Hello ,
am having considerable difficulty with Devuan 6 to reamin stable,
with previous Devuan do not remember encountering similar issues, but it could be resolved.
was switchting today from DE (Xfce) to (MATE) on Devuan 6;
did noteice that after entering username - password - there is a 30+ second delay and then a "beachball" for around 10second until desktop clears and loads fully.
have hoped it could be resolved by updateing to Devuan 7,
but the error remain for now;
please if someone could advise with the error?
according to "dmesg" it looks like this
[ 33.199088] show_signal: 118 callbacks suppressed
[ 33.199091] traps: accounts-daemon[2515] trap int3 ip:7efe6edc8bb7 sp:7ffe6721f620 error:0 in libglib-2.0.so.0.8400.4[66bb7,7efe6ed81000+a1000]
[ 33.230102] audit: type=1400 audit(1793289809.824:132): apparmor="ALLOWED" operation="open" class="file" profile="Xorg" name="/etc/udev/udev.conf" pid=2513 comm="Xorg" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[ 33.242994] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 33.424298] r8169 0000:0b:00.0: invalid VPD tag 0x00 (size 0) at offset 0; assume missing optional EEPROM
[ 33.528817] Lockdown: Xorg: raw io port access is restricted; see man kernel_lockdown.7
[ 33.545197] amdgpu 0000:03:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=none
[ 33.545201] amdgpu 0000:13:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=none
[ 33.952081] audit: type=1400 audit(1793289810.545:133): apparmor="ALLOWED" operation="open" class="file" profile="Xorg" name="/etc/udev/udev.conf" pid=2513 comm="Xorg" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[ 33.952428] audit: type=1400 audit(1793289810.545:134): apparmor="ALLOWED" operation="open" class="file" profile="Xorg" name="/etc/udev/udev.conf" pid=2513 comm="Xorg" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[ 34.059680] audit: type=1400 audit(1793289810.653:135): apparmor="ALLOWED" operation="open" class="file" profile="Xorg" name="/etc/udev/udev.conf" pid=2513 comm="Xorg" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[ 34.059736] audit: type=1400 audit(1793289810.653:136): apparmor="ALLOWED" operation="open" class="file" profile="Xorg" name="/etc/udev/udev.conf" pid=2513 comm="Xorg" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[ 34.381118] traps: accounts-daemon[2787] trap int3 ip:7f0005c85bb7 sp:7ffcafc98580 error:0 in libglib-2.0.so.0.8400.4[66bb7,7f0005c3e000+a1000]
[ 37.869195] traps: accounts-daemon[3033] trap int3 ip:7f0052ba0bb7 sp:7ffe361c9de0 error:0 in libglib-2.0.so.0.8400.4[66bb7,7f0052b59000+a1000]
[ 39.733463] traps: accounts-daemon[3042] trap int3 ip:7f524c972bb7 sp:7fff831181b0 error:0 in libglib-2.0.so.0.8400.4[66bb7,7f524c92b000+a1000]
[ 40.232235] block nvme2n1: No UUID available providing old NGUID
[ 87.736466] snd_hda_intel 0000:03:00.1: IRQ timing workaround is activated for card #0. Suggest a bigger bdl_pos_adj.thank you very much.
This looks a bit suspicious, to me..... maybe check grub configuration....
thank you,
updating grub did not resolve; previsouly, with xfce4, the issue did not occur.
This sounds like the same delay that I get on my older computer, although I can't be sure.
This fixes it for me. Open /etc/default/grub as root.
Find the line called: GRUB_CMDLINE_LINUX_DEFAULT="quiet"
Change it to read:
GRUB_CMDLINE_LINUX_DEFAULT="quiet loglevel=3 splash noresume"
Save and exit. Then run sudo update-grub.
Hopefully it fixes your issue. If it doesn't, it shouldn't hurt anything.
thank you, it hasn't resolved yet.
there must be more going on ¸~ since i noticed the older laptop is booting Devuan 7 faster than the 2 year old desktop PC (with whistles&bells) ~ Deskop booting hangs around also at "CUPS" , not sure whats going on, but instead of re-applying Devuan fresh, this time i'd rather like to find out.
What display manager are you using? Whichever it is, stop it, run startx as your normal user and examine /var/log/Xorg.0.log for any warnings/errors.
