#1 2020-06-25 19:23:48
mtbvfr
Errors encountered processing: libgstreamer-gl1.0-0_1.14.4-2_amd64.deb
Hi Folks,
The errors occurred when upgrading from Ascii 2.1 to Beowulf with Synaptic using the "Add downloaded packages" feature.
I have made backup copies of 3 log files of which none indicate what the errors were.
Is there somewhere else I can look for a detailed description of the errors?
The 3 log files are the following. All of these are in the /var/log/apt directory.
eipp.log.xz
history.log
term.log
At the bottom of the term.log file was the following.
/tmp/apt-dpkg-install-QwO4dY/011-libgstreamer-gl1.0-0_1.14.4-2_amd64.deb
Log ended: 2020-06-25  12:14:42
At the bottom of the history.log file are the records for the attempted upgrade with the initial 3 lines as follows with the "xxxxxx" representing my User Account.
Start-Date: 2020-06-25  11:56:40
Commandline: /usr/sbin/synaptic
Requested-By: xxxxxx (1000)
On the "Install:" line is "libgstreamer-gl1.0-0:amd64 (1.14.4-2, automatic)"
The last 2 lines of the history.log file are as follows.
Error: Sub-process /usr/bin/dpkg returned an error code (1)
End-Date: 2020-06-25  12:14:42
In the eipp.log file, "libgstreamer-gl1.0-0:amd64" is listed on Line 5 which is labelled by "Install:".
Request: EIPP 0.1
Architecture: amd64
Architectures: amd64
Remove: various packages listed here
Install: libgstreamer-gl1.0-0:amd64 is listed on this Line
Planner: internal
Further down the file it is detailed as the following.
Package: libgstreamer-gl1.0-0
Architecture: amd64
Version: 1.14.4-2
APT-ID: 22581
Multi-Arch: same
Depends: libc6 (>= 2.14), libdrm2 (>= 2.4.17), libegl1, libgbm1 (>= 8.1~0), libgl1, libglib2.0-0 (>= 2.40), libgstreamer-plugins-base1.0-0 (>= 1.8.0), libgstreamer1.0-0 (>= 1.14.4), libgudev-1.0-0 (>= 165), libwayland-client0 (>= 1.9.91), libwayland-egl1 (>= 1.15.0), libx11-6, libx11-xcb1, libxcb1
Breaks: libgstreamer-plugins-bad1.0-0 (<< 1.13.1)
Thanks!!, MTB.
#2 2020-06-26 19:26:58
mtbvfr
Re: Errors encountered processing: libgstreamer-gl1.0-0_1.14.4-2_amd64.deb
Hi Folks,
I have some more info which I hope helps to solve this issue.
After Fixing some Broken Packages in Synaptic and starting the "Add downloaded packages" feature again, I still encountered problems with the same package as before. However, there is a little more detail in the term.log file this time as appears next.
Log started: 2020-06-25  23:53:10
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 432358 files and directories currently installed.)
Preparing to unpack .../libgstreamer-gl1.0-0_1.14.4-2_amd64.deb ...
Unpacking libgstreamer-gl1.0-0:amd64 (1.14.4-2) ...
dpkg: error processing archive /var/cache/apt/archives/libgstreamer-gl1.0-0_1.14.4-2_amd64.deb (--unpack):
 trying to overwrite '/usr/lib/x86_64-linux-gnu/libgstgl-1.0.so.0', which is also in package libgstreamer-plugins-bad1.0-0:amd64 1:1.10.4-dmo2
Preparing to unpack .../gstreamer1.0-gl_1.14.4-2_amd64.deb ...
Unpacking gstreamer1.0-gl:amd64 (1.14.4-2) ...
dpkg: error processing archive /var/cache/apt/archives/gstreamer1.0-gl_1.14.4-2_amd64.deb (--unpack):
 trying to overwrite '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstopengl.so', which is also in package gstreamer1.0-plugins-bad:amd64 1:1.10.4-dmo2
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
Log ended: 2020-06-25  23:53:12
The Desktop is now partly broken and a dialogue window appears with the following text below which appear 2 buttons (Execute and Remove).
Plugin "PulseAudio Plugin" unexpectedly left the panel, do you wish to restart it?
If you press Execute the panel will try to restart the plugin otherwise it will be permanently removed from the panel.
Thanks, MTB.
#3 2020-06-26 21:23:37
I have a couple of ideas, but nothing certain.
Maybe you could remove libgstreamer-plugins-bad1.0-0 and eliminate the conflict. Two packages should not provide the same file. Maybe the newer version doesn't have the conflicting file.
You really should remove deb-multimedia from your sources. Look in /etc/apt/sources.list, look for any files in /etc/apt/sources.list.d/ and also wherever synaptic stores its sources. That alone might fix the upgrade problem, or maybe you have a bunch of other packages from dmo that might cause problems.
dpkg -l |grep dmowill give you a list of files with dmo in the name or the version. The ones with dmo in the version are from deb-multimedia. See how many you have.
How old is this system? Was it upgraded from jessie? From a jessie beta?
#4 2020-06-27 04:43:44
mtbvfr
Hi fsmithred,
My first Devuan install was Ascii 2.0 from Live ISO.
If I recall correctly, I added the deb-multimedia repository for some DVD Authoring packages in my quest for something that could produce smooth text for subtitle tracks. As you will see below, it looks like I installed some other packages form that repository also.
I have the following files in the /etc/apt/sources.list.d directory.
connectify.list
(will uninstall/remove the related packages of the the above because
  the VPN didn't work for me and then delete this file)
devuan.list
(every line in the above is disabled, can I remove it?)
jami.list
riot-im.list
windscribe-repo.list
As far as I am aware, and can see, Synaptic stores its sources in the "sources.list' file but also references the files in the "/etc/apt/sources.list.d" directory.
Contained in the "/var/lib/apt/lists" directory are the following files related to deb-multimedia.org.
www.deb-multimedia.org_dists_stretch_InRelease
www.deb-multimedia.org_dists_stretch_main_binary-amd64_Packages
www.deb-multimedia.org_dists_stretch_main_i18n_Translation-en
www.deb-multimedia.org_dists_stretch_non-free_binary-amd64_Packages
www.deb-multimedia.org_dists_stretch_non-free_i18n_Translation-en
The command grep ^Package www.deb-multimedia*_Packages | awk '{print $2}' | sort -u issued with that directory being active produces a list of 633 packages. I will list them later if you think it's necessary.
The following page gave me the idea for the grep command.
How To List All Packages In A Repository On Ubuntu, Debian Or Linux Mint [APT]
ls |grep dmo in the "/var/cache/apt/archives" directory produces the following list of 120 files.
aegisub_1%3a3.2.2+dfsg-dmo4_amd64.deb
aegisub-l10n_1%3a3.2.2+dfsg-dmo4_all.deb
audacity_1%3a2.1.3-dmo1+deb9u1_amd64.deb
audacity-data_1%3a2.1.3-dmo1+deb9u1_all.deb
bdsup2sub_4.0.0-dmo1_all.deb
bombono-dvd_1%3a1.2.2-dmo13_amd64.deb
bombono-dvd-data_1%3a1.2.2-dmo13_all.deb
devede_1%3a4.8.8-dmo1_all.deb
faac_1%3a1.28-dmo5_amd64.deb
ffmpeg_3.3.9-dmo1+deb9u1_amd64.deb
gpac_1%3a0.7.1+20190313.git21f1d86ee-dmo1+deb9u3_amd64.deb
gpac-modules-base_1%3a0.7.1+20190313.git21f1d86ee-dmo1+deb9u3_amd64.deb
gstreamer1.0-libav_1.10.4-dmo1_amd64.deb
gstreamer1.0-plugins-bad_1%3a1.10.4-dmo2_amd64.deb
gstreamer1.0-plugins-ugly_1.10.4-dmo1_amd64.deb
lame_1%3a3.99.5-dmo6_amd64.deb
libaacs0_0.9.0-dmo1_amd64.deb
libaribb24-0_1.0.3-dmo1_amd64.deb
libaribb25-0_0.2.7-dmo1_amd64.deb
libasound2-plugins_1.1.4-dmo1+deb9u1_amd64.deb
libass9_2%3a0.13.7-dmo1_amd64.deb
libavdevice57_10%3a3.3.9-dmo1+deb9u1_amd64.deb
libavfilter6_10%3a3.3.9-dmo1+deb9u1_amd64.deb
libavresample3_10%3a3.3.9-dmo1+deb9u1_amd64.deb
libbabl-0.1-0_0.1.28-dmo1_amd64.deb
libbasicusageenvironment1_2%3a2017.04.26-dmo1+deb9u2_amd64.deb
libbdplus0_0.1.2-dmo1+deb8u1_amd64.deb
libdca0_0.0.5-dmo2+deb8u1_amd64.deb
libdsm3_1%3a0.2.7-dmo3_amd64.deb
libdvbpsi10_1.3.1-dmo1_amd64.deb
libebml4v5_1%3a1.3.9-dmo0+deb9u1_amd64.deb
libfaac0_1%3a1.28-dmo5_amd64.deb
libffmpegthumbnailer4v5_2.2.0-dmo4_amd64.deb
libffms2-4_1%3a2.23-dmo1_amd64.deb
libgegl-0.3-0_0.3.18-dmo1_amd64.deb
libgpac7_1%3a0.7.1+20190313.git21f1d86ee-dmo1+deb9u3_amd64.deb
libgroupsock8_2%3a2017.04.26-dmo1+deb9u2_amd64.deb
libgstreamer-plugins-bad1.0-0_1%3a1.10.4-dmo2_amd64.deb
liblavfile-2.1-0_2.1.0-dmo9_amd64.deb
liblavjpeg-2.1-0_2.1.0-dmo9_amd64.deb
liblavplay-2.1-0_2.1.0-dmo9_amd64.deb
liblivemedia58_2%3a2017.04.26-dmo1+deb9u2_amd64.deb
libmatroska6v5_1%3a1.4.5-dmo1_amd64.deb
libmicrodns0_0.1.2-dmo0~bpo9+1_amd64.deb
libmjpegutils-2.1-0_2.1.0-dmo9_amd64.deb
libmp4v2-2_2%3a2.0.0-dmo4_amd64.deb
libmpeg2encpp-2.1-0_2.1.0-dmo9_amd64.deb
libmplex2-2.1-0_2.1.0-dmo9_amd64.deb
libnfs8_1.11.0-dmo1_amd64.deb
libobs0_19.0.2-dmo2+deb9u1_amd64.deb
libogmrip1_1.0.1-dmo9_amd64.deb
libpostproc54_10%3a3.3.9-dmo1+deb9u1_amd64.deb
libquicktime2_1.2.4-dmo19+deb9u1_amd64.deb
librtmp1_2.4~20160119.gitfa8646dae-dmo5_amd64.deb
libsuil-0-0_1%3a0.8.4-dmo1+deb9u1_amd64.deb
libtwolame0_0.3.13-dmo3_amd64.deb
libusageenvironment3_2%3a2017.04.26-dmo1+deb9u2_amd64.deb
libvamp-hostsdk3v5_1%3a2.7.1-dmo1_amd64.deb
libvidstab1.0_2%3a0.98b-dmo1+deb8u1_amd64.deb
libvlc5_1%3a3.0.8-dmo0+deb9u4_amd64.deb
libvlc5_3.0.11-dmo0+deb9u1_amd64.deb
libvlc-bin_1%3a3.0.8-dmo0+deb9u4_amd64.deb
libvlc-bin_3.0.11-dmo0+deb9u1_amd64.deb
libvlccore9_1%3a3.0.8-dmo0+deb9u4_amd64.deb
libvlccore9_3.0.11-dmo0+deb9u1_amd64.deb
libx264-150_0.150.2833+gitdf79067-dmo1+deb9u1_amd64.deb
libxine2_1.2.8-dmo5_amd64.deb
libxine2-bin_1.2.8-dmo5_amd64.deb
libxine2-doc_1.2.8-dmo5_all.deb
libxine2-ffmpeg_1.2.8-dmo5_amd64.deb
libxine2-misc-plugins_1.2.8-dmo5_amd64.deb
libxine2-plugins_1.2.8-dmo5_all.deb
libxine2-x_1.2.8-dmo5_amd64.deb
libxvidcore4_1.3.4-dmo1_amd64.deb
mencoder_4%3a1.3.0~20170413.svn37931-dmo3+deb9u5_amd64.deb
mjpegtools_2.1.0-dmo9_amd64.deb
mjpegtools-gtk_2.1.0-dmo9_amd64.deb
mkvtoolnix_9.8.0-dmo1_amd64.deb
mkvtoolnix-gui_9.8.0-dmo1_amd64.deb
mplayer_4%3a1.3.0~20170413.svn37931-dmo3+deb9u5_amd64.deb
mpv_0.27.2-dmo1+deb9u1_amd64.deb
obs-plugins_19.0.2-dmo2+deb9u1_amd64.deb
obs-studio_19.0.2-dmo2+deb9u1_amd64.deb
ogmrip_1.0.1-dmo9_amd64.deb
ogmrip-doc_1.0.1-dmo9_all.deb
phonon4qt5-backend-vlc_1%3a0.9.1-dmo1+deb9u1_amd64.deb
rtmpdump_2.4~20160119.gitfa8646dae-dmo5_amd64.deb
subtitleripper_0.5.2-dmo3_amd64.deb
tovid_0.35.2-dmo1_all.deb
tovidgui_0.35.2-dmo1_all.deb
transcode_4%3a1.1.7-dmo15_amd64.deb
transcode-doc_4%3a1.1.7-dmo15_all.deb
twolame_0.3.13-dmo3_amd64.deb
vlc_1%3a3.0.8-dmo0+deb9u4_amd64.deb
vlc_3.0.11-dmo0+deb9u1_amd64.deb
vlc-data_1%3a3.0.8-dmo0+deb9u4_all.deb
vlc-data_3.0.11-dmo0+deb9u1_all.deb
vlc-l10n_1%3a3.0.8-dmo0+deb9u4_all.deb
vlc-l10n_3.0.11-dmo0+deb9u1_all.deb
vlc-plugin-base_1%3a3.0.8-dmo0+deb9u4_amd64.deb
vlc-plugin-base_3.0.11-dmo0+deb9u1_amd64.deb
vlc-plugin-notify_1%3a3.0.8-dmo0+deb9u4_amd64.deb
vlc-plugin-notify_3.0.11-dmo0+deb9u1_amd64.deb
vlc-plugin-qt_1%3a3.0.8-dmo0+deb9u4_amd64.deb
vlc-plugin-qt_3.0.11-dmo0+deb9u1_amd64.deb
vlc-plugin-samba_1%3a3.0.8-dmo0+deb9u4_amd64.deb
vlc-plugin-samba_3.0.11-dmo0+deb9u1_amd64.deb
vlc-plugin-skins2_1%3a3.0.8-dmo0+deb9u4_amd64.deb
vlc-plugin-skins2_3.0.11-dmo0+deb9u1_amd64.deb
vlc-plugin-video-output_1%3a3.0.8-dmo0+deb9u4_amd64.deb
vlc-plugin-video-output_3.0.11-dmo0+deb9u1_amd64.deb
vlc-plugin-video-splitter_1%3a3.0.8-dmo0+deb9u4_amd64.deb
vlc-plugin-video-splitter_3.0.11-dmo0+deb9u1_amd64.deb
vlc-plugin-visualization_1%3a3.0.8-dmo0+deb9u4_amd64.deb
vlc-plugin-visualization_3.0.11-dmo0+deb9u1_amd64.deb
x11proto-xf86vidmode-dev_2018.4-4_all.deb
x11proto-xf86vidmode-dev_2.3.1-2_all.deb
xine-ui_0.99.9-dmo14+deb9u1_amd64.deb
Not only can I not start Synaptic from the Desktop but I also could not use the Terminal (should have noted the error message).
I logged into the tty6 console and attempted the following command.
aptitude search "?origin (deb-multimedia) ?installed"
The resulting output was as follows.
Warning: Invalid locale(please review locale settings, this might lead to some problems later):
    locale::facet::_S_create_c_locale name not valid
So, I logged out of the tty6 Console and then the Desktop to Restart into another Distro to make this post.
Would it be possible to chroot into my Ascii OS to run the aptitude command and the dpkg command you suggested?
If so, would I then be able to use the chroot environment to use whatever other commands are necessary to fix the upgrade?
Thanks!!, MTB.
#5 2020-06-27 10:48:59
Wow. I think (hope) that 120 is the correct number of dmo packages installed and not 633.
You can get rid of sources.list.d/devuan.list. I don't know about the other lists. You might need to disable them temporarily and/or you might need to change the suite they're using. (stretch to buster?)
It looks like your dmo packages are older versions than what beowulf has. If you remove dmo from sources, you should be able to upgrade most of them to stock beowulf versions.
If there's something in dmo you need that isn't in the devuan repo, you can add it later. I highly recommend pinning dmo to a lower priority or disabling it altogether after you install what you want. That will prevent pulling in other stuff from dmo that you don't need or want. Just avoid dmo if you can.
And yes, you can do all this in a chroot from another system. I like to use a live-cd (or usb) for that, but rescue mode in the installer isos will also work.
#6 2020-06-27 18:02:18
mtbvfr
Before I get started on using chroot, is there a particular reason that you use a Live System for it? Is there any difference to using chroot from a Live system as opposed to an Installed system?
Thanks!!
#7 2020-06-27 18:46:00
Yes, you can use an installed system.
#8 2020-06-28 00:48:23
mtbvfr
Evening fsmithred,
There appears to be multiple ways that chroot can be used but in my research the info has not been 100% detailed as to what to do for a particular scenario.
For example, should I be doing this from a Terminal opened under the root account of the Live or Installed system or should I use sudo with the Terminal opened under My User Account?
I have seen pages where the person has created a directory for a Mount Point under their home directory whilst others have done it under the /mnt directory of the File System.
I have seen people referring to differences in commands/procedures to follow dependent on whether you are using a UEFI or Legacy BIOS.
Others have mentioned the mounting of boot partitions. In my case would that be the BOOTEFI partition (Partition 1) on the same drive that I have Devuan installed on? Do I need to be doing this for my scenario?
Within the Installed system I am currently working from, the Devuan partition is identified as /dev/sdc4.
My Laptop uses UEFI.
The Installed system I am currently working from is on the Internal Hard Drive whilst Devuan is on an External Hard Drive.
Are the following instructions what I need to be doing if working from Terminal as the root account?
Create a Directory sdc4 under the /mnt directory.
Mount /dev/sdc4 to /mnt/sdc4 (mount /dev/sdc4 /mnt/sdc4)
For the above command, should I be using "-t ext4" also?
chroot into /mnt/sdc4 (chroot /mnt/sdc4)
Do I also need to be executing the following commands/procedures before the chroot command?
Create a boot/efi directory under the /mnt/sdc4 directory for the mounting of a Boot partition? Which Boot partition?
Which of the following examples that I pulled off the Internet and modified, if necessary, should I be executing?
mount -t proc none /mnt/sdc4/proc
mount -o bind /dev /mnt/sdc4/dev
mount -o bind /sys /mnt/sdc4/sys
mount --bind /dev /mnt/sdc4/dev
mount --bind /proc /mnt/sdc4/proc
mount --bind /sys /mnt/sdc4/sys
mount -t proc proc /mnt/sdc4/proc/
mount -t sysfs sys /mnt/sdc4/sys/
mount -o bind /tmp /mnt/sdc4/tmp/
mount -o bind /dev /mnt/sdc4/dev/
Are there any other Local directories that should be mounted before executing the chroot?
Thanks!!, MTB.
#9 2020-06-28 09:08:22
If you're chrooting from a beowulf (or Debian buster) system then the easiest method is
# apt install arch-install-scripts
# mount /dev/sdc4 /mnt
# arch-chroot /mnt
[chroot] # mount -a
The arch-chroot command will (bind) mount the API filesystems automatically.
If you're doing this from ASCII then use
# for i in proc sys dev{,/pts} ; do mount --bind /$i /mnt/$i ; done
# chroot /mnt
[chroot] # mount -a
No need to bother with /tmp and no need to create any directories under /mnt; the mount and {arch-,}choot commands need root privileges.
EDIT: s/sda/sdc/
#10 2020-06-28 10:14:57
HevyDevy
Nice one Hoas, i didnt know arch-install-scripts were in the debian repos, this is archlinux port to debian hey?
#11 2020-06-29 17:08:43
mtbvfr
# arch-chroot /mnt
[chroot] # mount -a
Hi HoaS,
Thanks for this. I also discovered your input, regarding chrooting elsewhere, after I discovered that this installed system has its own utility which when you exit automatically cleanly unmounts the partition.
However, I decided to still install what you suggested to see what operational differences there might be for my own learning.
So, following your instructions, after entering the exit command, I executed umount /dev/sdc4 which reported that the partition was busy but I couldn't find anything open, that I was aware, that could be using a file of the Devuan install. So, after a little research I used the umount -l /dev/sdc4 command which did the trick.
Can you say what would have been holding a file open on the Devuan system even though I had exited the chroot environment?
Thanks!!, MTB.
#12 2020-06-29 17:17:43
mtbvfr
Hi again fsmithred,
So, after chrooting into Devuan, when I executed dpkg -l | grep dmo the output resulted in a listing of 122 packages which is 2 more than what was produced by ls |grep dmo in the "/var/cache/apt/archives/" directory.
aegisub                                1:3.2.2+dfsg-dmo4
aegisub-l10n                           1:3.2.2+dfsg-dmo4
audacity                               1:2.1.3-dmo1+deb9u1
audacity-data                          1:2.1.3-dmo1+deb9u1
bdsup2sub                              4.0.0-dmo1
bombono-dvd                            1:1.2.2-dmo13
bombono-dvd-data                       1:1.2.2-dmo13
devede                                 1:4.8.8-dmo1
dvdstyler                              1:3.0.3-dmo1
dvdstyler-data                         1:3.0.3-dmo1
faac                                   1:1.28-dmo5
ffmpeg                                 10:3.3.9-dmo1+deb9u1
gpac                                   1:0.7.1+20190313.git21f1d86ee-dmo1+deb9
gpac-modules-base:amd64                1:0.7.1+20190313.git21f1d86ee-dmo1+deb9
gstreamer1.0-libav:amd64               1:1.10.4-dmo1
gstreamer1.0-plugins-ugly:amd64        1:1.10.4-dmo1
lame                                   1:3.99.5-dmo6
libaacs0:amd64                         0.9.0-dmo1
libaribb24-0                           1.0.3-dmo1
libaribb25-0                           0.2.7-dmo1
libasound2-plugins:amd64               1:1.1.4-dmo1+deb9u1
libass9:amd64                          2:0.13.7-dmo1
libavcodec57:amd64                     10:3.3.9-dmo1+deb9u1
libavdevice57:amd64                    10:3.3.9-dmo1+deb9u1
libavfilter6:amd64                     10:3.3.9-dmo1+deb9u1
libavformat57:amd64                    10:3.3.9-dmo1+deb9u1
libavresample3:amd64                   10:3.3.9-dmo1+deb9u1
libavutil55:amd64                      10:3.3.9-dmo1+deb9u1
libbabl-0.1-0:amd64                    1:0.1.28-dmo1
libbasicusageenvironment1              2:2017.04.26-dmo1+deb9u2
libbdplus0                             0.1.2-dmo1+deb8u1
libbluray-bdj                          2:1.0.0-dmo1
libbluray2:amd64                       2:1.0.0-dmo1
libchromaprint1:amd64                  1:1.4.2-dmo1
libdca0:amd64                          0.0.5-dmo2+deb8u1
libdsm3:amd64                          1:0.2.7-dmo3
libdvbpsi10:amd64                      1:1.3.1-dmo1
libebml4v5:amd64                       1:1.3.9-dmo0+deb9u1
libfaac0:amd64                         1:1.28-dmo5
libfdk-aac1:amd64                      1:0.1.5-dmo2
libffmpegthumbnailer4v5:amd64          1:2.2.0-dmo4
libffms2-4:amd64                       1:2.23-dmo1
libgegl-0.3-0:amd64                    1:0.3.18-dmo1
libgpac7:amd64                         1:0.7.1+20190313.git21f1d86ee-dmo1+deb9
libgroupsock8                          2:2017.04.26-dmo1+deb9u2
libilbc2:amd64                         2.0.2-dmo4
libkvazaar3:amd64                      1:1.1.0-dmo1
liblavfile-2.1-0:amd64                 2:2.1.0-dmo9
liblavjpeg-2.1-0:amd64                 2:2.1.0-dmo9
liblavplay-2.1-0:amd64                 2:2.1.0-dmo9
liblivemedia58                         2:2017.04.26-dmo1+deb9u2
libmatroska6v5:amd64                   1:1.4.5-dmo1
libmfx0:amd64                          1.21-dmo1
libmicrodns0:amd64                     0.1.2-dmo0~bpo9+1
libmjpegutils-2.1-0:amd64              2:2.1.0-dmo9
libmp3lame0:amd64                      1:3.99.5-dmo6
libmp4v2-2:amd64                       2:2.0.0-dmo4
libmpeg2encpp-2.1-0:amd64              2:2.1.0-dmo9
libmplex2-2.1-0:amd64                  2:2.1.0-dmo9
libnfs8:amd64                          1.11.0-dmo1
libobs0                                1:19.0.2-dmo2+deb9u1
libogmrip1:amd64                       1.0.1-dmo9
libopenh264-2:amd64                    1.6.0-dmo3
libpostproc54:amd64                    10:3.3.9-dmo1+deb9u1
libquicktime2:amd64                    3:1.2.4-dmo19+deb9u1
librtmp1:amd64                         2:2.4~20160119.gitfa8646dae-dmo5
libsuil-0-0:amd64                      1:0.8.4-dmo1+deb9u1
libswresample2:amd64                   10:3.3.9-dmo1+deb9u1
libswscale4:amd64                      10:3.3.9-dmo1+deb9u1
libtwolame0:amd64                      1:0.3.13-dmo3
libusageenvironment3                   2:2017.04.26-dmo1+deb9u2
libvamp-hostsdk3v5:amd64               1:2.7.1-dmo1
libvidstab1.0                          2:0.98b-dmo1+deb8u1
libvlc-bin:amd64                       1:3.0.11-dmo0+deb9u1
libvlc5:amd64                          1:3.0.11-dmo0+deb9u1
libvlccore9:amd64                      1:3.0.11-dmo0+deb9u1
libwxsvg3:amd64                        3:1.5.12-dmo1
libx264-150:amd64                      3:0.150.2833+gitdf79067-dmo1+deb9u1
libx265-116:amd64                      1:2.4-dmo1
libxine2                               1:1.2.8-dmo5
libxine2-bin:amd64                     1:1.2.8-dmo5
libxine2-doc                           1:1.2.8-dmo5
libxine2-ffmpeg:amd64                  1:1.2.8-dmo5
libxine2-misc-plugins:amd64            1:1.2.8-dmo5
libxine2-plugins                       1:1.2.8-dmo5
libxine2-x:amd64                       1:1.2.8-dmo5
libxvidcore4:amd64                     3:1.3.4-dmo1
mencoder                               4:1.3.0~20170413.svn37931-dmo3+deb9u5
mjpegtools                             2:2.1.0-dmo9
mjpegtools-gtk                         2:2.1.0-dmo9
mkvtoolnix                             9.8.0-dmo1
mkvtoolnix-gui                         9.8.0-dmo1
mplayer                                4:1.3.0~20170413.svn37931-dmo3+deb9u5
mpv                                    1:0.27.2-dmo1+deb9u1
obs-plugins                            1:19.0.2-dmo2+deb9u1
obs-studio                             1:19.0.2-dmo2+deb9u1
ogmrip                                 1.0.1-dmo9
ogmrip-doc                             1.0.1-dmo9
phonon4qt5-backend-vlc:amd64           1:0.9.1-dmo1+deb9u1
rtmpdump                               2:2.4~20160119.gitfa8646dae-dmo5
subtitleripper                         0.5.2-dmo3
tovid                                  0.35.2-dmo1
tovidgui                               0.35.2-dmo1
transcode                              4:1.1.7-dmo15
transcode-doc                          4:1.1.7-dmo15
twolame                                1:0.3.13-dmo3
vlc                                    1:3.0.11-dmo0+deb9u1
vlc-bin                                1:3.0.11-dmo0+deb9u1
vlc-data                               1:3.0.11-dmo0+deb9u1
vlc-l10n                               1:3.0.11-dmo0+deb9u1
vlc-plugin-base:amd64                  1:3.0.11-dmo0+deb9u1
vlc-plugin-notify:amd64                1:3.0.11-dmo0+deb9u1
vlc-plugin-qt:amd64                    1:3.0.11-dmo0+deb9u1
vlc-plugin-samba:amd64                 1:3.0.11-dmo0+deb9u1
vlc-plugin-skins2:amd64                1:3.0.11-dmo0+deb9u1
vlc-plugin-video-output:amd64          1:3.0.11-dmo0+deb9u1
vlc-plugin-video-splitter:amd64        1:3.0.11-dmo0+deb9u1
vlc-plugin-visualization:amd64         1:3.0.11-dmo0+deb9u1
x11proto-xf86vidmode-dev               2018.4-4
xine-ui                                0.99.9-dmo14+deb9u1
Of the 122 packages, 18 did not have a file in "/var/cache/apt/archives/". They were the following.
devede
dvdstyler
libavcodec57:amd64
libavformat57:amd64
libavutil55:amd64
libbluray-bdj
libbluray2:amd64
libfdk-aac1:amd64
libilbc2:amd64
libkvazaar3:amd64
libmfx0:amd64
libmp3lame0:amd64
libopenh264-2:amd64
libswscale4:amd64
libwxsvg3:amd64
libx265-116:amd64
Of the 120 packages in "/var/cache/apt/archives/", 16 were not listed by dpkg -l | grep demo. However, 15 of these appear to have been earlier versions that were previously installed whilst the last pairing is the opposite. Whether these should have been removed when the other version was installed I can't say. The following list will help to clarify I hope.
Using aptitude search "?origin (deb-multimedia) ?installed" in the chroot environment produces the same result as before.
Warning: Invalid locale (please review locale settings, this might lead to problems later):
So, is there anymore analysis to be done before following a plan of action?
Thanks !!, MTB.
#13 2020-06-29 18:17:49
dmo is a sure path to a frankendevuan.  smile
#14 2020-06-29 18:54:26
I guess the plan would be to remove whatever is blocking the upgrade and whatever else you don't need. You can probably remove all or most of the dmo packages. And anything with "deb9" in the version is for stretch/ascii.
#15 2020-06-29 19:30:35
mtbvfr
I forgot to ask the following.
Should I use a dpkg command or an apt-get command to uninstall the dmo packages?
If apt-get, should I use apt-get remove Package or apt-get autoremove Package? Which options should be applied?
Will the use of these also remove the associated .deb files from "/var/cache/apt/archives/"?
After the packages have been uninstalled/removed, can I, then, copy the previously downloaded non-dmo .deb files into "/var/cache/apt/archives/" before executing apt-get dist-upgrade with the Laptop not connected to the Internet from the chroot environment?
Thanks!!
#16 2020-06-29 19:32:43
Not really but you can use lsof /dev/sdc4 to list any open files.
#17 2020-06-29 23:16:32
Use apt, apt-get or aptitude remove Package.
You probably won't need to name all of them, as some will come out automatically with others.
Aptitude will most likely remove more than the others.
You can do 'apt autoremove' afterward to get rid of unneeded packages that weren't already removed.
'apt-get autoclean' will get rid of the obsolete packages in /var/cache/apt/archives
'apt-get clean' will get rid of all the packages in /var/cache/apt/archives
I have no idea, but it sounds like you know what you're doing. I've never done it that way.
#18 2020-06-30 00:09:27
mtbvfr
I have no idea neither. smile That's why I am asking.
Thanks !!
#19 2020-06-30 06:44:15
PedroReina
I use this method again and again. But always with an active internet conexion and no chroot. I think that the package manager may need the conexion to know which packages is going to get. If the package is already in /var/cache/apt/archives/ it just skip the download.
#20 2020-06-30 22:32:12
mtbvfr
Hola Pedro,
Necesito usar chroot porque el escritorio es corruptado.
Su última frase parece ser confirmada por la información que encontré en el siguiente manual en línea.
Using APT Offline
Publicaré mi plan de acción, para que todos lo comenten, muy pronto.
¡Gracias!, MTB.
#21 2020-06-30 22:43:38
mtbvfr
Hi Folks,
Here's the Upgrade Recovery Plan I have come up with for which I would appreciate any feedback as to possible problems I could encounter.
chroot into my Devuan system.
For Package Removal Simulation, use aptitude -s -P remove "Package Name" for following packages.
For Package Removal, use aptitude -P remove "Package Name" to remove following packages.
    After each Removal, use dpkg -l | grep dmo to check how many packages still need to be removed.
For Package Names, used by the above commands, remove the ":amd64" suffix first.
devede                                 1:4.8.8-dmo1
faac                                   1:1.28-dmo5
lame                                   1:3.99.5-dmo6
ogmrip                                 1.0.1-dmo9
tovid                                  0.35.2-dmo1
Once all the above packages are removed, use apt autoremove.
Use apt-get autoclean to remove obsolete packages in the /var/cache/apt/archives directory.
Manually remove any remaining "dmo" packages in the /var/cache/apt/archives directory.
Remove all "dmo" packages from the directory I previously used for the packages I downloaded with the Bash script file that was created by Synaptic.
Execute the apt-get update command.
Perform the "3.2. Operation" step of Chapter 3. Using APT and wget from the Using APT Offline online manual (this could be what Synaptic does when the "Generate package download script" feature is used.) to check what package files already downloaded are still required and also to check if there are any new packages to be downloaded.
I will look at the output in the "uris" Output file first, before executing the awk command, and maybe use that for the basis of a comparison in a Spreadsheet as well as with the Diffuse Merge Tool graphical application. For any packages that I haven't previously downloaded, I can manually create a Bash script file using the wget command.
Once I have all the required packages in the 1 directory, then, I can execute the apt-get -o dir::cache::archives="/disc/" dist-upgrade command with "/disc/" being replaced by MY directory location.
Thanks!!, MTB.
#22 2020-07-01 08:28:44
PedroReina
Excelent! Thanks for sharing.
#23 2020-07-01 16:39:53
mtbvfr
Hi Folks,
I have partially(?) solved the locale problem it appears but not sure.
After some more research I executed locale-gen followed by dpkg-reconfigure locales.
Now, I do not get the original error output but when I execute dpkg-reconfigure locales I receive the following response.
/usr/sbin/dpkg-reconfigure: locales is broken or not fully installed
dpkg -l |grep locale produces the following.
ii  krb5-locales                                                1.15-1+deb9u1                             all          internationalization support for MIT Kerberos
ii  libboost-locale1.62.0:amd64                                 1.62.0+dfsg-4                             amd64        C++ facilities for localization
iU  libboost-locale1.67.0:amd64                                 1.67.0-13+deb10u1                         amd64        C++ facilities for localization
ii  libencode-locale-perl                                       1.05-1                                    all          utility to determine the locale encoding
iU  liblocale-gettext-perl                                      1.07-3+b4                                 amd64        module using libc functions for internationalization in Perl
iU  locales                                                     2.28-10                                   all          GNU C Library: National Language (locale) data [support]
iU  python-apt-common                                           1.8.4.1                                   all          Python interface to libapt-pkg (locales)
ii  util-linux-locales                                          2.29.2-1+devuan2.1                        all          locales files for util-linux
Thanks!! MTB.
#24 2020-07-01 17:57:29
From a native Beowulf install:
# dpkg -l | grep locale
ii  krb5-locales                                      1.17-3                              all          internationalization support for MIT Kerberos
ii  libdatetime-locale-perl                           1:1.23-1                            all          Perl extension providing localization support for DateTime
ii  liblocale-gettext-perl                            1.07-3+b4                           amd64        module using libc functions for internationalization in Perl
ii  locales                                           2.28-10                             all          GNU C Library: National Language (locale) data [support]
ii  python-apt-common
My first candidate for removal would be the libboost-packages, then the util-linux from ASCII.
#25 2020-07-01 19:35:44
Have you tried
# apt reinstall locales
# dpkg-reconfigure locales
