Pages: 1
Opening this new thread in order to keep all genuen related questions and discussions in one place, as a successor to the historical gnuinos thread.
First, I would like to take the opportunity to thank the whole Devuan community for their hard work, and especially Aitor for his sustained work on genuen (previously known as gnuinos) and for his active support all along the way.
Since we are here, I would also like to report that after creating a VM with the latest version (2026.06.20) of the genuen 6 iso image, I am currently not able to start a graphical session. I will try tweaking the VM settings, but am currently left with a blinking cursor. The Xorg.0.log file says:
[2026-06-20 08:10:03] (EE) No devices detected.
[2026-06-20 08:10:03] no screens foundThe VM was installed with the same settings as the previous genuen ISO image: LVM and encryption, QEMU/KVM on virt-manager and integrated Intel graphics.
I tried installing the latest iso version (2026.06.20) to a QEMU .qcow2 VM image (no virt-manager) and I experienced a similar problem, tough in my case I didn't even get a login prompt, just a blinking cursor. The same happened after a couple of different install tries (text mode and expert). Booting the live image just gave me back another blinking cursor.
I still have a working genuen VM image installed from scratch using an iso from May 2026. I also have another one upgraded at the time from gnuinos-runit to genuen, which works remarkably well.
Something amiss with the iso image, I would guess.
First of all, thank you so much for the kind words, for opening this new thread, and for your valuable feedback on the latest genuen iso. Your testing is essential to making this release stable.
I have been investigating the "blinking cursor" issue ((EE) No devices detected / no screens found) in Qemu/KVM, and I wanted to share my findings and what I have ruled out so far.
What I have verified:
The bug is specific to the ISO environment: I have successfully upgraded older existing installations on physical machines with both UEFI and BIOS, and they boot and work perfectly. But, when booting the new live iso in Qemu and some physical machines, it indeed stalls at the blinking cursor right after loading the system services.
Technical details & What has been ruled out:
To isolate the issue, I have performed several tests on the live image configuration, ruling out the most obvious changes:
1) Not a Secure Boot / Kernel issue: I am aware that the custom genuen certificate (generated to bypass the MS-signed Debian certificate) has expired, and I haven't resigned the linux-libre kernel yet (as my initial Secure Boot attempts failed). However, this is 100% unrelated to this bug since Secure Boot is disabled in your VMs, the kernel boots perfectly, and services initialize normally before the crash. If it were a signature issue, UEFI would have blocked the boot way earlier.
2) Not a vdev or xlibre issue: I tried reverting vdev back to eudev, and swapping xlibre back to stock X11. The blinking cursor persisted. The issue does not stem from either of them.
3) Not the latest display tweaks: I tried completely removing the nouveau.modeset=1 kernel parameter and deleting a custom configuration file I added under /etc/X11/xorg.conf.d/. Surprisingly, the error remains. Most other recent changes are strictly constrained to vdev and libudev-compat on the one hand, and simple-netaid and avmix (formerly amixer-gtk) on the other hand (including their respective xfce-panel plugins).
4) List of Banned Packages Expansion: Another major change in this iso was tightening the package blacklist in Amprolla, strictly following the FSF's https://libreplanet.org/wiki/list_of_so … Guidelines. While I don't think this should break Xorg directly, it is something to keep in mind regarding potential underlying dependency drops.
Current status:
This is quite mysterious, as the underlying system seems to be completely functional, but Xorg fails to detect the emulated virtual screens in Qemu.
I am still digging deeper into the ISO build configuration to find out why the virtual graphic drivers are failing to load on this specific build. In the meantime, if anyone can try booting the live image with the nomodeset kernel parameter added to GRUB, please let me know if it allows you to bypass the cursor.
Thank you all for your patience and support. I will keep you updated!
Adding nomodeset to the kernel parameters at boot makes no difference when booting either the live image or the already installed image. It won't get past the blinking cursor.
I trialled the ISO and ran into two issues:
1 that xserver-xlibre-video-qxl wasn't installed (I had chosen qxl as emulated video card), and
2. that /etc/X11/xorg.conf.d/20-nouveau.conf was present and forced nouveau.
I moved away the latter and installed the former, and then it appeared to work.
Removing "/etc/X11/xorg.conf.d/20-nouveau.conf" did the trick.
Also solved here by removing /etc/X11/xorg.conf.d/20-nouveau.conf.
Thanks for looking into this!
Some fresh news about the 2026.07.17 ISO image: the live system is booting fine, but it looks like LVM is not working. I first tried installing on a VM with encryption (and LVM), then without encryption (but with LVM), but I was only able to get it up and running when installing without LVM. In the two other cases, I am getting a blinking cursor.
The non-LVM system is as fast and pleasant as usual.
I uploaded a new image after disabling udev synchronization and rules during LVM volume activation in the initramfs environment:
Ran vgscan and vgchange injecting custom inline LVM configuration: 'activation { udev_sync=0 udev_rules=0 }'
Forced manual block node creation using --mknodes
Added PREREQ="vdev" to vdev`s local-block/forcelvm script to force execution order
Added more kernel modules to `modules.d/vdev`: dm_snapshot, dm_mirror, ahci and nvme
The new script:
PREREQ="vdev"
prereqs()
echo "$PREREQ"
case $1 in
prereqs)
prereqs
exit 0
esac
. /scripts/functions
# This was necessary because LVM autodetect is completely broken.
if [ -x /usr/sbin/lvm ]; then
log_begin_msg "Activanting LVM with sysinit (vdev environment)..."
# Force LVM to scan the blocks using sysinit to populate its internal cache
/usr/sbin/lvm vgscan --mknodes --config "activation { udev_sync=0 udev_rules=0 }" >/dev/null 2>&1
# The status change will now work because the internal cache already recognises the drives
/usr/sbin/lvm vgchange --sysinit -ay --config "activation { udev_sync=0 udev_rules=0 }" >/dev/null 2>&1
log_end_msg
fiPlease, can you try again?
Thanks in advance ![]()
Thank you!
The new image gives the same results as the 2026.07.17 on a VM here: all is well without LVM, stubbornly blinking cursor with LVM. 🧐
It's working for me:
Same here after using a different storage volume - but only without encryption. 🤔
So I am currently getting:
LVM without encryption : now works.
LVM + encryption : blinking cursor.
Which is already some nice progress!
hola propero
una pregunta saldra la version de lxde de genuen?
Sí, en breve, de hecho he realizado varias mejoras tanto en libfm como en pcmanfm que voy a proponer en la lista de correo de lxde. Por ejemplo, he añadido un spinner a las acciones de udisks2 (al estilo Thunar) y también he movido el TabBar (donde se abren las pestañas) dentro del FileView porque antes en el "modo de panel doble" había un único TabBar común para ambos paneles donde se mezclaban pestañas de uno y otro panel, lo cual resultaba confuso. Ahora en cambio cada panel tiene su propio TabBar. Solo me queda configurar un poco el escritorio, y publico la iso.
Thank you! Full success here with the 2026.07.24 image. ![]()
This is again an amazingly snappy system, low on resources and fully fledged. The only addition I am currently making to the installed system is lxpolkit.
I added xfce-polkit to the iso image.
Thank you! This is now a perfect fit.
The lxde version also rocks out of the box. You have created the perfect dilemma for genuen users. ![]()
Pages: 1
