#1 2026-03-25 22:36:20
karma
xfdashboard
I always like to use xfdashboard on Xfce, but unfortunately it is not in the repos.
What's the best way to install xfdashboard on Devuan Xfce?
Thank you.
#2 2026-03-25 22:50:02
brocashelm
Re: xfdashboard
I don't think this was ever packaged for Debian, as there are no snapshot DEB files in existence. I do know that Ubuntu (and particularly Xubuntu) have it packaged up, but it's not a good idea to mix different repositories.
You're better off just compiling it from source using the same release version as the Xfce you use (which I assume is 4.20 if you are using Devuan Excalibur).
#3 2026-03-25 23:28:27
karma
Re: xfdashboard
Yes I'm on 4.20 and using Devuan Excalibur.
I will definitely look at installing from source.
Haven't done that for a while, but I'm up for the challenge.
Thanks for your reply brocashelm
#4 2026-03-26 00:28:55
Mercury
Re: xfdashboard
Ubuntu packages are installable in Devuan, though dependency management can sometimes be tricky. You can download the DEBs here: https://launchpad.net/ubuntu/+source/xf … d/31059741
Download and simulate an install with apt:
apt --simulate install "./xfdashboard_1.0.0-0ubuntu5_amd64.deb" "./libxfdashboard0_1.0.0-0ubuntu5_amd64.deb"
And let apt tell you what dependencies it's missing.
#5 2026-03-26 00:37:32
Re: xfdashboard
Please note that installing Ubuntu packages is NOT an "official" recommendation. In fact, we advise to avoid installing non-Devuan/Debian packages into the mix.
#6 2026-03-26 03:52:14
Mercury
Re: xfdashboard
For crying out loud. We're not talking about adding Ubuntu repositories - that is a bad idea. A controlled, manual installation of a small set of packages from DEB is not going to torch the system. I did it many times in the past. Sometimes, a package wanted a long chain of Ubuntu-specific dependencies that quickly got unwieldy. I just didn't install it in that case. Most of the time, it was a manageable handful of packages.
There's nothing "official" about my advice. Just stuff that works to achieve a goal.
#7 2026-03-28 16:49:59
mweishaar
Re: xfdashboard
@karma I have been using xfce since around 2006 and have never heard of this. Looked it up, and while it's not something I am interested in I thought I would share a helpful page I found (that you may have already seen).
https://docs.xfce.org/apps/xfdashboard/start
#8 2026-03-28 17:59:59
Mercury
Re: xfdashboard
I downloaded the three main DEB packages from the page I linked earlier, then simulated an installation:
apt --simulate install "/tmp/xfdashboard_1.0.0-0ubuntu5_amd64.deb" "/tmp/libxfdashboard0_1.0.0-0ubuntu5_amd64.deb" "/tmp/xfdashboard-plugins_1.0.0-0ubuntu5_amd64.deb"
The only dependencies required were all satisfied through the regular Devuan repositories. They are:
libclutter-1.0-0
libclutter-1.0-common
libcogl-common
libcogl-pango20
libcogl-path20
libcogl20
I.e. this is easy to install on Devuan.
#9 2026-04-04 16:39:48
karma
Re: xfdashboard
Thanks everyone for your comments.
I tried the method suggested by Mercury, but it did not work for me. I was getting to many errors about unsolvable dependencies.
What I did in the end was to install from source:
version 1.1.0 (2025-08-21) from
https://archive.xfce.org/src/apps/xfdashboard/1.1/
Dependencies required depend on what's already installed.
I installed these.
cmake meson libgarcon-1-dev libxfce4ui-2-dev libcogl-dev libclutter-1.0-0 libclutter-1.0-dev libwnck-3-dev gettext
Then:
# tar xf xfdashboard-<version>.tar.bz2
# cd xfdashboard-<version>
# meson setup build
# meson compile -C build
# meson install -C build
Installed without problem.
But when I tried $ xfdasboard in terminal I got this error:
xfdashboard: error while loading shared libraries: libxfdashboard.so.0.10100.0: cannot open shared object file: No such file or directory
To test if it works I did:
export LD_LIBRARY_PATH=/home/neo/Downloads/Devuan/.bin/xfdashboard-1.1.0/build/libxfdashboard/:$LD_LIBRARY_PATH
then
$ xfdashboard
It worked great
So, I placed my build directory in to my PATH. That's where the offending libxfdashboard.so.0.10100.0 is.
Rebooted, Works great
Added xfdashboard to a hot-corner. Happy now.
