#1 2022-02-18 21:17:35
jacksprat
[SOLVED] Where did obmenu go?
I [think I] remember using the Openbox menu tool "obmenu" in earlier versions of Devuan, but the default 4.0 install doesn't have it.  Is it discontinued, hidden?  If the former, is its function replaced by anything?  Thanks.
#2 2022-02-18 21:52:43
Re: [SOLVED] Where did obmenu go?
jacksprat wrote:
discontinued
^ This: https://pkginfo.devuan.org/cgi-bin/poli … u&x=submit
There's https://github.com/keithbowes/obmenu but it isn't packaged for Devuan. It should be fairly simple to do that with debmake(1) though. See also https://www.debian.org/doc/manuals/debmake-doc/
#3 2022-02-18 22:12:13
jacksprat
Thanks, I will try adding into /etc/apt, though I am not sure about mixing different releases.  My backup is to modify ~/.config/openbox/menu.xml .  I must be alone in using Openbox as my DE.
#4 2022-02-18 23:28:41
IIRC MiyoLinux has some nice menus for openbox.  Check in Devuan Derivatives.
#5 2022-02-19 08:39:49
There is obmenu-generator, I provide the .deb packages linked from the GitHub page:
https://github.com/trizen/obmenu-genera … INSTALL.md
Be sure to either add the repository or install both the perl-linux-desktopfiles and the actual obmenu-generator packages. I do not recommend manually installing the linux-desktopfiles perl modules with cpan although many random interweb "guides" will suggest it.
#6 2022-02-19 10:55:34
jacksprat
Thanks for your help, but I decided to just copy over the obmenu generated .xml files from my Void computer to ~/.config/openbox;  I will comeback to your suggestions for obconf alternatives if I get bored writing xml.
#7 2022-03-20 21:39:57
zephyr
Very good question, have been using obmenu2, doesn't work well doing a build with live-build, it just breaks. Found obmenu3 on sourceforge with a whole different gui. Working with it now, will let those interested how it goes with a build.
For me, too old school for a obmenu-generator, like configuring my own menus! Don't like icons everywhere either.
https://sourceforge.net/projects/obmenu3/files/
https://github.com/0x10/obmenu2
Don't forget to add a  3 on the obmenu, menu.xml!
Screenie smile
Fluxbox with fluxmenu also MIA, lot easier to edit the menu by hand!
zephyr
CROWZ
#8 2022-03-21 01:50:46
vlax
nope, you're not alone: I use Openbox for many years now and I love it
satellite mestizo
#9 2022-03-21 10:03:09
xinomilo
Unknown
you're not alone.
#10 2022-03-21 21:21:33
thierrybo
obmenu-generator is very customizable. If you don't want any icons, just remove "-i" from "execute" part in menu.xml:
<?xml version="1.0" encoding="utf-8"?>
<openbox_menu xmlns="http://openbox.org/"
 xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
  xsi:schemaLocation="http://openbox.org/">
    <menu id="root-menu" label="obmenu-generator" execute="/home/thierrybo/Sys/GIT.local.repositories/obmenu-generator/obmenu-generator -i" />
</openbox_menu>
And you also have to customize your menu layout in schema.pl. The only thing that is automatically updated is desktop files inside freedesktop categories. But even theses categories are "manual entries":
    #          NAME            LABEL                ICON
    # Deux lignes du dessous ajoutées mais Debian menu plante, mais inclut dans lxde
    #{pipe => ['/usr/bin/openbox-menu -i debian-menu.menu', 'openbox-menu debian-menu.menu', 'applications-system']},
    {pipe => ['/usr/bin/openbox-menu lxde-applications.menu', 'ob-menu lxde-app.menu', 'applications-system']},
    {cat => ['utility',     'Accessoires', 'applications-utilities']},
    {cat => ['development', 'Développement', 'applications-development']},
    {cat => ['XAMPP', 'Développement XAMPP', 'applications-development']},
    {cat => ['education',   'Education',   'applications-science']},
    {cat => ['game',        'Jeux',       'applications-games']},
    {cat => ['graphics',    'Graphisme',    'applications-graphics']},
    {cat => ['audiovideo',  'Multimedia',  'applications-multimedia']},
    {cat => ['network',     'Internet',     'applications-internet']},
    {cat => ['office',      'Bureautique',      'applications-office']},
    {cat => ['other',       'Autres',       'applications-other']},
    {cat => ['settings',    'Réglages',    'applications-accessories']},
    {cat => ['system',      'Système',      'applications-system']},
but before this block I have this:
	# Ajouté nom distribution
    {sep => "Devuan"},
    #          COMMAND                 LABEL              ICON
#    {item => ['xdg-open .',       'File Manager', 'system-file-manager']},
    {item => ['bl-file-manager',       'Gestionnaire de fichiers', 'system-file-manager']},
    {item => ['x-terminal-emulator',            'Terminal',     'utilities-terminal']},
    {item => ['x-www-browser', 'Navigateur Web',  'web-browser']},
    {item => ['thunderbird', 'Courriel',  'emblem-mail']},
    {item => ["$editor", 'Editeur texte',  'text-editor']},
    {item => ['wine "C:\Program Files\Tracker Software\PDF Viewer\PDFXCview.exe"', 'Lecteur Pdf',  'C055_PDFXCview.0']},
#    {item => ['/home/thierrybo/.local/opt/foxitsoftware/foxitreader/FoxitReader.sh', 'Lecteur Pdf',  'FoxitReader']},
    {item => ['keepassxc', 'KeepassXC',  'keepassxc']},
#    {item => ['~/.local/opt/KeePassXC.AppImage', 'KeepassXC',  'keepassxc']},
#    {item => ['gtk-launch appimagekit-org.keepassxc.KeePassXC.desktop', 'KeepassXC',  'keepassxc']},
    {item => ['~/.config/conky/conky-startup.sh', 'Conky',  '']},
    {item => ['gmrun',            'Exécuter',  'system-run']},
    {sep => 'Catégories'},
and after i have this:
    {sep => 'Mes pipemenus'},
    {pipe => ['~/.config/openbox/menu/cbpp-places-pipemenu', 'Dossier personnel', '']},
    {pipe => ['~/.config/openbox/menu/obrecent.sh', 'Fichiers récents', '']},
#    {pipe => ['~/.config/openbox/menu/obrecent-test_pipemenu', 'Fichiers récents test', '']},
#    {pipe => ['~/.config/openbox/menu/openbox_wiki__Pipemenus__obrecent.sh', 'Fichiers récents Wiki', '']},
    {sep => undef},
    {pipe => ['~/.config/openbox/menu/help-pipemenu', 'Aide et ressources', '']},
    {pipe => ['~/.config/openbox/menu/bl-kb-pipemenu', 'Raccourcis clavier', '']},
    {sep => undef},
    {pipe => ['~/.config/openbox/menu/openvpn-pipemenu', 'OpenVPN', '']},
    {pipe => ['~/.config/openbox/menu/scrot-pipemenu', 'Scrot', '']},
    {pipe => ['~/.config/openbox/menu/bash-pipemenu', 'Bash', '']},
    {pipe => ['~/.config/openbox/menu/ffmpeg-pipemenu', 'Ffmpeg', '']},
test
There is a special bonus :-) I you also use jgmenu, a graphical dmenu tool, it can integrate automatically obmenu generated menu.
#11 2022-04-02 07:36:16
zephyr
thierrybo wrote: obmenu-generator is very customizable. If you don't want any icons, just remove "-i" from "execute" part in menu.xml:
Thank you for your suggestion, plus sorry I'm late getting back with you! I have tried jgmenu and like it, BL uses it and it's an enhancement for me which I like.
Appreciate your time and effort for the configuration script for ob-generator, will take a shot at it! smile
Thanks again! cheers
zephyr
CROWZ
#12 2022-04-17 16:43:40
czeekaj
yikes. I'll miss it but looks like there are already drop in replacements.
Am I missing something or is chimaera recently had obmenu added again? I never noticed it going missing.
#13 2022-05-25 15:28:59
Dev1User
I also miss obmenu. Unfortunately, there isn't really an alternative in Devuan's packages. In the virtual machine I looked at jgmenu under Artix. At first glance, quite okay, but it is not as simple as obmenu. I will continue to use my XML file and modify it as needed and wait until a decent replacement comes along.
#14 2022-05-25 19:23:02
MiyoLinux
I'm on my phone...waiting in line to pick up my son from school.  So, I can't test this as to whether it would work or not...
I probably shouldn't even say anything since I can't test it... tongue
I don't know if the dependencies are still available, but you could try downloading the. deb file to see if it will install... wink
https://packages.debian.org/buster/obmenu
#15 2022-05-25 21:03:18
alexkemp
I am unsure how different this may be, but YAD is available:-
$ apt search yad
yad/stable,now 0.40.0-1 amd64 [installed]
  tool for creating graphical dialogs from shell scripts
Command-line only, works very well in my experience.
#16 2022-05-26 20:18:18
MiyoLinux
...and I shouldn't have said anything. I just tried it on chimaera, and it didn't work due to a missing dependency --> python-glade2.
I use obmenu-generator and/or jgmenu on Openbox. Sorry for the interruption. I'll bow out of the discussion now... tongue
#17 2022-05-30 16:59:37
Dev1User
I have now taken a closer look at jgmenu. It seems to work fine. I installed jgmenu from Daedalus packages on Chimaera. After a few tries, I managed to get it to look good by my standards. Actually I wanted to make it even better, but somehow it didn't quite work out yet. In that area obmenu was already much easier.
I have a submenu, but how can I actually make another submenu from the submenu?
I used now the old XML obmenu file parallel with jgmenu. Jgmenu is anchored in the Tint2 bar. What else I noticed is that jgmenu can also read the XML file without any problem and can also display it just like obmenu. I like that jgmenu has a search function integrated. That is already very practical. I have set it so that jgmenu uses the same optics settings of obconf and tint2.
Ah good to know that it no longer works.
#18 2022-05-30 17:41:18
xinomilo
Unknown
there's also rofi, dmenu replacement (amongst other things.)
https://tracker.debian.org/pkg/rofi
#19 2022-05-31 12:12:07
I've been following this thread as I have a parallel Devuan Beowulf setup on another drive which I keep up to date.
It is a practise bed for when I finally leave Xfce behind and go to a 100% Openbox setup.
I'd like to recover the best part of my old #! Waldorf installation.
xinomilo wrote:
there's also rofi, dmenu replacement ...
Seems that this app (just from reading about it) suffers from what I have seen in many other applications: feature creep.
Why can't things go back to the tried and true do one thing and do it well and just not complicate things?
I like how obmenu works and not getting it in chimaera is yet another reason to keep using beowulf with a backported kernel.
slim and wicd my other ones.
Of course, YMMV.
#20 2022-07-22 21:38:59
Recently I developed a dynamic cache for xmenu called xmenu-cache. It monitors /usr/share/applications keeping the content of xmenu up-to-date. The local directory /usr/local/share/applications should be added to the watching directories of inotify as well, but this directory is used only in some exotic cases, so I decided to leave the program as simple as possible so far. I included a built-in *.svg -> *.png conversor, because icons in .svg format weren't displayed by xmenu. You can test the menu running the new images of gnuinos-openbox (chimaera):
https://www.gnuinos.org/mirror/chimaera/live/
Alternatively, you can also install both xmenu and xmenu-cache from the package mirror in your current system:
http://packages.gnuinos.org/gnuinos/pool/main/x/xmenu/
http://packages.gnuinos.org/gnuinos/poo … enu-cache/
Once you have installed the packages, you need to follow the steps below:
  • Add a new line xmenu-cache & to your ~/.config/openbox/autostart in order to start the monitoring tool
  • Replace the default menu of openbox with xmenu.sh in your ~/.config/openbox/rc.xml
  • If you want to customize the static part of the menu (header plus footer), copy the content of /etc/default/xmenurc to ~/.xmenurc and modify the key-value pairs to suit your needs better. By default:
#===== Configuration file for xmenu-cache =====
ApplicationLauncher = gmrun
TerminalEmulator = sakura
FileManager = spacefm
TextEditor = geany
WebBrowser = icecat
Logout = logout
Bear in mind that this is a work in progress, and it has nothing to do with my previous popupmenu in Gtk. It's faster and requires X11 instead, and neither does it depend on libmenu-cache. Only on lxmenu-data, because it requires some .desktop files in /usr/share/desktop-directories to classify the applications by categories.
Here you are a screenshot:
FluxBB bbcode test
#21 2022-07-23 08:32:19
I' ve fixed a bug when running execv in xmenu-cache.c, and I'm rebuilding the iso images of gnuinos openbox.
#22 2022-07-23 16:46:49
Done. I've built the images mirroring from deb.devuan.org without issues:
Now you can give a try to the xmenu downloading the ob images.
#23 2022-07-23 16:53:07
I forgot: xmenu-cacherc has been renamed to xmenurc, and I did change it in my previous posts.
#24 2022-12-29 00:44:43
MiyoLinux
As an Openbox fanboi tongue , I recently tried out Crunchbang ++...for the second time.
After playing around with it for a while, I took a dive into the "GUI Menu Editor"...I'm not sure how I didn't notice this before.
The developer of #!++ has repackaged obmenu to work on newer systems using python3. Not only that, but he also incorporated (into obmenu) the ability to add icons to the Openbox menu (if desired). yikes big_smile
I downloaded the .deb file from my installation of #!++, and I've installed it on Chimaera, Daedalus, and Ceres...it works perfectly on all of them! wink
This may be what the OP was looking for???
#25 2022-12-29 12:04:43
#!++ uses obmenu2, their debian directory is here. It's all MIT licensed so you don't need to ask Ben for permission. I'm sure he would grant it though.
