#1 2024-11-26 09:45:41
[SOLVED] forum image embedding question.
referencing the directions for displaying an image found here:
https://dev1galaxy.org/help.php#img
     snippet quoted:
Links and images
If you want to display an image you can use the img tag. The text appearing after the "=" sign in the opening tag is used for the alt attribute and should be included whenever possible.
FluxBB bbcode test produces FluxBB bbcode test
     same but code tags:
[img=FluxBB bbcode test]https://dev1galaxy.org/img/test.png[/img] produces FluxBB bbcode test
     page source code quoted:
<p><a name="img"></a>If you want to display an image you can use the img tag. The text appearing after the "=" sign in the opening tag is used for the alt attribute and should be included whenever possible.</p>
        <p><code>FluxBB bbcode test</code> produces <samp><img style="height: 21px" src="https://dev1galaxy.org/img/test.png" alt="FluxBB bbcode test" /></samp></p>
tried to do this a variety of ways and never succeeded. this was the image i was trying to embed:
xkcd password strength comic
are the instructions correctly incorrect?
#2 2024-11-26 17:13:40
Re: [SOLVED] forum image embedding question.
I'm seeing all your images, so it must be working.
#3 2024-11-26 23:10:44
This forum does not offer inline display of images... or does it? Yes it does, if you have configured your profile thusly.
Click on the "Profile" link, then click on the "Display" menu entry and then decide about whether to set (or not) the toggle for "show images in posts", followed by a light poke at the "submit" button.
#4 2024-11-27 07:32:17
indeed @ralph.ronnquist offers the correct correction and a light poke as well...sigh...
throughout decades of electronics usage we have always sought to turn off anything/everything we can/could to reduce attack-surface / bandwidth-consumption / doxxing / identity-theft / etc.
once again...and on a daily basis...humbled & _hat_in_hand_head_bowed_
nevertheless,
