#1 2022-02-08 06:38:46
SpongeBOB
[SOLVED] Error with apt update
Hi everyone,
I installed Devuan (devuan_chimaera_4.0.0_amd64_desktop.iso) I need to run few apt install
after an apt update I got
root@DevUlVM:/home/virtua# apt update
Ign:l cdrom://[Devuan GNU/Linux 4.0 chimaera amd64 - desktop 20211012] chimaera InRetease
Err:2 cdrom://[Devuan GNU/Linux 4.0 chimaera amd64 - desktop 20211012] chimaera Release Please use apt-cdrom to make this CD-ROM recognized by APT. apt-get update cannot be us ed to add new CD-ROMs
Get:3 http://pkgmaster.devuan.org/merged chimaera-security InRelease [21.5 kB]
E: The repository 'cdrom://[Devuan GNU/Linux 4.0 chimaera amd64 - desktop 20211012] chimaera Release' does not have a Release file.
E: Release file for http://pkgmaster.devuan.org/merged/dists/chimaera-security/InRelease is not valid yet (invalid for another 21h 32min 45s). Updates for this repository will no t be applied.
root@DevUlVM:/home/virtua# |
so some error here..
I updated my etc/apt/sources.list to as https://www.devuan.org/os/packages
deb http://deb.devuan.org/merged chimaera          main
deb http://deb.devuan.org/merged chimaera-updates  main
deb http://deb.devuan.org/merged chimaera-security main
but that still give me error's
root@DevlllVM:/home/virtua# apt update
Ign:l http://deb.devuan.org/merged chimera InRelease
Ign:2 http://deb.devuan.org/merged chimera-updates InRelease
Ign:3 http://deb.devuan.org/merged chimera-security InRelease
Err:4 http://deb.devuan.org/merged chimera Release
404 Not Found [IP: 185.38.15.81 80]
Err:5 http://deb.devuan.org/merged chimera-updates Release
Err:6 http://deb.devuan.org/merged chimera-security Release 404 Not Found [IP: 185.38.15.81 80]
E: The repository 'http://deb.devuan.org/merged chimera Release' does not have a Release file.
hb: Updating from such a repository can't be done securely, and is therefore disabled by default.
E: The repository 'http://deb.devuan.org/merged chimera-updates Release' does not have a Release file.
E: The repository 'http://deb.devuan.org/merged chimera-security Release' does not have a Release file.
root@DevU!VM:/home/virtua#
any ideas ?
Thanks.
#2 2022-02-08 07:37:23
Re: [SOLVED] Error with apt update
SpongeBOB wrote:
Hi everyone,
any ideas ?
It looks like there is a typo.  It should be chimaera not chimera.
Also . . . would be nice if you could actually post the code using the code tags rather than posting off-site images.
Thanks.
And looks like you might have a clock issue and need to comment  the CDROM line in sources.list
#3 2022-02-08 20:02:41
SpongeBOB
Thanks @golinux sorry to have posted as image instead of text. But I couldn't due to this very problem.
This Devuan is a VM and until I fix my apt problem I can't copy/past or transfer data to my VM host hmm
You were right al of those error where coming because my time was wrong. now it's work like a charm smile
(tomorrow I will swap those picture to text)
#4 2022-02-09 05:28:41
SpongeBOB
Done, I swapped the image for text. (done by OCR, so I hope there is no mistake)
Cheers.
#5 2022-02-09 05:32:18
Much appreciated.  Thanks!
