#1 2026-09-21 20:36:48
IdeaFix
chimaera is going to archive?
I can make apt-get update but not apt-get upgrade
http://deb.debian.org/debian-security/pool/updates/main/a/apr-util/libaprutil1_1.6.1-5+deb11u2_amd64.deb  404  Not Found [IP: 146.75.118.132 80]
http://deb.debian.org/debian-security/pool/updates/main/libd/libdbi-perl/libdbi-perl_1.643-3+deb11u2_amd64.deb  404  Not Found [IP: 146.75.118.132 80]
http://deb.debian.org/debian-security/pool/updates/main/l/linux-signed-amd64/linux-image-amd64_5.10.262-1_amd64.deb  404  Not Found [IP: 146.75.118.132 80]
http://deb.debian.org/debian-security/pool/updates/main/p/python-httplib2/python3-httplib2_0.18.1-3+deb11u1_all.deb  404  Not Found [IP: 146.75.118.132 80]
http://deb.debian.org/debian-security/pool/updates/main/u/unzip/unzip_6.0-26+deb11u2_amd64.deb  404  Not Found [IP: 146.75.118.132 80]
All this files are in  Debian 11 (Bullseye) archive.
#2 2026-09-22 01:25:31
pcalvert
Re: chimaera is going to archive?
If you haven't already, try again. This is most likely a temporary issue caused by mirrors not being in sync.
Another one is called Luxxle.
#3 2026-09-22 01:57:05
turbo
same here just different files. It is going on since last week already.
Even changed the sources from standard devuan to my closest mirror.
Err:1 http://mirror.dogged.ca/devuan/merged chimaera-security/main amd64 libaprutil1 amd64 1.6.1-5+deb11u2
  404  Not Found [IP: 151.101.66.132 80]
Err:2 http://mirror.dogged.ca/devuan/merged chimaera-security/main amd64 mariadb-common all 1:10.5.29-0+deb11u1
Err:3 http://mirror.dogged.ca/devuan/merged chimaera-security/main amd64 libmariadb3 amd64 1:10.5.29-0+deb11u1
E: Failed to fetch http://deb.debian.org/debian-security/pool/updates/main/a/apr-util/libaprutil1_1.6.1-5+deb11u2_amd64.deb  404  Not Found [IP: 151.101.66.132 80]
E: Failed to fetch http://deb.debian.org/debian-security/pool/updates/main/m/mariadb-10.5/mariadb-common_10.5.29-0+deb11u1_all.deb  404  Not Found [IP: 151.101.66.132 80]
E: Failed to fetch http://deb.debian.org/debian-security/pool/updates/main/m/mariadb-10.5/libmariadb3_10.5.29-0+deb11u1_amd64.deb  404  Not Found [IP: 151.101.66.132 80]
Any suggestions or just "sit it out" and wait?
#4 2026-09-22 07:49:24
IdeaFix
No changes. I think, it is not a "mirrors not being in sync" problem. All debian packages are in archive repository but devuan source is trying to merge them from deb.debian.org.
#5 2026-09-22 07:52:54
IdeaFix
https://dev1galaxy.org/viewtopic.php?id=7317 - Last time, it took some time to acknowledge the problem.
#6 2026-09-22 16:17:31
My first step would be to point a web browser at http://deb.debian.org/debian-security/pool/updates/main and look around. It may just be some paths have changed.
And at the actual paths you have in /etc/apt/sources.list etc.
#7 2026-09-22 17:39:13
IdeaFix
Debian repo is in archive now. Devuan merged repo points not to archive but to main updates pool - http://deb.debian.org/debian-security/pool/updates/main
BUG is on the devuan side. It’s really sad that the developers can’t even properly move a release to the archive.
I’m not demanding anything, and I realize that no one owes me anything, but I’ve been pointing out the problem and its causes for some time now. It would be great if someone responded.
#8 2026-09-22 17:45:00
This is a user support forum. Have you filed an official bug report where a dev will actually see it??
You can start here:
https://bugs.devuan.org/db/ix/full.html
#9 2026-09-22 22:58:13
Yes there is some inconsistency there which might be due to those particular package version are available neither in deb.debian.org nor in archive.debian.org. They apparently where available in deb.debian.org but then have got removed from there and, contrary to expectation, not been placed in archive.debian.org. (Maybe I'm looking in the wrong places ?)
It does look like Devuan's amprolla will need some logic to handle that. Perhaps you would want to assist with that... (how to merge debian packages that get dropped from deb.debian.org without turning up in archive.debian.org). Or you could perhaps get in touch with the debian developers on that issue. Afaict it would affect Debian 11 Bullseye in a similar way.
#10 2026-09-23 09:02:30
IdeaFix
There is no "security" in debian archive for Bullseye. Security becomes a part of updates.
https://gist.github.com/ishad0w/7665cde … 13802e61e4
https://lists.debian.org/debian-user/20 … 00415.html
> Did this mean that everything that was in
> bullseye-security was rolled into the main
> archive
Yes, pretty much
That might be the reason.
#11 2026-09-23 09:32:44
Did you find the package files? Which repository are they in?
The transfer into archive does seem to be a gradual thing rather than instantaneous, so if you hold your breath for a week or so, it might have sorted itself.
#12 2026-09-24 17:55:56
IdeaFix
https://lists.debian.org/debian-mirrors … m%2F#00001 - last two posts
I understand that it is very difficult for devuan team to merge this repo https://snapshot.debian.org/archive/deb … 3T220410Z/
#13 2026-09-24 21:25:36
As you knw, chimaera is "end of life" and there are a couple of newer releases now in play: daedalus, excalibur. How about upgrading?
And, if that snapshot has those debs, it'd be easy for you to add that to your sources list. Would be a way to fix the situation for yourself; your personal merge. if you like.
#14 2026-09-25 07:46:27
IdeaFix
I need Tomcat 9 and Java 8. Tomcat 9 is available in the standard repositories, while I get Java 8 from Temurin. I also have ELTS from Freexian.
Upgrading to newer distribution versions would deprive me of the distribution's benefits if I had to install Tomcat 9 from a tarball.
I understand that Chimaera is currently EOL, but that doesn't mean it should be moved to the archive with errors.
#15 2026-09-25 08:22:16
I think almost everyone agrees with you, but it looks like it has happened, so now we (you) need to go on from there ... to stay you need to find appropriate debian repository snapshots that include the needed package versions, and then add those to your sources.list. And you might then also want to have pinning set up to restrict those sources to the particular packages. Alternatively you just download the deb files...
E.g. https://snapshot.debian.org/archive/deb … u1_all.deb is one of them.
EDIT EDIT: I couldn't convince apt-get to use a sources.list line, so I have to stay with advicing you to download the deb file(s).
#16 2026-09-26 09:34:37
IdeaFix
Recalling the experience with moving Chimaera backports to the archive, I think we need to wait for a decision from the Debian side and then spend some time persuading the Devuan team to fix their "unique" repositories smile
Right now, the Devuan package list is simply unreliable. Yes, one could blame Debian, but that doesn't solve the problem. "We don't guarantee anything to our users" and "We don't care about our users" are not the same thing.
Unfortunately, simply adding a snapshot isn't the solution. Before the move to the archive, PHP packages and several others were updated; these are rebuilt on the Devuan side. Just as with Tomcat, once the organizational issues are resolved, I might have to persuade the maintainer (via a bug report) to rebuild the package.
I have working deb11 server:
root@elar:~# apt update
Сущ:1 http://archive.debian.org/debian bullseye InRelease
Сущ:2 http://archive.debian.org/debian bullseye-updates InRelease
Сущ:3 http://archive.debian.org/debian bullseye-backports InRelease
Сущ:4 https://snapshot.debian.org/archive/debian-security/20260903T220410Z bullseye-security InRelease
Пол:5 https://packages.adoptium.net/artifactory/deb bullseye InRelease [7507 B]
Сущ:6 https://security.freexian.com/extended-lts bullseye InRelease
Сущ:7 https://repo.zabbix.com/zabbix-tools/debian-ubuntu bullseye InRelease
Сущ:8 https://repo.zabbix.com/zabbix/7.0/debian bullseye InRelease
Получено 7507 B за 2с (3918 B/s)
Чтение списков пакетов… Готово
Построение дерева зависимостей… Готово
Чтение информации о состоянии… Готово
Все пакеты имеют последние версии.
root@elar:~# uname -a
Linux elar 5.10.0-46-amd64 #1 SMP Debian 5.10.262-1 (2026-07-31) x86_64 GNU/Linux
root@elar:~# cat /etc/debian_version
11.11
root@elar:~#
However, neither the developers nor the user community have a solution for Devuan yet.
But you are right: one can manually build a repository from snapshots and rebuild specific packages. After all, that is precisely why we value the distribution.
#17 2026-09-28 11:43:03
IdeaFix
debmirror --nosource \
          --host=snapshot.debian.org \
          --method=https \
          --root=archive/debian-security/20260903T220410Z \
          --dist=bullseye-security \
          --section=main,contrib,non-free \
          --arch=amd64 \
          --ignore-release-gpg \
          --progress \
          /opt/security/
I made a local mirror for x64 in /opt/security, next step I need to merge devuan packages and make a local repository
#18 2026-09-29 20:21:41
I seem to have the same problem with the headless [Chimaera] VM I run exclusively for [pihole]+[unbound], which I won't upgrade to [Daedalus]. Also for reasons, main one being that it works perfectly well.
An example, to be clear in case it is something else:
[unzip_6.0-26+deb11u2_amd64.deb] is not in http://deb.debian.org/debian-security/p … in/u/unzip.
Q: If I download the 13 packages, install them manually and (if*) this issue gets fixed, will the eventual upgrades (if any) be installed as usual? ie: no downloading the packages manually.
*I checked the link IdeaFix posted but those last two are it, from 07/09 and 08/09. ie: no activity from maintainers/packagers since then.
#19 2026-09-30 11:32:24
I wrote:
... seem to have the same problem ...
Looking for the [*.deb] files I am needing I found two possible sources:
https://miroir.blueline.mg/debian-security/dists/
https://debian.sipwise.com/debian-security/dists/
Are these legitimate Debian mirrors?
#20 2026-10-05 10:28:36
IdeaFix
https://archive.debian.org/debian-secur … -security/
bullseye-security is in archive now... now we need chimaera-security here https://archive.devuan.org/merged/dists/
#21 2026-10-05 11:12:48
IdeaFix wrote:
... bullseye-security is in archive now...
Thanks for the heads up.
#22 2026-10-12 18:04:06
IdeaFix wrote:
... now we need chimaera-security here ...
Done. 8^)
