#1 2018-06-13 10:09:47
joril
Wrong /etc/locale.gen after Ascii net-install with additional locale
Hi everyone,
I've just installed a new Ascii server using the net-install ISO. During installation I selected an additional locale (it_IT.utf8) and even though locale used it correctly, /etc/locale.gen had it STILL commented out, so locale-gen wouldn't generate it and locale -a wouldn't list it.
Fixing this is easy once you know how, but what's the recommended way to report this problem?
#2 2018-06-13 15:20:03
Re: Wrong /etc/locale.gen after Ascii net-install with additional locale
Please report bugs to http://bugs.devuan.org  It's easy to do by email following the instructions.
#3 2018-06-14 06:48:34
joril
Thanks! I've used reportbug in the past, but I'm not sure which package I should file a bug against, this time...?
#4 2018-06-14 07:04:01
Package locales seems to be the owner of /etc/locale.gen (or at least the man page).
#5 2018-06-14 07:06:26
joril
Indeed, but it looks like this is an installation issue, not a problem with locales per se... Well I'll file the bug against locales anyway, thanks smile
#6 2018-06-14 07:25:00
joril
It seems like there's an issue with reportbug at the moment https://bugs.devuan.org/db/21/217.html
I'll send a mail manually smile
