#1 2018-05-13 11:26:28
rsevero
Several bash completions unavailable
I noticed that several bash completions weren't available, Like apt for example.
After I included the following line at the end of /usr/share/bash-completion/bash_completion I got all missing bash completions:
. /usr/share/bash-completion/completions/*
Why isn't this directory being sourced automatically?
#2 2018-05-13 15:46:57
Re: Several bash completions unavailable
Does that happen on Debian also?  I assume so since we pull it directly from their repos.   Please file a bug upstream if there isn't one already.
#3 2018-05-14 13:17:37
rsevero
I'm not sure as I have never used debian but I will look for a bug and fill a new one if necessary.
Thanks!
#4 2018-05-14 13:22:14
KatolaZ
Sorry if this sounds silly, but please consider that /etc/bash_completion is *not* included by default in your bashrc/profile. So in order for the completions to work you have to explicitly source /etc/bash_completion in your bashrc/profile.
My2Cents
#5 2018-05-14 13:28:33
rsevero
That could definitely be the problem but I already uncommented the lines that source /usr/share/bash-completion/bash_completion in my profile.
After that I had to also include
at the end of /usr/share/bash-completion/bash_completion to get several bash completions to work.
For example, apt package names bash completion only worked after that. Are apt package names bash completion working for you?
#6 2018-05-14 13:38:28
KatolaZ
I have always sourced only "/etc/bash_completion" (which, BTW, sources /usr/share/bash-completion/bash_completion, which in turns loads all the completions under /usr/share/bash-completion/completions/ ...) and I don't use apt :-)
#7 2018-05-14 13:43:19
rsevero
AFAICT the problem is exactly that /usr/share/bash-completion/bash_completion doesn't source /usr/share/bash-completion/completions
I had to manually include
in /usr/share/bash-completion/bash_completion to get /usr/share/bash-completion/completions completions.
#8 2018-05-14 15:33:43
My2Cents
I have never touched my bash profile and bash_completion has always worked.  Maybe that's an Xfce thing?
