#1 2022-07-18 19:43:24
nobodyuknow
[SOLVED] When will 5.13 kernel be available?
Is there an estimate for when 5.13 kernel will be available in Devuan packages?
#2 2022-07-19 00:47:26
Re: [SOLVED] When will 5.13 kernel be available?
I'm using 5.18 from bpo (backports)
linux-image-5.18.0-0.bpo.1-amd64-unsigned_5.18.2-1~bpo11+1_amd64.deb
#3 2022-07-19 12:12:53
That kernel version will never be available for the current stable release. The kernel only gets backported security & bug fixes after the release, no (major) version bumps are provided.
#4 2022-07-19 23:56:50
nobodyuknow
@GlennW
Thanks for that. I've never used Debian backports. I guess I just add "deb http://deb.debian.org/debian bullseye-backports main" to sources.list.
@Head_on_a_Stick
So the philosophy for Devuan (and Debian, I assume) is to release one kernel with the original release? That explains why the only available kernel is 5.10.
#5 2022-07-20 00:21:56
nobodyuknow wrote:
@GlennW
It is never a good idea to use Debian repositories directly. All "safe" Debian packages are available through the Devuan repositories at  deb.devuan.org. You might want to have a look at this page.
#6 2022-07-20 01:22:02
just chimaera-backports...
deb http://deb.devuan.org/merged/ chimaera-backports main non-free contrib
Beowulf
deb http://deb.devuan.org/merged/ beowulf-backports main non-free contrib
I remember when odd-numbered kernel versions were unstable.
#7 2022-07-21 18:30:39
nobodyuknow
@golinux and GlennW
Thanks for the warning, as I was already looking at Debian packages.
I looked at the link, and the packages (https://pkginfo.devuan.org/), but my eyes glazed over at all of the rt, dbg, cloud, etc., images and headers. I'll have more tea and look again.
#8 2022-07-21 19:24:48
Only install the linux-image-amd64 package. It always depends on the latest version.
