#1 2026-09-21 16:56:12
yurimodin
[SOLVED] Steam is being problematic without SystemD
I know its probably a me problem but Steam and even Heroic Launcher have been a real issue lately from not having udev. Steam did not even want to start from Flatbak or Native.
I dualboot distros so I have been on Devuan for a long time but I just setup Debian on my other drive for now because of this.
Any other gamers in here that have any pointers for me?
FYI I am running Cinnamon(Xorg) and Nvidia proprietary drivers from the repos on both installs.
#2 2026-09-21 21:14:03
tux_99
Re: [SOLVED] Steam is being problematic without SystemD
But udev is available in Devuan.
$ ps -ef|grep udev
root       475     1  0 12:44 ?        00:00:01 /sbin/udevd --daemon
$ apt list udev
udev/stable 1:3.2.9+devuan4 amd64
udev/stable 1:3.2.9+devuan4 i386
“Either the users control the program – or the program controls the users” Richard Stallman
#3 2026-09-22 00:34:02
Mercury
What actual issue or error are you seeing?
#4 2026-09-22 15:35:10
yurimodin
Mostly stuff fails to open. Then when you try it from terminal you get a bunch of errors about udev sessions or mismatches. Usually a reboot fixes it but its odd. That is what Heroic was doing. Steam flat out refused to run after a few errors no matter what I did.
#5 2026-09-22 16:08:25
Please post a copy of the error messages you are getting. And a list of exactly which "stuff" fails to open. That might give us enough information to work out what's wrong.
#6 2026-09-22 17:16:55
yurimodin
Sorry it was dbus not udev
Heroic
~$ flatpak run com.heroicgameslauncher.hgl
bwrap: Can't find source path /tmp/dbus-CBeNqz22Wh: No such file or directory
Steam
Exit code: 0
Saving response to: /tmp/steamDEmHFJ - 105 bytes
steamwebhelper.sh[17511]: Starting steamwebhelper under bootstrap steamrt steam runtime via: /home/mark/.steam/debian-installation/steamrt64/pv-runtime/steam-runtime-steamrt/_v2-entry-point
steamwebhelper.sh[17511]: Starting steamwebhelper with steamrt steam runtime at /home/mark/.steam/debian-installation/steamrt64/pv-runtime/steam-runtime-steamrt/_v2-entry-point
x86_64-linux-gnu-capsule-capture-libs: warning: libsystemd.so.0 has an unexpected DT_SONAME, ignoring: libelogind.so.0
Steam Runtime Launch Service: starting steam-runtime-launcher-service
Steam Runtime Launch Service: steam-runtime-launcher-service is running pid 18442
steam-runtime-launcher-service[18442]: E: Can't find session bus: Could not connect: No such file or directory
i386-linux-gnu-capsule-capture-libs: warning: libsystemd.so.0 has an unexpected DT_SONAME, ignoring: libelogind.so.0
ERROR: ld.so: object 'libgtk3-nocsd.so.0' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
pressure-vessel-wrap[17511]: W: Disabling gtk3-nocsd LD_PRELOAD: it is known to cause crashes.
bwrap: Can't find source path /tmp/dbus-7aaYNAIIPe: No such file or directory
Steam Runtime Launch Service: steam-runtime-launcher-service pid 18442 exited
Steam Runtime Launch Service: steam-runtime-launcher-service is running pid 20595
steam-runtime-launcher-service[20595]: E: Can't find session bus: Could not connect: No such file or directory
Steam Runtime Launch Service: steam-runtime-launcher-service pid 20595 exited
Steam Runtime Launch Service: steam-runtime-launcher-service is running pid 22507
steam-runtime-launcher-service[22507]: E: Can't find session bus: Could not connect: No such file or directory
Steam Runtime Launch Service: steam-runtime-launcher-service pid 22507 exited
Steam Runtime Launch Service: steam-runtime-launcher-service keeps crashing on startup, disabling
steamwebhelper.sh[27493]: Starting steamwebhelper under bootstrap steamrt steam runtime via: /home/mark/.steam/debian-installation/steamrt64/pv-runtime/steam-runtime-steamrt/_v2-entry-point
steamwebhelper.sh[27493]: Starting steamwebhelper with steamrt steam runtime at /home/mark/.steam/debian-installation/steamrt64/pv-runtime/steam-runtime-steamrt/_v2-entry-point
pressure-vessel-wrap[27493]: W: Disabling gtk3-nocsd LD_PRELOAD: it is known to cause crashes.
steamwebhelper.sh[5262]: Starting steamwebhelper under bootstrap steamrt steam runtime via: /home/mark/.steam/debian-installation/steamrt64/pv-runtime/steam-runtime-steamrt/_v2-entry-point
steamwebhelper.sh[5262]: Starting steamwebhelper with steamrt steam runtime at /home/mark/.steam/debian-installation/steamrt64/pv-runtime/steam-runtime-steamrt/_v2-entry-point
pressure-vessel-wrap[5262]: W: Disabling gtk3-nocsd LD_PRELOAD: it is known to cause crashes.
#7 2026-09-27 03:03:05
SotF
I use SysVinit, KDE (x11), AMD CPU, AMD GPU. The Steam flatpak runs good for me.
I have a feeling the problem might actually be with Gnome or DEs using GTK.
I think that because Gnome (the most) hates x11. I suspect Mint cares little on working with x11 and are focusing on Wayland.
Display servers can affect the init framework and dbus, overall your GPU may not be communicated with correctly.
Options:
1) I haven't ran Cinnamon in a long time, but doesn't it have an option for desktop shortcuts, under Properties, to 'Run with dedicated GPU'? Try running the native Steam app with that (or if you make a desktop shortcut for the Steam flatpak, try that too).
2) Make sure Mint is using the NVIDIA card.  nano ~/.local/share/applications/steam.desktop. Find "Exec=" and modify the line.
Exec=__NV_PRIME_RENDER_OFFLOAD=1 __GLX_VENDOR_LIBRARY_NAME=nvidia /usr/games/steam %U
Then restart computer.
3) Try a Qt based DE.
#8 2026-09-27 10:04:36
unixuser
this is pretty explicite. Check in /tmp folder if you have a dbus socket, if yes check its permissions. If not, (how) do you start a dbus session at launch ?
#9 2026-09-27 17:00:14
yurimodin
Thanks for the input everyone, I ended up on Debian13 Cinnamon and it all works........Unfortunately I think this SystemD stuff has metastasized as far as gaming goes.
#10 2026-09-28 09:12:23
skidicarus
I've been gaming with Steam on Excaliber with no issues. I just downloaded the .deb file from Steam's website. The only piece of software that's required me to resolve systemd dependencies is Mullvad VPN. Nothing of the sort with Steam.
#11 2026-09-28 20:08:45
JayneCobb
I am the same as Skidicarus. I just download Steam from their website as a .DEB file. I am on Excalibur, NVIDIA drivers, and sysvinit. No issues. This is on 2 different Dell Laptops, an XPS 9510 and a G15 5530 Gaming laptop.
#12 2026-09-29 02:11:15
Hi, I also use steam and I have no such problems. Main difference is I don't use flatpacks. So, imo I don't think it's a systemD fault.
#13 2026-09-29 03:52:39
Mercury
The OP was clearly having some dbus issues. There was not enough investigation done to try to fix it, just a switch to a different distro. If OP is satisfied with that, that's good enough for them. However, Steam does work in Devuan as many users, including myself, can confirm.
#14 2026-09-29 03:56:08
Works here too, on Excalibur. Without systemd.
#15 2026-09-29 13:12:06
Never had a problem with steam, except for this recent bug that doesn't let me view games that aren't safe unless I verify my id with a credit card
SOURCEFORGE rations
