#1 2026-02-27 12:12:06
DaveT
[SOLVED] DNS stopped working on Devuan Ceres
February 24th 2026 DNS stopped working on my Devuan Ceres laptop.
I was also setting up a new Devuan arm install, and that had the same problem. DNS not working but ping worked.
There are a LOT of 'do this to make DNS work' posts on the internet and quit a few here.
After trying the many alternatives this is the only thing that worked on both computers:-
/etc/resolvconf.conf    becomes:-
# Configuration for resolvconf(8)
# See resolvconf.conf(5) for details
resolvconf=NO
# If you run a local name server, you should uncomment the below line and
# configure your subscribers configuration files below.
/etc/resolv.conf        becomes:-
# no longer generated by resolvconf
# entered manually
search lan
nameserver 8.8.8.8
/etc/NetworkManager/NetworkManager.conf   becomes:-
[main]
plugins=ifupdown,keyfile
[ifupdown]
managed=false
I have no idea why Ceres stopped working, it might be because my internet provider is BT in the UK.
#2 2026-02-27 15:51:35
Re: [SOLVED] DNS stopped working on Devuan Ceres
LOL! Maybe it is because Ceres is "unstable" and always in flux until it is officially released as "stable"?
#3 2026-02-27 16:30:46
DaveT
I used Debian Sid (unstable) for many years. There were occasional hiccups but apart from the changeover from Grub V1 to Grub V2 which was 'fraught!' it made a perfectly good OS for my laptop.
I put off moving to Devuan Ceres for a long time, but in the 6 months so far it has been an easy ride - apart from the DNS hassles!
The arm is being used as a server so that is running Excalibur.
#4 2026-02-28 13:39:11
Bold of you to use Ceres, the one time I tried it, I ran into LOTS of issues.
I learned my lesson lol.
Honestly if you want to do a rolling release os there are better options out there then devuan.
Voidlinux & artixlinux both fit that bill.
But yeah, I second what golinux said. That is what unstable does.
Surprised you haven't had more hiccups.
#5 2026-02-28 15:18:49
abower
People running Ceres/Freia helps make Freia good!
#6 2026-02-28 16:46:24
@abower I would trust testing LONG before I trusted unstable tongue
#7 2026-02-28 19:38:38
fanderal
DaveT wrote:
I used Debian Sid (unstable) for many years. There were occasional hiccups but ... it made a perfectly good OS
Same experience here, and true for a while after Devuan became my default. These days, 1 to a dozen pkgs might be held until dependency issues are resolved... with a window mgr, no DE. Unstable isn't as stable smile as it once was, but it's certainly living up to its name today.
#8 2026-03-01 10:51:37
Devarch
smile big_smile
Can't say much about Void (it's probably better while being limited in terms of software) but Artix is definitely less stable than Ceres.
#9 2026-03-02 00:29:16
@Devarch fair enough about artix. I was unaware about this.
