#1 2025-03-31 15:35:33
devur
[SOLVED] new installation with a few problems and a 'core boot file'
my new installation has a few problems, libreoffice won't start
after the installation I changed the size of the swap partition with devuan live and gparted
from 1 gb to 32 gb it was without problems, during boot I saw some lines with check sum error
and in /home there is a 'core' file that is difficult to read it looks like gnu is a recurring word
i fear that it is a guix.iso file that I had lying around on a cscard that was not ejected,
but there has been no check sum error on later boot, there is however a problem with
libreoffice writer that will not start and it is the same for other libreoffice programs
i have ufw and firejail which have both been active and ran the code
sudo firecfg --clean
but without effect on libreoffice, and I don't immediately see any other errors during the installation, but you never know
any help or suggestions
#2 2025-04-01 07:30:09
PedroReina
Re: [SOLVED] new installation with a few problems and a 'core boot file'
Have you tried to start libreoffice off a console to see any error messages?
#3 2025-04-01 12:31:48
devur
yes it's tried but i don't have any errors from the terminal, as i just remembered it's something with app not found.
in the meantime i have uninstalled LibreOffice and have started with the firejail manual from WordPress 'building custom profile'
but there is also the problem of finding an answer to whether the installation is compromised and i have to start from scratch
but i must say that my Devuan seems to work well!
Is there any use for the 'core file' I have?
#4 2025-04-02 18:40:22
devur
I have formatted the hdd and started a new installation
#5 2025-04-03 14:26:14
devur
OK After a lot of problems, I'm back in business.  smile
