#1 2025-12-23 13:04:37
gfp
updating Genuen/Gnuinos
should I wait until Genuen is updating to "excalibur"
or should I already
point the repositories to the forthcoming stable release based on Devuan 6.0 Excalibur, the sources.list file should look as follows:
deb http://packages.genuen.org/merged excalibur main
deb-src http://packages.genuen.org/merged excalibur main
deb http://packages.genuen.org/merged excalibur-updates main
deb-src http://packages.genuen.org/merged excalibur-updates main
deb http://packages.genuen.org/merged excalibur-security main
deb-src http://packages.genuen.org/merged excalibur-security main
in order to get an update?
AFAIK until now is is work in progress and not all packages are already updated,
in order not to get a mixed distribution.
#2 2025-12-23 13:21:53
Re: updating Genuen/Gnuinos
Yes, you should wait a little while. Yesterday i uploaded severel packages to the repository:
https://packages.genuen.org/genuen/pool/main
But there is still work to be done.
#3 2025-12-23 14:47:43
prospero
genuen
Sounds good, and even shorter. Adopted. cool
