#1 2026-04-27 13:01:32
sephiroth
[SOLVED] Plasma login manager all white
I've done a base system install, followed by a base plasma desktop install, then the kde-standard meta-package, and finally LibreOffice. After this, I must be missing something because the login screen is all white with white letters. What am I missing?
#2 2026-04-27 16:09:04
yurimodin
Re: [SOLVED] Plasma login manager all white
This happens on several distros because no theme has been assigned to the login screen in the KDE control panel. I really wish that would het addressed. Anyway just pick a login screen theme and it should be good.
#3 2026-04-27 16:33:23
#4 2026-04-29 12:15:59
sephiroth
That worked, thank you.
