#1 2024-11-18 13:53:34
ks
Cups error AFTER successful print
Running daedalus, cups hosted on a separate pc running daedalus too.
I don't know which devuan release introduced this symptom (I've skipped one or two releases on the print server) but it's wasting two sheets of paper each time I print something.
When a file is printed successfully, the printer is ready again, then after a moment prints a blank sheet and another one with:
ERROR:
timeout
OFFENDING COMMAND:
timeout
STACK:
That happens with all the applications I use for printing. The single exception I've seen so far has been printing PDFs with xpdf.
#2 2024-11-18 21:39:54
Re: Cups error AFTER successful print
Daedalus here, not having the issue you described, printer works great.
#3 2024-11-19 09:38:54
have had many mysterious mysteries manifest over the last 40 years. especially with those printers.
