#1 2026-05-22 14:24:44
testing a yabridge fix
Any yabridge users?
I've been using chat bots to try a fix for yabridge to work with the latest version of winehq-staging. So far I've only worked on vst3 using reaper. I don't have many windows vsts so was just wondering if anyone is interested and would like to test theirs and provide some feedback on the results. Also if you use ardour see if it works with that.
So far in testing some work as expected, some work with minor bugs like the mouse wheel doesn't change the dials, I have to click and drag and some freeze and I have to close the fx window and reopen it. Different manufactures give different results. If anyone does use yabridge and tries let me know how it went and what plugins you used thanks.
Edit new link https://sourceforge.net/projects/vstbridge/
SOURCEFORGE rations
#2 2026-05-26 00:18:11
Re: testing a yabridge fix
Chat bots have done well here. It made a few more changes that seem to work well for vst3 and vst2 on the latest version of wine staging. Also it created an install.sh an GUI for adding and syncing plugins to be a bit more user friendly.
It's now been forked and called vstbridge. It can be found here  https://sourceforge.net/projects/vstbridge/
SOURCEFORGE rations
