#1 2026-05-21 11:10:00
[SOLVED] Unknown file
Doing some clean-up of leftovers from the various dist-upgrades I have gone through since jesse/ascii (actually found a netscape.desktop file) I came across a strange file.
#/root/fpv
Any idea as to what it is?
I cannot find a reference to it save 'first person view' drones setups which I do not have.
Please advise.
#2 2026-05-21 14:51:28
Re: [SOLVED] Unknown file
What kind of file is it?   file /root/fpv
How big is it? Can you see inside it with a pager or something else?
Does the date give you any clues? Maybe find other files with the same date to figure out what you were doing.
#3 2026-05-21 16:03:06
blackhole
Possibly something you have accidentally redirected to a file while running commands as root, due to a syntax error. perhaps.
/root is the root user's home directory. No packages would install in that location. Open it in a text editor
and have a look?
#4 2026-05-21 17:36:07
It has no extension.
According to mc:
Modify time: Apr 26 2025
fsmithred wrote:
Can you see inside it with ...
blackhole wrote:
... text editor and have a look?
It has some code (?), starting with the string glibc-ld.so.cache1.1 and ending with ldconfig (Debian GLIBC 2.36-9+deb12u10) stable release version 2.36.
No idea as to why it is there.
Can't remember what I was doing last thursday, much less on Apr 26 2025.
My guess is that it can be safely deleted but I have been wrong many times so I thought I's ask. 8^°
Thanks to both for the fast reply.
#5 2026-05-22 14:07:23
Doing some more digging found that, at some point and for reasons unknown, I did ...
# ldconfig -p
... which can only be executed with elevated priviliges.
From man ldconfig:
man ldconfig wrote:
-p
--print-cache
Print the lists of directories and candidate libraries stored in the current cache.
As it was just a print I tried it, with the result being a huge printout in the terminal:
[root@devuan ~]# ldconfig -p
1442 libs found in cache `/etc/ld.so.cache'
	libz3.so.4 (libc6,x86-64) => /usr/lib/x86_64-linux-gnu/libz3.so.4
	libz3.so.4 (libc6) => /usr/lib/i386-linux-gnu/libz3.so.4 ...
        ld-linux.so.2 (ELF) => /lib/ld-linux.so.2
	ld-linux-x86-64.so.2 (libc6,x86-64) => /lib/x86_64-linux-gnu/ld-linux-x86-64.so.2
Cache generated by: ldconfig (Debian GLIBC 2.36-9+deb12u14) stable release version 2.36
[root@devuan ~]#
No idea as to how that got in the /root directory but I deleted it.
The cache itself is in /etc/ld.so.cache.
That's all I could find, so I guess I can mark it solved.
