#1 2022-05-03 00:45:27
nhgbnkjdfjmhbg
how to install linux biowulf
what settings should be written in the command line
#2 2022-05-03 00:59:35
Re: how to install linux biowulf
Detailed instructions on this page.
#3 2022-05-03 01:29:35
nhgbnkjdfjmhbg
all these instructions do not correspond to my installation through the command line
#4 2022-05-03 02:37:25
Usually "install linux beowulf" would mean to use an installer ISO which then kicks in already on the boot-up of the machine.
Presumably you think of doing something else and you may then need to explain in some more detail what you mean.
In particular "installation through the command line" implies you are running an OS. which?
#5 2022-05-03 05:54:00
MiyoLinux
Are you wanting to debootstrap?
I supplied a live .iso that used debootstrap to install beowulf. It still should work.
https://sourceforge.net/projects/miyoli … bootstrap/
However, I only supplied BIOS versions for 64 and 32 bit computers.
Edit: or you can download the newer Deboot-Ceres, and just change ceres to beowulf in the debootstrap command.
https://sourceforge.net/projects/miyoli … oot-Ceres/
#6 2022-05-03 06:00:02
MiyoLinux
Debootstrap: install Devuan the Arch way.
...or is it? ...
Install Arch the Devuan way!
LOLOLOLOLOL!
#7 2022-05-04 13:16:18
MiyoLinux
Well okay then...
#8 2022-05-04 16:15:44
Have a look at this thread: https://dev1galaxy.org/viewtopic.php?id=4919 if you want to install the Arch way.
Or do you just want to install a basic system without graphical interface? That can be done with every installer. When you are asked what to install just select basic system utilities, and you end up with a system that just can be operated via cli.
