#1 Today 10:33:48
kapqa
upgrade succesful .. or not? (systemd)
Hello ,
have discovered the tool "nala" for update/upgrade and trying it out.
today it  took some time to finish and left me with this message
Fetched 147.0 MB in 23s (6.4 MB/s)
│✔ Running dpkg … ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 100.0% • 0:00:00 • 539/539│
Warning: unable to delete old directory '/lib/systemd/system': Directory not empty
Warning: unable to delete old directory '/lib/systemd': Directory not empty
Finished Successfully
may question:
am i allowed to delete those folders?
have seen that the upgrades pull quite some packages with "systemd" in namespace in for devuan 7.0 , but have taken notice of them all.
(most will probably be beningn?)
thank you.
#2 Today 13:54:02
Re: upgrade succesful .. or not? (systemd)
Perhaps you are seeing those files due to this decision made early on in Devuan's history?
"Why are systemd files present in Devuan?"
https://dev1galaxy.org/viewtopic.php?id=1925
Something to consider . . .
#3 Today 17:26:04
kapqa
thanks , i suppose the upgraded files theat are being pulled like @libpipewire/systemd or something *just one catch
is due to being automatically linked with the debian.system since i had disabled both pulseaduio.pipewire to the best of instructions received.
nothing to be concerned of, i guess, and thanks for the }requiredP{ reading.
much appreciated.
