#1 2026-09-06 18:23:52
bdow
What DE do you prefer to use on Devuan?
I'm running freia, migrated from forky quite recently, the random crashes i have no idea what they even are happening somewhat often, which was also the case on forky. Would you recommend any DE else? If so, please tell me about it!
Have a good one, thanks in advance. X3
#2 2026-09-06 21:48:02
Micronaut
Re: What DE do you prefer to use on Devuan?
Using an experimental / development platform does have its hazards. I don't think the DE will make much difference. But I have tended to prefer Cinnamon. It's closer than XFCE is to the Windows desktop nearly everyone is used to, and lighter weight than overly fancy things like KDE.
#3 2026-09-06 23:26:57
Random crashes are unusual and probably pointing to a hardware problem.
That was the case on my first computer, which had a defective cache-RAM-module. At the time, it was sitting in a dedicated slot for a tiny amount of faster RAM. Crashes were completely unpredicteable - time span between 15 minutes and a few day.
Since then, I tend to "reconnect" (pull out and press in again) RAM modules, when strange things happens.
DE:
Still on LXDE - just works for me.
#4 2026-09-07 12:32:53
Nowadays, happy with XFCE.
(Used to regularly use Fluxbox beforehand).
#5 2026-09-07 12:57:30
Andre4freedom
I'm very happy with Cinnamon, but I like XFCE too.
#6 2026-09-07 15:31:11
Calamity
I'm on XFCE currently as well, I also like LXQt and IceWM.
Re-examine all that you have been told. Dismiss that which insults your soul.  - Walt Whitman
Dump shampoo and hair dye
Global Skywatch・Subliminal Manipulation
#7 2026-09-07 18:25:31
skidicarus
XFCE on my laptop and KDE on my desktop. Haven't had any issues with either.
#8 2026-09-07 18:51:22
I started off with Mate desktop on ASCII and switched to Cinnamon on Beowulf which I am still using.
#9 2026-09-08 08:25:45
blackhole
Which desktop were you using to start with?
You don't seem to be requesting assistance in diagnosing the crashes, so I assume that you have that in hand or are willing to live with it - or you presume that this desktop is the root cause?
In case you do want to diagnose the problem, we would need more details of the crashes, when they occur, what's running, etc? Also what crashes? Is there a kernel panic or does X just segfault for example?
Is your desktop running under X or a wayland compositor? In either case, hardware acceleration can be a factor and thus GPU drivers. You would need to provide a lot more in the way of details...
Failing all that, it could be a hardware issue, as suggested above.
#10 2026-09-08 13:55:31
yohno
I am with Xfce4 with Openbox now on Freia. I have been with some difficulties from the net install iso's of Freia for Lxqt and Xfce4 since last week so I decided  to migrate from one of debian stable xfce4 iso's today. Now I am happy now.
Two or three weeks ago, I could install lxqt from the previous one but I have been keep failing to have the GOOD initial environment from both of net install iso's since last week. I started my linux journey from ascii with mostly openbox. No more i3!
Please provide the clear explanation of your problem and/pr issue so that some knowledgeable SMEs could provide you some better advice .....
Yoshi
#11 2026-09-11 10:32:28
PedroReina
I settled on KDE many years ago. Although we as power users can use any DE (or just plain CLI), I have to facilitate things for the normal users I share computers with, and I find it easier to do with KDE. I remember using KDE kiosk, for example.
#12 2026-09-11 16:22:56
Valera
My main DE is Enlightenment E27, then SonicDE, LXQT and XFCE. I would recommend SonicDE.
#13 2026-09-11 20:10:13
sgage
Been on MATE since Jessie. I tried to like XFCE, but something about it puts me off. Same thing with KDE - I keep trying but it doesn't quite click. This is not some moral judgement, nor a judgement on technical merit. I think it's more simply my particular aesthetic sense, the combination of simplicity yet integration that hits some sort of sweet spot for me.
#14 2026-09-11 21:38:40
Mercury
XFCE works well enough for me.
Many years ago I tried GNOME and found it so unfriendly and unintuitive that it nearly put me off Linux entirely. It was downright odd in how it appeared simple but nothing about it jelled with me, like a UI "uncanny valley".
I moved to KDE for a while and liked it well enough. It wasn't quite as simple but it knew what it wanted to be and did it well. Pretty to look at. I gave it up simply because I wanted something less resource-hungry.
XFCE isn't perfect but I found my groove with it and have been using it for a decade now. I stopped chasing perfection in favor of consistency.
#15 2026-09-11 22:05:12
sgage
Never heard Gnome described as a UI 'uncanny valley' experience - I completely agree! That is my reaction as well.
'I stopped chasing perfection in favor of consistency.'
My feeling exactly...
#16 2026-09-15 00:32:54
cmaurand
I've been using MATE since my days on Ubuntu more than a decade ago. Most of my machines are still running MATE. I recently installed Cinnamon in a virtual machine and I rather like it. I haven't done much, but it's clean and seems to be well integrated and unlike lxqt runs on xorg and not wayland. Wayland and KVM don't mix very well.
#17 2026-09-15 01:48:40
Openbox. I'm one of the last few faithful of the old #! crew, Miyolinux built an amazing version of Devuan using Openbox back in the day and it just knocked my socks off, I had to make my own spin after that. Been using it ever since almost 10 years now and it's still solid and stable and fast, a real credit to the work of Devuan to preserve these legacy systems.
#18 2026-09-15 21:28:33
beate
My prefered DE?
Windowmaker. Plus Xeyes plus Xteddy ;-) No file manager.
And many terminal windows. And web browser windows.
On newer installations i am even going back to xterm as the terminal emulator (with modern fonts).
One of my machines is running XFCE with a Macos Like look.
One installation even has a Unity inspired look. But that's not for me...
#19 2026-10-05 08:28:16
KindlyDoRight
I strongly prefer KDE on X11, with 10 virtual desktops, across 3 real monitors [4K 43" center primary and two flanking 2K 32"].
  (On X11, because every application, terminal, folder window is restored to their proper virtual desktop position. And because cut & paste works between every app and virtual machine [no-friction].)
My workflow requires a robust "Round-robin" multitasking environment.
For a simple example: I maintain 31 different browser instances (with more than 10 windows and 1,000 tabs per instance). Each browser instance is topic specific (Publishing, DevOps, Typography, Programming, Home Maintenance, Adhoc Research, et cetera).  And I maintain many specific-use Virtual Machines.
I don't use AI, BTW.  I myself do the all the thinking, exploring, trying, evaluating, learning, adapting, growing, appreciating, and enjoying.
I have developed enterprise projects that lasted more than 14 years (as the preferred solution), across 15 different industries.  My longest project is still very active, from 2003.
(My journey into coding began with APL in 1980, over a 150 baud modem - via a rotary 'all-in-one' acoustic coupler.  I've seen and experienced a lot.)
For me, KDE on X11 is transparent to the way I think, work, and pivot.  When Devuan 8 eventually comes around, I'll examine SonicDE on X11 for workstation use.
Yes, KDE is memory heavy, and yes, X11 has been declared 'obsolete'.  But for my own soul, nothing else provides me the flexibility I need - season by season.
#20 2026-10-06 02:26:33
KDE Plasma on X11
#21 2026-10-06 20:17:36
kaiyel
"I stopped chasing perfection in favor of consistency."
Same here.  I landed on Mate after stability issues with Cinnamon ages ago and have used it as my daily driver for years.  I'm also a fan of XFCE.  If I could get Mate to stop rearranging the icons in the desktop panel periodically between logins, it would be about perfect.  Not much pizzazz, but everything I need to get work done with months (year?) between reboots.
Cheers,
--K
#22 2026-10-07 17:35:51
blackhole
Regarding gnome-shell, A few months ago I set up an "off the shelf" Debian box with gnome as part of a work project.  Last time I tried it out was probably ten years ago? Itt wasn't at all great then, but it's quite frankly astonishing at how much it has regessed. It used to based around the "don't give the user too many options" philosophy. Now it's more like: "make certain the user can't do anything".
I can't see how anyone would find that usable or useful. I can't envisage who it's designed for or what use case.
I dislike automobile analogies, but it's akin to designing a car without an engine, or controls - as that's far safer and reduces obviously support overhead.
"The idiots can only do what we allow them"
Thus, your theoretical tech support only have to deal with problems 1 to 10.
The usual answers to 1 to 10 will be "reinstall".
#23 2026-10-07 20:21:32
tux_99
@blackhole gnome-shell is for people who want others to make all the decisions for them, they just go along with everything (some would call them lemmings smile ).
TBH, I have Gnome on a tablet as it's well suited for touch screens and that tablet is only used by family members for web browsing and watching videos, but I would never install it on a desktop or laptop PC.
“Either the users control the program – or the program controls the users” Richard Stallman
#24 2026-10-08 07:01:02
pcalvert
I've been using Xfce for years, and it suits me just fine. However, I am looking for something lighter to run in VMs that have limited RAM, and on older hardware (e.g., an old Chromebook with only 2GB of RAM). I've been thinking that LXQt might be a good choice for those situations.
Another one is called Luxxle.
#25 2026-10-08 17:46:29
fanderal
I prefer no DE. Got stuck on Fluxbox with a console login a while back. Can edit a simple text file for the main menu to organize DE-independent apps and short scripts for local stuff like mount/open/umount flash and internal drives, or put a spin drive to sleep when not in use. A right-click anywhere on the desktop opens the menu and where an app's window opens can be specified. Issues with apps come up time to time but never had an issue with Fluxbox. If needed, I'm comfortable with Blackbox, Openbox and XFCE.
I'd suggest installing from a Devuan ISO. I'd also suggest trying many DEs until, over time, you feel drawn to one DE for whatever reason/s. It's a personal choice.
