#1 2022-06-21 20:05:40
deepforest
how on Devuan analyze boot time?
smile
#2 2022-06-22 04:40:16
Re: how on Devuan analyze boot time?
#3 2022-06-22 20:12:44
deepforest
smile
#4 2022-06-23 19:30:57
xinomilo
Unknown
bootlogd or bootchart? never really bothered with that tbh.
there's also systemd-bootchart, not sure if it's dependent on systemd, if not, maybe it can be used in devuan too.
#5 2022-06-26 16:23:59
deepforest
thx, how to use them?
smile
#6 2022-06-26 17:31:10
Links to the .debs are in my exclamation mark (see fsmithred's post just above mine for bootlogd), along with an explanation of how to get bootchart working in chimaera.
#7 2022-06-26 18:27:44
deepforest
And where is your exclamation mark?
smile
#8 2022-06-26 18:29:57
deepforest
root@devuan:/etc# apt install bootchart
E: Unable to locate package bootchart
root@devuan:/etc#
smile
#9 2022-06-26 18:49:44
https://dev1galaxy.org/viewtopic.php?pid=36356#p36356
#10 2022-06-26 19:01:39
deepforest
freeartist@devuan:~/Downloads/bootchart$ ./pybootchartgui.py
bash: ./pybootchartgui.py: /usr/bin/python: bad interpreter: No such file or directory
smile
#11 2022-06-26 19:07:02
deepforest
freeartist@devuan:/usr/bin$ sudo ln -fs python3 python
/home/freeartist/Downloads/bootchart/pybootchartgui/parsing.py:101: SyntaxWarning: "is" with a literal. Did you mean "=="?
  if pid is 0:
/home/freeartist/Downloads/bootchart/pybootchartgui/draw.py:511: SyntaxWarning: "is not" with a literal. Did you mean "!="?
  if (OPTIONS.show_pid or OPTIONS.show_all) and ipid is not 0:
/home/freeartist/Downloads/bootchart/pybootchartgui/draw.py:609: SyntaxWarning: "is not" with a literal. Did you mean "!="?
  if i is not 0:
No path given, trying /var/log/bootchart.tgz
warning: path '/var/log/bootchart.tgz' does not exist, ignoring.
Parse error: empty state: '/var/log/bootchart.tgz' does not contain a valid bootchart
smile
#12 2022-06-26 19:36:56
deepforest
root@devuan:/home/freeartist/Downloads# dpkg -i bootchart2_0.14.4-3+b1_amd64.deb
Selecting previously unselected package bootchart2.
(Reading database ... 461869 files and directories currently installed.)
Preparing to unpack bootchart2_0.14.4-3+b1_amd64.deb ...
Unpacking bootchart2 (0.14.4-3+b1) ...
Setting up bootchart2 (0.14.4-3+b1) ...
update-rc.d: warning: start and stop actions are no longer supported; falling back to defaults
update-rc.d: warning: stop runlevel arguments (6 0) do not match bootchart-done Default-Stop values (none)
Processing triggers for man-db (2.10.2-1) ...
freeartist@devuan:/var/log$
freeartist@devuan:~/Downloads$ bootchart2
bash: bootchart2: command not found
smile
#13 2022-06-27 17:20:26
It would have been *much* better to change the shebang in pybootchartgui.py instead of mangling your system. Remove that symlink.
So I presume you didn't boot with the required initcall_debug printk.time=y init=/sbin/bootchartd kernel parameters then?
This is like pulling teeth... roll
#14 2022-06-29 10:49:46
deepforest
I see now
but
freeartist@devuan:/var/log$ bootchart /var/log/bootchart.tgz
bash: bootchart: command not found
freeartist@devuan:/var/log$ bootchart2 /var/log/bootchart.tgz
smile
#15 2022-06-29 10:53:01
sed -i 's|#!/usr/bin/python|&3|' pybootchartgui.py
./pybootchartgui.py
EDIT: monkey patching ftw! big_smile
#16 2022-06-29 10:58:55
deepforest
./pybootchartgui.py
Wow! Thanks! Its magic! What is trick?
https://i.imgur.com/ynv1HKU.png
ps understood python>python3 in pybootchartgui.py
smile
#17 2022-06-29 11:02:38
Glad you got it working.
#18 2022-06-29 11:03:51
deepforest
Thanks! And how analyze that? I see hdd is bottleneck?
smile
#19 2022-06-29 11:05:30
Looks like eudev takes forever. Do you have many devices connected?
You could try udev instead but that's from the systemd crowd so people might throw rotten fruit at you.
#20 2022-06-29 11:14:06
deepforest
Yes, thx. i see long udevd.
usb mouse and usb hub, 2 sata hdd, nothing else
Noo, i am here because sysvinit
smile
#21 2022-06-30 06:14:59
xinomilo
Unknown
try removing devices one by one (i'd start with usb hub) and rebooting. see if/what device makes a difference.
if not, check boot messages... is "Waiting for /dev to be fully populated" step that is taking too long? (cause there are lots of eudev/init script issues around that one iirc.)
#22 2022-06-30 15:05:20
Also perhaps check with a live ISO that boots with systemd to see how udev handles the devices.
Is there actually much delay when starting the desktop? It could be that the eudev stuff is done in the background after a working desktop is reached. I've seen that before with systemd-analyze output.
#23 2022-07-04 23:20:38
deepforest
Ok, i will look exactly. I have at dual boot Arch and Fedora, all systems booting about same time.
smile
#24 2022-07-05 08:57:57
deepforest
@Head_on_a_Stick
Hello) Here svg logs from Arch and Fedora36
https://svgshare.com/i/irR.svg
https://svgshare.com/i/iqo.svg
smile
