Hello ,
i have tried to install virtualbox-7.2 lately and initially run into some issues;
since friendly AI was eager to help out, did let him go easily on this, or rather took him to seriously ~
well , in short, i messed up the system.
since the virtualbox-extensions would not install, and if yes, give error, asked for advice, that coame very forthcoming;
probably the entry
sudo chown -R root:wheel /usrkilled it, since then have lots of issues on this partition, like
Error: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ExecFaild: Failed to execute program.org.freedesktop.PackageKit: [b]Permission Denied[/b]and lots of permission denied error;
also, the start-menu has shrunken, and there is no longer option to shutdown or restart , just "leave", eg. "lock" "log-out" and "switch-user".
Hopefully someone know of a good method to set the permission back straight, so can continue use the OS properly;
Thanks.
Maybe
sudo chown -R root:root /usrThat should fix most if not all of it. AFAIK there's no wheel group in debian-based systems. For future reference, changing ownership on system files should be done carefully ans sparingly. Changing ownership of everything in /usr recursively is extremely bad advice. You relied on a friend who routinely lies, cheats and steals.
You better should have asked for support here in the forum.
when the permissions issue is solved, open up a new thread with whats up about VBox 7.2.
That'll probably fix a lot, but not everything.
On my daedalus system, under /usr: (find ! -group root -ls | grep -v ./local/)
407952 16 -rwxr-sr-x 1 root utmp 14416 Feb 26 2023 ./lib/x86_64-linux-gnu/utempter/utempter
523692 52 -rwsr-xr-- 1 root messagebus 51272 Sep 24 2023 ./lib/dbus-1.0/dbus-daemon-launch-helper
690224 4 drwxrwsr-t 2 root lpadmin 4096 Dec 27 2015 ./share/ppd/custom
393038 4 drwxrwsr-x 12 root staff 4096 Oct 22 2023 ./local
436499 636 -rws--x--- 1 root operator 649688 May 25 2022 ./bin/cdrdao
411257 16 -rwxr-sr-x 3 root mail 14608 Sep 3 2021 ./bin/mail-touchlock
398561 32 -rwxr-sr-x 1 root shadow 31184 Dec 14 2025 ./bin/expiry
411257 16 -rwxr-sr-x 3 root mail 14608 Sep 3 2021 ./bin/mail-lock
396906 24 -rwxr-sr-x 1 root mail 23040 Feb 4 2021 ./bin/dotlockfile
401820 100 -rwsr-sr-x 1 root mail 101664 Mar 1 2022 ./bin/procmail
399266 44 -rwxr-sr-x 1 root crontab 43648 Mar 2 2023 ./bin/crontab
400977 60 -rwsr-sr-x 1 daemon daemon 59768 Oct 15 2022 ./bin/at
397902 80 -rwxr-sr-x 1 root shadow 80376 Dec 14 2025 ./bin/chage
402924 120 -rwxr-x--- 1 root operator 121840 Aug 6 2019 ./bin/growisofs
410565 456 -rws--x--- 1 root operator 463776 Jun 24 2022 ./bin/wodim
401442 20 -rwxr-sr-x 1 root mail 18768 Mar 1 2022 ./bin/lockfile
400077 476 -rwxr-sr-x 1 root _ssh 485760 Apr 4 2026 ./bin/ssh-agent
411257 16 -rwxr-sr-x 3 root mail 14608 Sep 3 2021 ./bin/mail-unlockObviously, the list will vary depending on what's installed. Stuff in /usr/src seems to be owned by $USER:$USER, and stuff in /usr/local is root:staff
And if you've got a usr-merged system (excalibur), there's probably going to be more...
[edit]
here's another list from an excalibur system, not a lot installed there
/usr$ find ! -group root -ls | grep -v ./local/
66326757 44 -rwxr-sr-x 1 root shadow 43256 Jun 29 2025 ./sbin/unix_chkpwd
66331837 24 -r-xr-sr-x 1 root postdrop 22840 Aug 10 12:35 ./sbin/postqueue
66331826 24 -r-xr-sr-x 1 root postdrop 22888 Aug 10 12:35 ./sbin/postdrop
66337980 60 -rwsr-sr-x 1 daemon daemon 59768 May 4 2025 ./bin/at
66324522 32 -rwxr-sr-x 1 root shadow 31256 Apr 19 2025 ./bin/expiry
66332196 412 -rwxr-sr-x 1 root _ssh 420224 May 6 08:33 ./bin/ssh-agent
66322953 112 -rwxr-sr-x 1 root shadow 113848 Apr 19 2025 ./bin/chage
66322893 52 -rwxr-sr-x 1 root crontab 51936 Jun 13 2025 ./bin/crontab
66322658 24 -rwxr-sr-x 1 root mail 23104 Dec 31 2024 ./bin/dotlockfileOffline
Mine:
/usr> find ! -group root -ls
1000852 16 -rwxr-sr-x 1 root utmp 14416 Nov 12 2024 ./lib/x86_64-linux-gnu/utempter/utempter
980836 52 -rwsr-xr-- 1 root messagebus 51272 Mar 10 2025 ./lib/dbus-1.0/dbus-daemon-launch-helper
4612 4 drwxr-xr-x 4 mercury mercury 4096 Aug 10 02:00 ./share/runit/sv.now/ntpsec
4620 4 drwxr-xr-x 2 mercury mercury 4096 Aug 10 02:00 ./share/runit/sv.now/ntpsec/.meta
...... a bunch of stuff in ./share/runit/ ..... not sure that's actually correct but it works so w/e.....
935307 420 -rwsr-xr-- 1 root dip 428424 Feb 17 2025 ./sbin/pppd
923748 44 -rwxr-sr-x 1 root shadow 43256 Jun 29 2025 ./sbin/unix_chkpwd
924273 32 -rwxr-sr-x 1 root shadow 31256 Apr 19 2025 ./bin/expiry
924270 112 -rwxr-sr-x 1 root shadow 113848 Apr 19 2025 ./bin/chage
926142 52 -rwxr-sr-x 1 root crontab 51936 Jun 13 2025 ./bin/crontabThis is a pretty minimal 6.1 excalibur.
It might well be easier to backup all relevant data and to re-install the system. I assume no Timeshift snapshots are available?
The bad news is you broke it - the good news is you get to keep all the pieces...
Lesson learnt on "AI"?
ERROR: ld.so: object 'libgtk3-nocsd.so.0' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.but now sudo seem no longer operational
sudo apt update
sudo: /usr/bin/sudo must be owned by uid 0 and have the setuid bit setthe AI friend can bhe helplful ~ normally consult only on "technical" issues, everything else is out of range, of course (well, he's is listening, and not amuesed, ![]()
edti: have recoverred from "sudo chwon -R root:root /usr" with the
chown root:root /usr/bin/sudo && chmod 4755 /usr/bin/sudo
however the issue still stands; am wondering if such a one-liner can have such destrcutive effect; but for now would have to answer affirmative; he has played me, again.
