#1 2025-11-01 21:20:35
Qemu question
How can I change the below to make it faster?
It usually takes like 30+ seconds to boot up my system in a vm when I type in password. How can I make it closer to the speed of my native OS?
The below?
"qemu-img create -f qcow2 Unknown.qcow2 60G"
#The above is for making the image
qemu-system-x86_64 -m 4096 -cdrom Unknown.iso -boot d Unknown.qcow2 --enable-kvm
#the above is for installing the image on the qcow2 built
qemu-system-x86_64 --enable-kvm Unknown.qcow2 -cpu kvm64,+nx -m 4096 -device AC97
#the above is for loading the installed qcow2 image built anytime
 qemu-system-x86_64 --enable-kvm Unknown.qcow2 -cpu kvm64,+nx -m 4096 -device AC97 -hdb /dev/sdb
This one is for loading usb drives in the qcow2.
The above is how I tend to build my images, run them, etc...
I read that cpu/ smp can help, but I am curious how much.
EDIT: between apostrophes is the code.
Does the above help?
#2 2025-11-01 22:36:46
Re: Qemu question
if you were to use "code" tags around code, then where would they be?
(You should be able to edit your post if you would want to).
#3 2025-11-01 23:31:33
Re: Qemu question
@ralph its between apostrophes now.
I tried using -smp 4 instead of kvm,+nx
And the rest the same and that helped, but I wonder if it can be better than this.
#4 2025-11-02 00:17:57
Re: Qemu question
It's not that hard:
* start with an opening square bracket, the word code, a closing square bracket
* end with an opening square bracket, a slash, the word code, a closing square bracket
Or maybe you want it to be a bit peculiar?
#5 2025-11-02 00:29:45
Re: Qemu question
Or click on the [ code ] button in the list above the input window. Without the extra spaces, of course. They are needed here to make the function visible in text mode.
#6 2025-11-02 01:35:18
HardSun
Re: Qemu question
Might be the OS you are emulating.
Have a look at the gentoo wiki for help.
https://wiki.gentoo.org/wiki/QEMU/Options
#7 2025-11-02 13:26:10
pcalvert
Re: Qemu question
The poor performance of QEMU is why I switched to VirtualBox years ago, despite all the criticism of VirtualBox that I came across. Even though people were claiming that QEMU is faster than VirtualBox, in my experience it was the exact opposite.
I started using QEMU again about three years ago. Its performance still seems a bit slow, but it's acceptable for the Linux guest VMs that I've used it for. I wish I knew how to tweak it for better performance, though.
Another one is called Luxxle.
#8 2025-11-02 16:41:48
pcalvert
Re: Qemu question
Depending on what you're doing, you may want to consider using Distrobox.
Distrobox
https://distrobox.it/
See also:
Distrobox Secure
https://github.com/club-mate/distrobox-secure
#9 2025-11-02 19:26:25
Re: Qemu question
@pcalvert hmm...  perhaps... although I definitely saw a big improvement with changing kvm64,nx to max -smp 4.
The speed more than doubled when I did that at least.
As for virtualbox, I don't trust that software at all.
Virt-manager is closer to trustworthy, but meh...
@golinux I added the brackets
