#1 2023-10-02 15:01:51
grafiksinc
Thanks! from the Peppermint Team
Wanted to drop a message in this forum to say thanks! to the Devuan team and community, the solid work you guys do really makes things smooth down stream..
We released  our most recent desktop Devuan build Oct 1everything was smooth....
#2 2023-10-03 03:40:08
Re: Thanks! from the Peppermint Team
Thanks for the update! Any stats you might want to share?
#3 2023-10-05 05:10:09
grafiksinc
Nothing too crazy. this time we adjusted Calamares to let the user select the init they want to use.
A mini (140-180mb) series of ISOs using the debian net installer.
Added a few desktops the community wanted to support.
Later to early next year we are releasing configured server  builds... looking forward to that.
#4 2023-10-05 14:43:39
Excellent!  Expanding available options is always a good thing! Do let us know if you want to be added to the Devuan derivatives list.
#5 2023-10-05 15:21:44
grafiksinc
You guys can make that decision... we are okay with anything....
I personally like to make sure I get over here to say thank you!.
Because not only for the base but the kindness, and helpfulness of the community here.
Feel free to list us if you want easy day.
#6 2023-10-06 23:56:44
@grafiksinc . . .
I have been looking through the Peppermint site and collected a few points to include with your listing which I hope aren't too far off the mark. Feel free to make corrections and/or suggestions. Should the calamares installer be mentioned?
"Peppermint OS Devuan comes with an xfce desktop and essential core packages needed to run a system out of the box. This gives users an opportunity to build a system that best fits their needs. The Devuan build offers 64 and 32 bit versions as well as a choice of SysVinit (default), Runit or OpenRC."
Thanks!
#7 2023-10-07 11:12:03
grafiksinc
That will work.... Thanks!
Very cool!
No need to mention calamares since both installers are used depending on the ISO downloaded...... :-)
#8 2023-10-07 16:12:00
Great! I have already added you to the derivatives list on this forum. Will add you to the list on WWW after b'fast. Cheers!
#9 2023-10-07 21:39:01
I have added it to the beta staging branch.  You can see it here:
https://beta.devuan.org/os/devuan-distros
I'll let someone else move it to the published site.
Thanks again for your contribution! See you next time . . .
