#1 2026-04-22 10:12:13
gfp
[SOLVED] GENUEN updating packages is disabled
Since approx. 8 weeks updating of Genuen/Gnuinos packages is disabled.
sudo apt update
sudo apt upgrade
does not work
Are there reasons for that?
Should we wait for the next version, which at the moment only for XFCE is available?
#2 2026-04-22 11:34:52
Re: [SOLVED] GENUEN updating packages is disabled
What does "does not work" mean? The repository tree seems fine...
#3 2026-04-22 19:15:24
prospero
I am currently able to update && upgrade genuen 6.0 Excalibur.
You may want to check your system time. If it is trailing, your system will see the InRelease file as a mirage from the future and refuse to trust it.
#4 2026-04-23 12:20:24
gfp
sudo apt update > update2.txt
in German:
E: Release-Datei für http://packages.gnuinos.org/merged/dist … /InRelease ist abgelaufen (ungültig seit 82 d 5 h 50 min 2 s). Aktualisierungen für dieses Depot werden nicht angewendet.
E: Release-Datei für http://packages.gnuinos.org/merged/dist … /InRelease ist abgelaufen (ungültig seit 82 d 5 h 50 min 3 s). Aktualisierungen für dieses Depot werden nicht angewendet.
in English:
E: Release file for http://packages.gnuinos.org/merged/dist … /InRelease expired (invalid since 82 d 5 h 50 min 2 s). Updates for this repository are not applied.
E: Release file for http://packages.gnuinos.org/merged/dist … /InRelease expired (invalid since 82 d 5 h 50 min 3 s). Updates for this repository are not applied.
What does that mean?
#5 2026-04-23 12:23:09
gfp
the time shown in the menu is OK. and for setting the time and equalize with the internet server I have to install NTP it said.
#6 2026-04-23 13:14:21
gfp
Should I replace the name: gnuinos
with
genuen
in  /etc/apt/sources.list   ?
would that help?
#7 2026-04-23 13:36:56
prospero
You should be using Excalibur.
See https://www.genuen.org.
#8 2026-04-25 10:12:45
gfp
How should I do this best?
I changed in /etc/apt/sources.list  from daedalus to excalibur
but
sudo apt update shows
Signation can´t be checked
missing public key.
Holen:1 http://packages.genuen.org/merged excalibur InRelease [3.630 B]
Holen:2 http://packages.genuen.org/merged excalibur-security InRelease [3.442 B]
Holen:3 http://packages.genuen.org/merged excalibur-updates InRelease [3.431 B]
Holen:4 https://repo.librewolf.net librewolf InRelease [5.649 B]
Fehl:1 http://packages.genuen.org/merged excalibur InRelease
  Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 72623EE3A542DC5B
Fehl:2 http://packages.genuen.org/merged excalibur-security InRelease
Get:4 https://repo.librewolf.net librewolf InRelease [5.649 B]
Missing:1 http://packages.genuen.org/merged excalibur InRelease
The following signatures could not be verified because their public key is not available: NO PUBKEY 72623EE3A542DC5B
Incorrect:2 http://packages.genuen.org/merged excalibur-security InRelease
Incorrect:3 http://packages.genuen.org/merged excalibur-updates InRelease
Package lists are read... Finished
W: GPG error: http://packages.genuen.org/merged excalibur InRelease: The following signatures could not be verified because their public key is not available: NO PUBKEY 72623EE3A542DC5B
Fehl:3 http://packages.genuen.org/merged excalibur-updates InRelease
Paketlisten werden gelesen… Fertig
W: GPG-Fehler: http://packages.genuen.org/merged excalibur InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 72623EE3A542DC5B
#9 2026-04-25 17:16:14
ilargi
Use a browser and go to: https://packages.genuen.org/genuen/pool … e-keyring/ Download "genuen-archive-keyring_2025.12.02_all.deb" to a local folder.
Now change to root and do:
dpkg -i /path/to/genuen-archive-keyring_2025.12.02_all.deb
to install a valid signature.
Finally do:
apt update
and
apt dist-upgrade
That should work (at least it did for me)
#10 2026-04-26 11:53:53
gfp
thanks very much
during installing that message came up:
* The base-files package cannot be installed because
* /bin is a directory, but should be a symbolic link.
* Please install the usrmerge package to convert this system to merged-/usr.
* For more information please read https://wiki.debian.org/UsrMerge.
I installed "usrmerge"
and run again:
sudo apt dist-upgrade
and then everything went fine.
Excalibur got installed.
But there are several problems.
e.g in KDE (I think it is X11) there are no  apps shown in the starter menu.
other problems I have not yet discovered.
at least  Genuen Excalibur got installed.
#11 2026-04-26 13:39:51
ilargi
Glad you got genuen with Excalibur up and running.
I haven't used KDE for ages and can't help you there. I run openbox + tint2 with obmenu-generator for my menus and it works fine.
#12 2026-04-26 22:50:45
There have been major updates to vdev, and it's highly recommended to install the latest version 1.3.93
I've updated the iso image as well:
https://www.genuen.org/mirror/excalibur
#13 2026-04-26 22:57:33
Hmmm... ilargi means moon in basque
#14 2026-04-27 14:24:05
gfp
installing vdev helped
now KDE X11 and wayland show all applications in the application menu.
thanks your your work
#15 2026-05-10 15:53:23
gfp
I reinstalled Genuen but
I can´t update anything.
I downloaded the
but can´t run
apt-update.
Release file for http://packages.genuen.org/merged/dists … /InRelease is expired (invalid since 3h 33min 5s). Updates for this repository will not be applied.
Even synaptic can´t be opened.
it is installed, but can´t be opened.
That´s why I can´t install
usrmerge
#16 2026-05-10 16:30:25
Please post full output from:
date (I suspect your system clock may be wrong).
uname -a
apt-update
And exactly what happens when you try to open synaptic?
#17 2026-05-10 16:52:34
I updated the repo
#18 2026-05-11 14:04:52
gfp
yes, the time is set incorrectly.
I tried to change that, but there is no option available.
There are no date and time settings in the settings menu.
Also clicking on the time there it shows grey, it means not accessible.
How can I change my time in XFCE?
here are my outputs:
date
Sun May 10 17:59:59 CEST 2026    (but today is Monday not Sunday and the time is also wrong for 2 hours.)
gfp@Tuxedo:~$ uname -a
Linux Tuxedo 6.12.60-amd64 #1 SMP PREEMPT_DYNAMIC Genuen 6.12.60-1 (2025-12-06) x86_64 GNU/Linux
gfp@Tuxedo:~$ apt-update
bash: apt-update: command not found
gfp@Tuxedo:~$ sudo apt-update
[sudo] password for gfp:
sudo: apt-update: command not found
gfp@Tuxedo:~$ sudo apt update
Get:1 http://packages.genuen.org/merged excalibur InRelease [3838 B]
Get:2 http://packages.genuen.org/merged excalibur-updates InRelease [2998 B]
Get:3 http://packages.genuen.org/merged excalibur-security InRelease [3009 B]
Error: Release file for http://packages.genuen.org/merged/dists … /InRelease is not valid yet (invalid for another 3h 50min 1s). Updates for this repository will not be applied.
#19 2026-05-11 16:33:42
I said to try apt-update because that's what you said in post 15. At least you realised what was wrong.
You can set the date with sudo date -s but read the man page for date first, You may find it easier to shut the system down, go into the BIOS and set the date there. Then run date after booting the system.
Once the system date is correct try apt update again. Hopefully it will then work.
#20 2026-05-11 19:03:19
There is a service sync-once in /etc/init.d that runs ntpdate the first time it detects a network connection. Anyway, you can run:
# hwclock --set --date "2026-05-11 21:01"
and
$ date --set "2026-05-11 21:01"
#21 2026-05-12 09:48:25
gfp
thanks
and
worked, I was able to set the time and I can update via terminal.
How can I reinstall "synaptic" because it does not open.
I tried:
gfp@Tuxedo:~$ sudo apt-get synaptic
E: Invalid operation synaptic
gfp@Tuxedo:~$ synaptic &
[1] 19785
gfp@Tuxedo:~$ bash: synaptic: command not found
[1]+  Exit 127                synaptic
It seems that it started somehow, but I can´t get it.
What is the correct name for it to install it again?
#22 2026-05-12 16:02:28
prospero
Synaptic is installed, but you need a polkit agent to prompt for password if you are starting it from the panel menu.
I have been using lxpolkit for that purpose, but you can also use any of the various scripts mentioned in the nearby gnuinos thread.
#23 2026-05-13 12:54:53
gfp
thanks
I even can´t start synaptic via terminal.
~$ synaptic
I installed lxplkit and rebooted my laptop, but there is still no way to open synaptic.
If I
run-program
synaptic
there is now an option: synaptic-pkexec
but still it can´t be launched.
after pressing "launch" nothing happens
#24 2026-05-13 19:06:44
prospero
You may need to modify the NotShowIn= line in/etc/xdg/autostart/lxpolkit.desktop so you can see the lxpolkit entry in Settings > Session and Startup > Application Autostart. It may not show in Xfce by default . You can either remove XFCE from the NotShowIn= line, or replace that line with OnlyShowIn=XFCE.
Note that running synaptic-pkexec also requires a polkit agent to prompt for password. You need to use sudo if you want to be prompted for a password in the terminal.
#25 2026-05-14 12:23:31
gfp
thanks very much
you seem to know very much...
it worked.
after removing
XFCE
from the
NotShowIn=
I can run synaptic with sudo from the terminal
