#1 2025-12-19 16:26:42
deepforest
LXQt cant install at Ceres
hi
pls why?
before i am install wine-staging from trixie repo
how to fix this?
root@devuan:/home/freeartist-devuan# apt install lxqt
Solving dependencies... Error!
Unsatisfied dependencies:
 lxqt : Depends: featherpad but it is not going to be installed
        Depends: lximage-qt but it is not going to be installed
        Depends: lxqt-about but it is not going to be installed
        Depends: lxqt-admin but it is not going to be installed
        Depends: lxqt-branding-debian but it is not going to be installed or
                 lxqt-branding
        Depends: lxqt-core (= 33.2) but it is not going to be installed
        Depends: lxqt-openssh-askpass but it is not going to be installed
        Depends: lxqt-powermanagement but it is not going to be installed
        Depends: lxqt-sudo but it is not going to be installed
        Depends: qps but it is not going to be installed
        Depends: qterminal but it is not going to be installed
        Recommends: feathernotes but it is not going to be installed
        Recommends: meteo-qt but it is not going to be installed
        Recommends: qpdfview but it is not going to be installed
        Recommends: hexchat but it is not going to be installed or
                    irssi but it is not going to be installed or
                    weechat but it is not going to be installed
        Recommends: screengrab but it is not going to be installed
        Recommends: xscreensaver but it is not going to be installed
Error: Unable to satisfy dependencies. Reached two conflicting decisions:
   1. lxqt-session:amd64 is selected for install because:
      1. lxqt:amd64=33.2 is selected for install
      2. lxqt:amd64 Depends lxqt-core (= 33.2)
      3. lxqt-core:amd64 Depends lxqt-session
   2. lxqt-session:amd64 Depends lxqt-qtplugin (>= 2.3.0~)
      but none of the choices are installable:
      [no choices]
root@devuan:/home/freeartist-devuan# apt-get dist-upgrade
Calculating upgrade... Done
  gimp gimp-data gir1.2-gimp-3.0 libegl-mesa0 libegl-mesa0:i386 libgbm-dev libgbm-dev:i386 libgbm1 libgbm1:i386 libgimp-3.0-0 libgimp-3.0-bin libgimp-3.0-dev libgl1-mesa-dri
  libgl1-mesa-dri:i386 libglx-mesa0 libglx-mesa0:i386 libqt5core5t64 libqt5dbus5t64 libqt5designer5 libqt5gui5t64 libqt5multimedia5 libqt5network5t64 libqt5opengl5t64 libqt5positioning5
  libqt5printsupport5t64 libqt5qml5 libqt5qmlmodels5 libqt5qmlworkerscript5 libqt5quick5 libqt5sensors5 libqt5sql5-sqlite libqt5sql5t64 libqt5svg5 libqt5test5t64 libqt5waylandclient5
  libqt5waylandcompositor5 libqt5webchannel5 libqt5widgets5t64 libqt5x11extras5 libqt5xml5t64 mesa-libgallium mesa-libgallium:i386 mesa-va-drivers mesa-va-drivers:i386 python3-pyqt5
  qml-module-qtgraphicaleffects qml-module-qtqml qml-module-qtquick-controls qml-module-qtquick-dialogs qml-module-qtquick-layouts qml-module-qtquick-privatewidgets
  qml-module-qtquick-window2 qml-module-qtquick2 qt5-gtk-platformtheme qt5ct qtwayland5 xkb-data
0 upgraded, 0 newly installed, 0 to remove and 57 not upgraded.
root@devuan:/home/freeartist-devuan# apt --fix-broken install
Summary:
  Upgrading: 0, Installing: 0, Removing: 0, Not Upgrading: 57
root@devuan:/home/freeartist-devuan# sudo apt-get --with-new-pkgs upgrade gimp gimp-data gir1.2-gimp-3.0 libegl-mesa0 libegl-mesa0:i386 libgbm-dev libgbm-dev:i386 libgbm1 libgbm1:i386 libgimp-3.0-0 libgimp-3.0-bin libgimp-3.0-dev libgl1-mesa-dri
Calculating upgrade... Error!
 gimp : Depends: libmng2 (>= 2.0.2) but it is not going to be installed
 libegl-mesa0 : Depends: mesa-libgallium (= 25.3.2-2) but 25.2.6-1 is to be installed
 libegl-mesa0:i386 : Depends: mesa-libgallium:i386 (= 25.3.2-2) but 25.2.6-1 is to be installed
 libgbm1 : Depends: mesa-libgallium (= 25.3.2-2) but 25.2.6-1 is to be installed
 libgbm1:i386 : Depends: mesa-libgallium:i386 (= 25.3.2-2) but 25.2.6-1 is to be installed
 libgimp-3.0-dev : Depends: gir1.2-gtk-3.0-dev
 libgl1-mesa-dri : Breaks: libgl1-mesa-dri:i386 (!= 25.3.2-2) but 25.2.6-1 is to be installed
 libgl1-mesa-dri:i386 : Depends: libgbm1:i386 (= 25.2.6-1) but 25.3.2-2 is to be installed
                        Breaks: libgl1-mesa-dri (!= 25.2.6-1) but 25.3.2-2 is to be installed
E: Unable to satisfy dependencies. Reached two conflicting decisions:
   1. libgtk-3-dev:amd64=3.24.51-4 is not selected for install
   2. libgtk-3-dev:amd64=3.24.51-4 is selected as a downgrade because:
      1. libgimp-3.0-dev:amd64=3.2.0~RC2-2 is selected as an upgrade
      2. libgimp-3.0-dev:amd64=3.2.0~RC2-2 Depends gir1.2-gtk-3.0-dev
bash: libgl1-mesa-dri:i386: command not found
bash: libqt5printsupport5t64: command not found
bash: libqt5waylandcompositor5: command not found
bash: qml-module-qtgraphicaleffects: command not found
bash: qml-module-qtquick-window2: command not found
oot@devuan:/home/freeartist-devuan# sudo aptitude full-upgrade
  libmng2{a}
  libappstream-glib8{u} libllvm19:i386{u} mesa-va-drivers{a} mesa-vdpau-drivers{a} mesa-vdpau-drivers:i386{a}
  gimp gimp-data gir1.2-gimp-3.0 libegl-mesa0 libegl-mesa0:i386 libgbm-dev libgbm-dev:i386 libgbm1 libgbm1:i386 libgimp-3.0-0 libgimp-3.0-bin libgimp-3.0-dev{b} libgl1-mesa-dri
  libqt5waylandcompositor5 libqt5webchannel5 libqt5widgets5t64 libqt5x11extras5 libqt5xml5t64 mesa-libgallium{b} mesa-libgallium:i386{b} python3-pyqt5 qml-module-qtgraphicaleffects
  qml-module-qtqml qml-module-qtquick-controls qml-module-qtquick-dialogs qml-module-qtquick-layouts qml-module-qtquick-privatewidgets qml-module-qtquick-window2 qml-module-qtquick2
55 packages upgraded, 1 newly installed, 5 to remove and 1 not upgraded.
Need to get 65.3 MB of archives. After unpacking 138 MB will be freed.
 libgimp-3.0-dev : Depends: gir1.2-gtk-3.0-dev which is a virtual package, provided by:
                            - libgtk-3-dev (3.24.51-4), but 1:3.24.38-2~deb12u2+rpt7+rpi1 is installed
 mesa-libgallium : Breaks: mesa-va-drivers:i386 (< 25.2.8-3) but 25.2.6-1 is installed and it is kept back
 mesa-libgallium:i386 : Breaks: mesa-va-drivers:i386 (< 25.2.8-3) but 25.2.6-1 is installed and it is kept back
 mesa-va-drivers:i386 : Depends: mesa-libgallium:i386 (= 25.2.6-1) but 25.3.2-2 is to be installed
 vdpau-driver-all : Depends: mesa-vdpau-drivers but it is not going to be installed
 vdpau-driver-all:i386 : Depends: mesa-vdpau-drivers:i386 but it is not going to be installed
 libqt5webkit5 : Depends: qtbase-abi-5-15-15 which is a virtual package, provided by:
                          - libqt5core5t64 (5.15.15+dfsg-6), but 5.15.17+dfsg-5 is to be installed
                 Depends: qtdeclarative-abi-5-15-15 which is a virtual package, provided by:
                          - libqt5qml5 (5.15.15+dfsg-3), but 5.15.17+dfsg-4 is to be installed
 keyboard-configuration : Depends: xkb-data (< 2.42A) but 2.46-2 is to be installed
open: 26; closed: 1264; defer: 7; conflict: 8        .The following actions will resolve these dependencies:
     Remove the following packages:
1)     libgimp-3.0-dev [3.0.4-3 (now)]
2)     libqt5webkit5 [5.212.0~alpha4-42+b2 (now)]
3)     mesa-va-drivers:i386 [25.2.6-1 (now)]
4)     smtube [21.7.0-1+b1 (now)]
5)     vdpau-driver-all [1.5-3+b1 (now, unstable)]
6)     vdpau-driver-all:i386 [1.5-3+b1 (now, unstable)]
     Keep the following packages at their current version:
7)     xkb-data [2.42-1 (now)]
Accept this solution? [Y/n/q/?] y
  libmng2{a}
  geoclue-2.0{u} iio-sensor-proxy{u} libappstream-glib8{u} libexiv2-dev{u} libgexiv2-dev{u} libgimp-3.0-bin{u} libgimp-3.0-dev{a} libllvm19:i386{u} libqt5positioning5{u}
  libqt5sensors5{u} libqt5webchannel5{u} libqt5webkit5{a} libvdpau-va-gl1{u} libvdpau-va-gl1:i386{u} mesa-va-drivers{a} mesa-va-drivers:i386{a} mesa-vdpau-drivers{a}
  mesa-vdpau-drivers:i386{a} smtube{a} vdpau-driver-all{a} vdpau-driver-all:i386{a}
  gimp gimp-data gir1.2-gimp-3.0 libegl-mesa0 libegl-mesa0:i386 libgbm-dev libgbm-dev:i386 libgbm1 libgbm1:i386 libgimp-3.0-0 libgl1-mesa-dri libgl1-mesa-dri:i386 libglx-mesa0
  libglx-mesa0:i386 libqt5core5t64 libqt5dbus5t64 libqt5designer5 libqt5gui5t64 libqt5multimedia5 libqt5network5t64 libqt5opengl5t64 libqt5printsupport5t64 libqt5qml5 libqt5qmlmodels5
  libqt5qmlworkerscript5 libqt5quick5 libqt5sql5-sqlite libqt5sql5t64 libqt5svg5 libqt5test5t64 libqt5waylandclient5 libqt5waylandcompositor5 libqt5widgets5t64 libqt5x11extras5
  libqt5xml5t64 mesa-libgallium mesa-libgallium:i386 python3-pyqt5 qml-module-qtgraphicaleffects qml-module-qtqml qml-module-qtquick-controls qml-module-qtquick-dialogs
  qml-module-qtquick-layouts qml-module-qtquick-privatewidgets qml-module-qtquick-window2 qml-module-qtquick2 qt5-gtk-platformtheme qt5ct qtwayland5
49 packages upgraded, 1 newly installed, 21 to remove and 1 not upgraded.
Need to get 63.7 MB of archives. After unpacking 201 MB will be freed.
Do you want to continue? [Y/n/?] y
Get: 1 http://deb.devuan.org/merged ceres/main amd64 gimp amd64 3.2.0~RC2-2 [6,793 kB]
Get: 2 http://deb.devuan.org/merged ceres/main amd64 gimp-data all 3.2.0~RC2-2 [13.1 MB]
Get: 3 http://deb.devuan.org/merged ceres/main amd64 libgimp-3.0-0 amd64 3.2.0~RC2-2 [1,071 kB]
Get: 4 http://deb.devuan.org/merged ceres/main amd64 gir1.2-gimp-3.0 amd64 3.2.0~RC2-2 [95.9 kB]
Get: 5 http://deb.devuan.org/merged ceres/main amd64 libmng2 amd64 2.0.3+dfsg-5 [192 kB]
Get: 6 http://deb.devuan.org/merged ceres/main amd64 libegl-mesa0 amd64 25.3.2-2 [124 kB]
Get: 7 http://deb.devuan.org/merged ceres/main i386 libegl-mesa0 i386 25.3.2-2 [129 kB]
Get: 8 http://deb.devuan.org/merged ceres/main amd64 libglx-mesa0 amd64 25.3.2-2 [117 kB]
Get: 9 http://deb.devuan.org/merged ceres/main i386 libglx-mesa0 i386 25.3.2-2 [121 kB]
Get: 10 http://deb.devuan.org/merged ceres/main i386 libgl1-mesa-dri i386 25.3.2-2 [47.1 kB]
Get: 11 http://deb.devuan.org/merged ceres/main amd64 libgl1-mesa-dri amd64 25.3.2-2 [48.9 kB]
Get: 12 http://deb.devuan.org/merged ceres/main i386 libgbm-dev i386 25.3.2-2 [26.9 kB]
Get: 13 http://deb.devuan.org/merged ceres/main amd64 libgbm-dev amd64 25.3.2-2 [26.9 kB]
Get: 14 http://deb.devuan.org/merged ceres/main amd64 libgbm1 amd64 25.3.2-2 [46.6 kB]
Get: 15 http://deb.devuan.org/merged ceres/main i386 libgbm1 i386 25.3.2-2 [47.9 kB]
Get: 16 http://deb.devuan.org/merged ceres/main i386 mesa-libgallium i386 25.3.2-2 [10.6 MB]
Get: 17 http://deb.devuan.org/merged ceres/main amd64 mesa-libgallium amd64 25.3.2-2 [10.3 MB]
Get: 18 http://deb.devuan.org/merged ceres/main amd64 libqt5dbus5t64 amd64 5.15.17+dfsg-5 [219 kB]
Get: 19 http://deb.devuan.org/merged ceres/main amd64 libqt5x11extras5 amd64 5.15.17-2 [10.3 kB]
Get: 20 http://deb.devuan.org/merged ceres/main amd64 libqt5network5t64 amd64 5.15.17+dfsg-5 [692 kB]
Get: 21 http://deb.devuan.org/merged ceres/main amd64 libqt5gui5t64 amd64 5.15.17+dfsg-5 [3,533 kB]
Get: 22 http://deb.devuan.org/merged ceres/main amd64 qtwayland5 amd64 5.15.17-3 [204 kB]
Get: 23 http://deb.devuan.org/merged ceres/main amd64 libqt5waylandclient5 amd64 5.15.17-3 [377 kB]
Get: 24 http://deb.devuan.org/merged ceres/main amd64 libqt5qmlmodels5 amd64 5.15.17+dfsg-4 [195 kB]
Get: 25 http://deb.devuan.org/merged ceres/main amd64 qml-module-qtqml amd64 5.15.17+dfsg-4 [21.1 kB]
Get: 26 http://deb.devuan.org/merged ceres/main amd64 libqt5qmlworkerscript5 amd64 5.15.17+dfsg-4 [36.2 kB]
Get: 27 http://deb.devuan.org/merged ceres/main amd64 libqt5quick5 amd64 5.15.17+dfsg-4 [1,627 kB]
Get: 28 http://deb.devuan.org/merged ceres/main amd64 qml-module-qtquick2 amd64 5.15.17+dfsg-4 [37.4 kB]
Get: 29 http://deb.devuan.org/merged ceres/main amd64 libqt5widgets5t64 amd64 5.15.17+dfsg-5 [2,425 kB]
Get: 30 http://deb.devuan.org/merged ceres/main amd64 qml-module-qtquick-privatewidgets amd64 5.15.17-3 [45.9 kB]
Get: 31 http://deb.devuan.org/merged ceres/main amd64 qml-module-qtquick-dialogs amd64 5.15.17-3 [124 kB]
Get: 32 http://deb.devuan.org/merged ceres/main amd64 qml-module-qtquick-layouts amd64 5.15.17+dfsg-4 [55.9 kB]
Get: 33 http://deb.devuan.org/merged ceres/main amd64 qml-module-qtquick-controls amd64 5.15.17-3 [534 kB]
Get: 34 http://deb.devuan.org/merged ceres/main amd64 qml-module-qtgraphicaleffects amd64 5.15.17-2 [69.5 kB]
Get: 35 http://deb.devuan.org/merged ceres/main amd64 qml-module-qtquick-window2 amd64 5.15.17+dfsg-4 [28.8 kB]
Get: 36 http://deb.devuan.org/merged ceres/main amd64 libqt5waylandcompositor5 amd64 5.15.17-3 [361 kB]
Get: 37 http://deb.devuan.org/merged ceres/main amd64 libqt5qml5 amd64 5.15.17+dfsg-4 [1,392 kB]
Get: 38 http://deb.devuan.org/merged ceres/main amd64 libqt5svg5 amd64 5.15.17-2 [138 kB]
Get: 39 http://deb.devuan.org/merged ceres/main amd64 qt5ct amd64 1.9-1+b1 [220 kB]
Get: 40 http://deb.devuan.org/merged ceres/main amd64 qt5-gtk-platformtheme amd64 5.15.17+dfsg-5 [131 kB]
Get: 41 http://deb.devuan.org/merged ceres/main amd64 libqt5xml5t64 amd64 5.15.17+dfsg-5 [127 kB]
Get: 42 http://deb.devuan.org/merged ceres/main amd64 libqt5designer5 amd64 5.15.17-4+b1 [2,770 kB]
Get: 43 http://deb.devuan.org/merged ceres/main amd64 libqt5printsupport5t64 amd64 5.15.17+dfsg-5 [208 kB]
Get: 44 http://deb.devuan.org/merged ceres/main amd64 libqt5test5t64 amd64 5.15.17+dfsg-5 [153 kB]
Get: 45 http://deb.devuan.org/merged ceres/main amd64 python3-pyqt5 amd64 5.15.11+dfsg-3 [2,537 kB]
Get: 46 http://deb.devuan.org/merged ceres/main amd64 libqt5sql5t64 amd64 5.15.17+dfsg-5 [127 kB]
Get: 47 http://deb.devuan.org/merged ceres/main amd64 libqt5sql5-sqlite amd64 5.15.17+dfsg-5 [60.2 kB]
Get: 48 http://deb.devuan.org/merged ceres/main amd64 libqt5opengl5t64 amd64 5.15.17+dfsg-5 [153 kB]
Get: 49 http://deb.devuan.org/merged ceres/main amd64 libqt5multimedia5 amd64 5.15.17-2 [282 kB]
Get: 50 http://deb.devuan.org/merged ceres/main amd64 libqt5core5t64 amd64 5.15.17+dfsg-5 [1,900 kB]
Fetched 63.7 MB in 13s (4,851 kB/s)
Reading changelogs... Done
Extracting templates from packages: 100%
(Reading database… 394806 files and directories currently installed.)
Removing geoclue-2.0 (2.8.0-1)…
Removing iio-sensor-proxy (3.8-1)…
(Reading database… 394771 files and directories currently installed.)
Preparing to unpack …/gimp_3.2.0~RC2-2_amd64.deb…
Unpacking gimp (3.2.0~RC2-2) over (3.0.4-3)…
Preparing to unpack …/gimp-data_3.2.0~RC2-2_all.deb…
Unpacking gimp-data (3.2.0~RC2-2) over (3.0.4-6.2)…
(Reading database… 394790 files and directories currently installed.)
Removing libgimp-3.0-dev:amd64 (3.0.4-3)…
(Reading database… 394523 files and directories currently installed.)
Preparing to unpack …/libgimp-3.0-0_3.2.0~RC2-2_amd64.deb…
Unpacking libgimp-3.0-0:amd64 (3.2.0~RC2-2) over (3.0.4-3)…
Preparing to unpack …/gir1.2-gimp-3.0_3.2.0~RC2-2_amd64.deb…
Unpacking gir1.2-gimp-3.0:amd64 (3.2.0~RC2-2) over (3.0.4-3)…
Selecting previously unselected package libmng2:amd64.
Preparing to unpack …/libmng2_2.0.3+dfsg-5_amd64.deb…
Unpacking libmng2:amd64 (2.0.3+dfsg-5)…
(Reading database… 394531 files and directories currently installed.)
Removing libappstream-glib8:amd64 (0.8.3-2)…
Removing libgexiv2-dev:amd64 (0.14.6-2)…
Removing libexiv2-dev:amd64 (0.28.7+dfsg-2)…
Removing libgimp-3.0-bin (3.0.4-3)…
Removing vdpau-driver-all:amd64 (1.5-3+b1)…
Removing mesa-vdpau-drivers:amd64 (25.2.8-2+b3)…
Removing vdpau-driver-all:i386 (1.5-3+b1)…
Removing mesa-vdpau-drivers:i386 (25.2.8-2+b3)…
(Reading database… 394387 files and directories currently installed.)
Preparing to unpack …/0-libegl-mesa0_25.3.2-2_i386.deb…
De-configuring libegl-mesa0:amd64 (25.2.6-1), to allow configuration of libegl-mesa0:i386 (25.3.2-2)…
Unpacking libegl-mesa0:i386 (25.3.2-2) over (25.2.6-1)…
Preparing to unpack …/1-libegl-mesa0_25.3.2-2_amd64.deb…
Unpacking libegl-mesa0:amd64 (25.3.2-2) over (25.2.6-1)…
Preparing to unpack …/2-libglx-mesa0_25.3.2-2_i386.deb…
De-configuring libglx-mesa0:amd64 (25.2.6-1), to allow configuration of libglx-mesa0:i386 (25.3.2-2)…
Unpacking libglx-mesa0:i386 (25.3.2-2) over (25.2.6-1)…
Preparing to unpack …/3-libglx-mesa0_25.3.2-2_amd64.deb…
Unpacking libglx-mesa0:amd64 (25.3.2-2) over (25.2.6-1)…
Preparing to unpack …/4-libgl1-mesa-dri_25.3.2-2_amd64.deb…
De-configuring libgl1-mesa-dri:i386 (25.2.6-1), to allow configuration of libgl1-mesa-dri:amd64 (25.3.2-2)…
Unpacking libgl1-mesa-dri:amd64 (25.3.2-2) over (25.2.6-1)…
Preparing to unpack …/5-libgl1-mesa-dri_25.3.2-2_i386.deb…
Unpacking libgl1-mesa-dri:i386 (25.3.2-2) over (25.2.6-1)…
Preparing to unpack …/6-libgbm-dev_25.3.2-2_amd64.deb…
De-configuring libgbm-dev:i386 (25.2.6-1), to allow configuration of libgbm-dev:amd64 (25.3.2-2)…
Unpacking libgbm-dev:amd64 (25.3.2-2) over (25.2.6-1)…
Preparing to unpack …/7-libgbm-dev_25.3.2-2_i386.deb…
Unpacking libgbm-dev:i386 (25.3.2-2) over (25.2.6-1)…
Preparing to unpack …/8-libgbm1_25.3.2-2_i386.deb…
De-configuring libgbm1:amd64 (25.2.6-1), to allow configuration of libgbm1:i386 (25.3.2-2)…
Unpacking libgbm1:i386 (25.3.2-2) over (25.2.6-1)…
Preparing to unpack …/9-libgbm1_25.3.2-2_amd64.deb…
Unpacking libgbm1:amd64 (25.3.2-2) over (25.2.6-1)…
dpkg: mesa-va-drivers:i386: dependency problems, but removing anyway as you requested:
 va-driver-all:i386 depends on mesa-va-drivers.
Removing mesa-va-drivers:i386 (25.2.6-1)…
dpkg: mesa-va-drivers:amd64: dependency problems, but removing anyway as you requested:
 va-driver-all:amd64 depends on mesa-va-drivers.
Removing mesa-va-drivers:amd64 (25.2.6-1)…
(Reading database… 394371 files and directories currently installed.)
Preparing to unpack …/mesa-libgallium_25.3.2-2_amd64.deb…
De-configuring mesa-libgallium:i386 (25.2.6-1), to allow configuration of mesa-libgallium:amd64 (25.3.2-2)…
Unpacking mesa-libgallium:amd64 (25.3.2-2) over (25.2.6-1)…
Preparing to unpack …/mesa-libgallium_25.3.2-2_i386.deb…
Unpacking mesa-libgallium:i386 (25.3.2-2) over (25.2.6-1)…
(Reading database… 394380 files and directories currently installed.)
Removing libllvm19:i386 (1:19.1.7-19)…
Removing smtube (21.7.0-1+b1)…
Removing libqt5webkit5:amd64 (5.212.0~alpha4-42+b2)…
Removing libqt5positioning5:amd64 (5.15.15+dfsg-3+b1)…
Removing libqt5sensors5:amd64 (5.15.15-2)…
Removing libqt5webchannel5:amd64 (5.15.15-2)…
Removing libvdpau-va-gl1:amd64 (0.4.2-2)…
Removing libvdpau-va-gl1:i386 (0.4.2-2)…
(Reading database… 394280 files and directories currently installed.)
Preparing to unpack …/00-libqt5dbus5t64_5.15.17+dfsg-5_amd64.deb…
Unpacking libqt5dbus5t64:amd64 (5.15.17+dfsg-5) over (5.15.15+dfsg-6)…
Preparing to unpack …/01-libqt5x11extras5_5.15.17-2_amd64.deb…
Unpacking libqt5x11extras5:amd64 (5.15.17-2) over (5.15.15-2)…
Preparing to unpack …/02-libqt5network5t64_5.15.17+dfsg-5_amd64.deb…
Unpacking libqt5network5t64:amd64 (5.15.17+dfsg-5) over (5.15.15+dfsg-6)…
Preparing to unpack …/03-libqt5gui5t64_5.15.17+dfsg-5_amd64.deb…
Unpacking libqt5gui5t64:amd64 (5.15.17+dfsg-5) over (5.15.15+dfsg-6)…
Preparing to unpack …/04-qtwayland5_5.15.17-3_amd64.deb…
Unpacking qtwayland5:amd64 (5.15.17-3) over (5.15.15-3)…
Preparing to unpack …/05-libqt5waylandclient5_5.15.17-3_amd64.deb…
Unpacking libqt5waylandclient5:amd64 (5.15.17-3) over (5.15.15-3)…
Preparing to unpack …/06-libqt5qmlmodels5_5.15.17+dfsg-4_amd64.deb…
Unpacking libqt5qmlmodels5:amd64 (5.15.17+dfsg-4) over (5.15.15+dfsg-3)…
Preparing to unpack …/07-qml-module-qtqml_5.15.17+dfsg-4_amd64.deb…
Unpacking qml-module-qtqml:amd64 (5.15.17+dfsg-4) over (5.15.15+dfsg-3)…
Preparing to unpack …/08-libqt5qmlworkerscript5_5.15.17+dfsg-4_amd64.deb…
Unpacking libqt5qmlworkerscript5:amd64 (5.15.17+dfsg-4) over (5.15.15+dfsg-3)…
Preparing to unpack …/09-libqt5quick5_5.15.17+dfsg-4_amd64.deb…
Unpacking libqt5quick5:amd64 (5.15.17+dfsg-4) over (5.15.15+dfsg-3)…
Preparing to unpack …/10-qml-module-qtquick2_5.15.17+dfsg-4_amd64.deb…
Unpacking qml-module-qtquick2:amd64 (5.15.17+dfsg-4) over (5.15.15+dfsg-3)…
Preparing to unpack …/11-libqt5widgets5t64_5.15.17+dfsg-5_amd64.deb…
Unpacking libqt5widgets5t64:amd64 (5.15.17+dfsg-5) over (5.15.15+dfsg-6)…
Preparing to unpack …/12-qml-module-qtquick-privatewidgets_5.15.17-3_amd64.deb…
Unpacking qml-module-qtquick-privatewidgets:amd64 (5.15.17-3) over (5.15.15-2)…
Preparing to unpack …/13-qml-module-qtquick-dialogs_5.15.17-3_amd64.deb…
Unpacking qml-module-qtquick-dialogs:amd64 (5.15.17-3) over (5.15.15-2)…
Preparing to unpack …/14-qml-module-qtquick-layouts_5.15.17+dfsg-4_amd64.deb…
Unpacking qml-module-qtquick-layouts:amd64 (5.15.17+dfsg-4) over (5.15.15+dfsg-3)…
Preparing to unpack …/15-qml-module-qtquick-controls_5.15.17-3_amd64.deb…
Unpacking qml-module-qtquick-controls:amd64 (5.15.17-3) over (5.15.15-2)…
Preparing to unpack …/16-qml-module-qtgraphicaleffects_5.15.17-2_amd64.deb…
Unpacking qml-module-qtgraphicaleffects:amd64 (5.15.17-2) over (5.15.15-2)…
Preparing to unpack …/17-qml-module-qtquick-window2_5.15.17+dfsg-4_amd64.deb…
Unpacking qml-module-qtquick-window2:amd64 (5.15.17+dfsg-4) over (5.15.15+dfsg-3)…
Preparing to unpack …/18-libqt5waylandcompositor5_5.15.17-3_amd64.deb…
Unpacking libqt5waylandcompositor5:amd64 (5.15.17-3) over (5.15.15-3)…
Preparing to unpack …/19-libqt5qml5_5.15.17+dfsg-4_amd64.deb…
Unpacking libqt5qml5:amd64 (5.15.17+dfsg-4) over (5.15.15+dfsg-3)…
Preparing to unpack …/20-libqt5svg5_5.15.17-2_amd64.deb…
Unpacking libqt5svg5:amd64 (5.15.17-2) over (5.15.15-2)…
Preparing to unpack …/21-qt5ct_1.9-1+b1_amd64.deb…
Unpacking qt5ct (1.9-1+b1) over (1.9-1)…
Preparing to unpack …/22-qt5-gtk-platformtheme_5.15.17+dfsg-5_amd64.deb…
Unpacking qt5-gtk-platformtheme:amd64 (5.15.17+dfsg-5) over (5.15.15+dfsg-6)…
Preparing to unpack …/23-libqt5xml5t64_5.15.17+dfsg-5_amd64.deb…
Unpacking libqt5xml5t64:amd64 (5.15.17+dfsg-5) over (5.15.15+dfsg-6)…
Preparing to unpack …/24-libqt5designer5_5.15.17-4+b1_amd64.deb…
Unpacking libqt5designer5:amd64 (5.15.17-4+b1) over (5.15.15-6)…
Preparing to unpack …/25-libqt5printsupport5t64_5.15.17+dfsg-5_amd64.deb…
Unpacking libqt5printsupport5t64:amd64 (5.15.17+dfsg-5) over (5.15.15+dfsg-6)…
Preparing to unpack …/26-libqt5test5t64_5.15.17+dfsg-5_amd64.deb…
Unpacking libqt5test5t64:amd64 (5.15.17+dfsg-5) over (5.15.15+dfsg-6)…
Preparing to unpack …/27-python3-pyqt5_5.15.11+dfsg-3_amd64.deb…
Unpacking python3-pyqt5 (5.15.11+dfsg-3) over (5.15.11+dfsg-2)…
Preparing to unpack …/28-libqt5sql5t64_5.15.17+dfsg-5_amd64.deb…
Unpacking libqt5sql5t64:amd64 (5.15.17+dfsg-5) over (5.15.15+dfsg-6)…
Preparing to unpack …/29-libqt5sql5-sqlite_5.15.17+dfsg-5_amd64.deb…
Unpacking libqt5sql5-sqlite:amd64 (5.15.17+dfsg-5) over (5.15.15+dfsg-6)…
Preparing to unpack …/30-libqt5opengl5t64_5.15.17+dfsg-5_amd64.deb…
Unpacking libqt5opengl5t64:amd64 (5.15.17+dfsg-5) over (5.15.15+dfsg-6)…
Preparing to unpack …/31-libqt5multimedia5_5.15.17-2_amd64.deb…
Unpacking libqt5multimedia5:amd64 (5.15.17-2) over (5.15.15-2)…
Preparing to unpack …/32-libqt5core5t64_5.15.17+dfsg-5_amd64.deb…
Unpacking libqt5core5t64:amd64 (5.15.17+dfsg-5) over (5.15.15+dfsg-6)…
Setting up mesa-libgallium:amd64 (25.3.2-2)…
Setting up mesa-libgallium:i386 (25.3.2-2)…
Setting up libmng2:amd64 (2.0.3+dfsg-5)…
Setting up libgbm1:amd64 (25.3.2-2)…
Setting up libgbm1:i386 (25.3.2-2)…
Setting up libgl1-mesa-dri:amd64 (25.3.2-2)…
Setting up libgl1-mesa-dri:i386 (25.3.2-2)…
Setting up libgbm-dev:amd64 (25.3.2-2)…
Setting up libgbm-dev:i386 (25.3.2-2)…
Setting up libqt5core5t64:amd64 (5.15.17+dfsg-5)…
Setting up libegl-mesa0:amd64 (25.3.2-2)…
Setting up libegl-mesa0:i386 (25.3.2-2)…
Setting up libgimp-3.0-0:amd64 (3.2.0~RC2-2)…
Setting up gimp-data (3.2.0~RC2-2)…
Installing new version of config file /etc/gimp/3.0/gimprc…
Installing new version of config file /etc/gimp/3.0/sessionrc…
Installing new version of config file /etc/gimp/3.0/toolrc…
Setting up libqt5sql5t64:amd64 (5.15.17+dfsg-5)…
Setting up libqt5dbus5t64:amd64 (5.15.17+dfsg-5)…
Setting up libglx-mesa0:amd64 (25.3.2-2)…
Setting up libglx-mesa0:i386 (25.3.2-2)…
Setting up libqt5sql5-sqlite:amd64 (5.15.17+dfsg-5)…
Setting up libqt5network5t64:amd64 (5.15.17+dfsg-5)…
Setting up libqt5xml5t64:amd64 (5.15.17+dfsg-5)…
Setting up libqt5test5t64:amd64 (5.15.17+dfsg-5)…
Setting up gir1.2-gimp-3.0:amd64 (3.2.0~RC2-2)…
Setting up libqt5gui5t64:amd64 (5.15.17+dfsg-5)…
Setting up libqt5qml5:amd64 (5.15.17+dfsg-4)…
Setting up gimp (3.2.0~RC2-2)…
Setting up libqt5x11extras5:amd64 (5.15.17-2)…
Setting up libqt5qmlmodels5:amd64 (5.15.17+dfsg-4)…
Setting up libqt5widgets5t64:amd64 (5.15.17+dfsg-5)…
Setting up qml-module-qtqml:amd64 (5.15.17+dfsg-4)…
Setting up libqt5svg5:amd64 (5.15.17-2)…
Setting up qt5-gtk-platformtheme:amd64 (5.15.17+dfsg-5)…
Setting up libqt5waylandclient5:amd64 (5.15.17-3)…
Setting up libqt5multimedia5:amd64 (5.15.17-2)…
Setting up libqt5qmlworkerscript5:amd64 (5.15.17+dfsg-4)…
Setting up libqt5opengl5t64:amd64 (5.15.17+dfsg-5)…
Setting up libqt5quick5:amd64 (5.15.17+dfsg-4)…
Setting up libqt5printsupport5t64:amd64 (5.15.17+dfsg-5)…
Setting up libqt5designer5:amd64 (5.15.17-4+b1)…
Setting up qt5ct (1.9-1+b1)…
Setting up qml-module-qtquick-window2:amd64 (5.15.17+dfsg-4)…
Setting up qml-module-qtquick-layouts:amd64 (5.15.17+dfsg-4)…
Setting up libqt5waylandcompositor5:amd64 (5.15.17-3)…
Setting up qml-module-qtquick2:amd64 (5.15.17+dfsg-4)…
Setting up qml-module-qtquick-privatewidgets:amd64 (5.15.17-3)…
Setting up python3-pyqt5 (5.15.11+dfsg-3)…
Setting up qtwayland5:amd64 (5.15.17-3)…
Setting up qml-module-qtgraphicaleffects:amd64 (5.15.17-2)…
Setting up qml-module-qtquick-dialogs:amd64 (5.15.17-3)…
Setting up qml-module-qtquick-controls:amd64 (5.15.17-3)…
Processing triggers for man-db (2.13.1-1)…
Processing triggers for dbus (1.16.2-2devuan2)…
Processing triggers for mailcap (3.75)…
Processing triggers for desktop-file-utils (0.28-1)…
Processing triggers for hicolor-icon-theme (0.18-2)…
Processing triggers for gnome-menus (3.38.1-1)…
Processing triggers for libc-bin (2.42-6)…
Processing triggers for glx-alternative-mesa (1.2.2)…
Current status: 1 (-56) upgradable.
root@devuan:/home/freeartist-devuan# sudo aptitude full-upgrade
  xkb-data
1 packages upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 830 kB of archives. After unpacking 3,985 kB will be used.
1)     xkb-data [2.42-1 (now)]
No packages will be installed, upgraded, or removed.
0 packages upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
Need to get 0 B of archives. After unpacking 0 B will be used.
smile
pyzNi 3.14zDa! smile
#2 2025-12-19 17:20:39
deepforest
Re: LXQt cant install at Ceres
Ceres is broken?
why?
can i fix this?
smile
#3 2025-12-19 19:12:13
fanderal
[no choices]
Lxqt-qtplugin is the problem. Version 2.3.0 is not available now but will be available soon. This occasionally happens in Ceres.
LXQt system integration plugin for Qt
https://tracker.debian.org/pkg/lxqt-qtplugin
#4 2025-12-19 20:20:07
deepforest
Ceres is broken?
Its can be fixed or not?
After reinstall xkb-plugin my Ceres is broken, i cant install anything, xorg - no choices, nvidia driver - no choices...
Why all broken?
smile
#5 2025-12-19 20:30:25
deepforest
same situation at Debian Sid
after upgrading xkb-data big part of X11 now broken
https://www.reddit.com/r/debian/comment … e_and_not/
smile
#6 2025-12-19 20:46:19
ceres is always broken. This is not news . . .
#7 2025-12-19 21:05:43
deepforest
can i fix this via daily mini.iso?
smile
#8 2025-12-19 22:54:40
HardSun
Sid and therefore ceres will be broken.
serious xkb-data bug: https://bugs.debian.org/cgi-bin/bugrepo … ug=1122650
#9 2025-12-19 23:53:42
RedGreen925
Why all broken?
Because it is the unstable version of the development branch of Debian being used by it. Which if you took the time to learn about it has breakages all the time. It is not for the faint of heart who want a good working system all the time this is what the stable version is for. The best strategy for running such a system is to not upgrade for days after you see the packages available while you scour the various forums and mailings list to determine what has been broken with the latest updates and if any work a rounds have been found. Especially when you have an nVidia graphics card who drivers always break with just about every new kernel update put out by such a distribution. With such a card you are set for failure on a regular basis using it.
#10 2025-12-20 09:09:09
deepforest
HardSun
RedGreen925
Thank you kind mans for yours replays and explains.
Is there any chance to fix this broken system or not?
Or only one way here to do fresh installation?
smile
#11 2025-12-20 10:20:44
Well, Ceres is broken by definition, it is and will remain UNSTABLE in exactly the litteral meaning of this word. The software in Ceres will slowly evolve and mature and end up in Testing at some point in time. And when testing is done, the software finally will become released as stable. It will take a lot of time.
If you want a stable environment use Excalibur. It has some bugs, but it is tested and released for general use.
When you are a bit more daring you may use Testing, which currently is Freia.
Please stop complaing about Ceres is broken.
#12 2025-12-20 11:53:50
deepforest
Thanks,
i am not complain,
i am ask is it fixible or not?
smile
#13 2025-12-20 12:38:56
RedGreen925
Eventually the bugs in it and the broken packages will be fixed, until then you get to wait for the fixes like everyone else. Running that version of the OS is only for very experienced people who are ready and able to fix these broken things themselves. A re-install of it will result in the same broken state you are in now if you want newer software with less chance of having broken packages and systems then use the testing/Freia branch this is composed of software that is just slightly older by a few days or week or two than the Ceres/unstable but only get into it if no major bugs are found in it while it is being confirmed by people not reporting any in the unstable packages. This allows you to run the newer software with greater likelihood of it being usable most of the time.
#14 2025-12-20 17:52:17
deepforest
RedGreen925
why no variants like "roll back" i.e. copy(replace) over my broken healthy files that not affected this bug, is it possible?
smile
#15 2025-12-20 20:24:09
RedGreen925
Always possible if you know the packages required to be be installed to have them used again. Then you need to stop updating the system or have put them packages on hold to stop them from being updated until new packages arrive that fix the broken mess. Either way it requires someone who knows their way around the system and the pitfalls of using it with the skills to fix it once broken.
#16 2025-12-20 20:48:29
deepforest
How then as you can see i cant reinstall anything?
https://dev1galaxy.org/viewtopic.php?pid=60721#p60721
smile
#17 2025-12-21 01:03:22
RedGreen925
Because you try to install the broken packages until Debian gets updated packages you will be in that situation trying to use apt. Now you can look into the /var/cache/apt/archives directory to see if those broken packages are there at an older version you can install to try and get it working. You would need to use the dpkg pckage to install them manually with a line like dpkg -i /var/cache/apt/archives/xorg_old_version.deb /var/cache/apt/archives/xfonts-scalable_old_version.deb ..... for all the packages it complains about that will not install with the new packages. This stands a chance of getting back to a working graphical system on your machine. If you get this to work then go into your sources.list or devuan.source if using that and change it to follow the testing then you should not end up with this kind of mess again. Your other option is to follow a stable system which will allow you to use it all the time without this junk happening to you.
#18 2025-12-21 10:28:22
dzz
More info (please don't request support there if you don't run siduction):
https://forum.siduction.org/index.php?topic=9864.0
https://forum.siduction.org/index.php?topic=9854.0
#19 2026-04-29 22:04:16
deepforest
Sorry for reflection.
Where is here was the problem? At lxqt-qtplugin or xkb-data or both?
What is the right way for update Ceres and how to avoid this problems in the future?
smile
#20 2026-05-01 00:34:49
pcalvert
I don't use Ceres, but I have considered using it. If I were using Ceres I would be using using BTRFS, ZFS, or ext4 with LVM, and the reason is snapshots. And along with one of those, I would probably use a utility like sanoid, snapper, or timeshift. With snapshots, one can "roll" the system back to the state it was in before the upgrade that broke it.
This website could also be useful for repairing a broken system: https://snapshot.debian.org/.
One must be extra careful when using it, though, because using Debian repositories with Devuan can cause serious problems. If only a few packages are required, downloading them manually would be the safest approach. Otherwise, apt-pinning will be required to prevent the automatic installation of Debian packages that you are not interested in.
Another one is called Luxxle.
#21 2026-05-02 09:46:12
Kristof12
It does seem you reinstalled by "apt remove" then "apt install" it's expected because of dependency tree is expected these issues is kinda common, it's better to use "apt reinstall" and check dependencies before using "apt remove" exactly, will always give you these headaches, try use Testing instead and you can have a better time
#22 2026-05-03 09:51:34
Duke Nukem
Is there a specific reason for you wanting to use Ceres? Are you a developer? Ceres is there for developers to try things out, to experiment with - in parallel with Debian's Sid.
Only one piece will be fixed at a time. Fixes will then be transferred into the testing version, currently Freia (equivalent to Debian Forky), but tinkering and trials with Ceres will continue so it will always be unstable.
#23 2026-05-03 23:20:14
deepforest
@Duke Nukem
1. Ceres\Sid still support nvidia 340 driver but Stable not
2. Ceres feels snappier then Stable at my old PC
smile
