10-21] Accepted nvidia-graphics-drivers 555.58.02-4 (source) into experimental (Andreas Beckmann)"
on this page:
This makes zero sense to me, I would have expected them to either abandon packaging Nvidia drivers completely or focus on the latest release of the 580 LTS branch were the 90 high-severity CVEs have been fixed.
I'm only asking out of curiosity since I'm now using the drivers from the official Nvdia repo anyway, as mentioned in the previous posts.
Also this thread is for devuan 6.0 , I have followed the advice herein and in https://wiki.debian.org/NvidiaGraphicsD … dc-maxwell .
It worked for daedalus (5.x)
I am now with nvidia 580.196.07-1.
I failed to install xserver-xorg-video-nvidia for unknown reason, but once I installed the package, the missing link mentioned in #13 was also showing up and the xserver started as used to be.
A reason more not to upgrade to excalibur in the moment.
Thanks for this helpful thread.
broken by design :
