#1 2026-08-05 02:19:36
kapqa
troubled of linux behaviour (or is it devuan=?)
Hello ,
please forgive another suspicious post ]
but maybe someone of you can relate and offer an explanation ~
now this eems a recent behaviour,
but maybe not
was running a program in terminal, (not via sudo or the like)
and effecting "log-out"
only to "log-in" but under the same user-name to find out that the program apparently was still running.
(was blocking the resource trying to access again)
effectively until reboot.
anomalie two:
noticed that firefox someimes dows downloads, but not finishes them, (they remain unfinished in download window, and the sand-time-clock is still running)
(even after closing and reopening firefox) (the download still hangs) (no way to "close" download =)Z> effectively unless reboot.
well, i am not used to such behaviour on computer, so it kept me puyyzzled.
#2 2026-08-05 13:35:58
tux_99
Re: troubled of linux behaviour (or is it devuan=?)
Without providing as much detail as possible (for the first one exact sequence of commands used and for the second one screenshots and links of the downloads, in addition to the devuan version you are running) you won't get any real answers as your problem description is way too vague for that.
Either the users control the program – or the program controls the users” Richard Stallman
#3 2026-08-05 16:28:06
Did you start it with nohup (that's supposed to have that effect)? Or did you a script that could do that?
I've made good use of nohup to run long-running scripts on another system:
nohup scriptname >>scriptname.log 2>&1 &
Will keep the script running even if the ssh connection to the system It's running on drops out.
#4 2026-08-05 17:04:12
Here is another, spacefm from devuan/debian packages crashes almost always after maybe at most 5 clicks, sometimes less.
I bet debian did some bs to eff spacefm up though.
#5 2026-08-05 17:29:29
kapqa
actually , idont know what the program is doing in the background, aside from apparently computeing;
but if it "survives" a logout, that isn*t a good sign, somehow, sisuppose.
makes one think of running task in background where actually the computer should sit quite still;
such continiuty features, if not advertised, are absolutely unwanted, at least in my book.
but possibly, sinceh the compile has just been matched up (it is supposed to run on "systemd" systems), maybe it got  botched to some degree since did only lwave awasy "libsystemd-dev" and the rest is as planned for those OS;
but apart this flaw, it seem to function fine;
or, the mate-desktop has more flaws, than one might expect (the big one seems to be the caja-filemanager).
#6 2026-08-05 17:37:04
Yep. Flaws and bad attempts at features. Caja likes to throw errors in the background.
#7 2026-08-05 19:56:25
kapqa
there seem to be one such mentiuon on github (however, not caja related)
https://github.com/mate-desktop/mate-se … issues/165
(not sure if lightdm is involved in devuan 6.0 standard with mate-desktop, though)
#8 2026-08-05 20:27:28
I became a Mate user after Gnome2 was dropped and replaced with Gnome3. I dropped Mate for Cinnamon about 6 years ago because of various hangs especially related to USB. Haven't seen similar issues on Cinnamon.
#9 2026-08-05 20:32:55
It is.
#10 2026-08-06 09:15:38
kapqa
thank you both,
used cinnamon in before, but droppoed to mate loosely; kinda like it (always like debian squeeze, my favorite probably).
nowe, the issue is also with cinnamon DE, so it is probably related to this "lightdm" think or similar; am not too knowledgeable in these things, there are quite some actors involved.
logging-off user does not stop the script, that is the issue.
to me, this seems unacceptable. (but again, since script was probably made with "systemctl" in mind, maybe , but just maybe, it is due to that).
#11 2026-08-06 16:41:33
What is the script called? We *can't* give you much help without knowing that.
Please give us some more information to work on.
#12 2026-08-06 17:32:40
kapqa
@chris2be8 ,
if you are interested, created a post over in the apposite forum to hihglight the issue,
to some degree, running in background is "desired" behaviour for the "client" since this program , when installed via "deb" is running in background after startup even before login-user, so i might have created a whole lot of noise for little bit noghting.
https://forum.foldingathome.org/viewtop … 77#p374677
old adagios still holdeth true:
those loudesth shoutesth, seldom the brightesth.
