#1 2023-10-15 02:04:19
Tad
[SOLVED] Claws mail start crashing
The system: Devuan Chimaera with all recent updates, Claws Mail 4.1.1-2~bpo11+1. Since two days ago it crashes when trying to open mails in HTML mode. Does anybody else experience the same?
Thanks, Tad
#2 2023-10-15 08:35:05
PedroReina
Re: [SOLVED] Claws mail start crashing
Tad wrote:
it crashes when ...
If you launch the program from a terminal, do you get some message on it?
#3 2023-10-15 11:04:09
Tad
Hi Pedro,
Yes, below are messages from claws mail after it has crashed. It looks like the recent libwebkit update has broken it.
Thanks, Tad
(claws-mail:26527): GLib-GObject-WARNING **: 21:48:06.356: ../../../gobject/gsignal.c:2614: signal 'resource-request-starting' is invalid for instance '0x2075450' of type 'WebKitWebView'
(claws-mail:26527): GLib-GObject-WARNING **: 21:48:06.357: ../../../gobject/gsignal.c:2614: signal 'resource-load-failed' is invalid for instance '0x2075450' of type 'WebKitWebView'
(WebKitWebProcess:26554): Fancy-Web-Ext-DEBUG: 21:48:06.553: Initializing Fancy web process extension
(WebKitWebProcess:26554): Fancy-Web-Ext-DEBUG: 21:48:06.574: Page 10 created for (null)
(WebKitWebProcess:26554): Fancy-Web-Ext-DEBUG: 21:48:06.574: WebPage user message received callback - LoadRemoteContent
(WebKitWebProcess:26554): Fancy-Web-Ext-DEBUG: 21:48:06.574: LoadRemoteContent param - 0
(WebKitWebProcess:26554): Fancy-Web-Ext-DEBUG: 21:48:06.581: WebPage user message received callback - LoadRemoteContent
(WebKitWebProcess:26554): Fancy-Web-Ext-DEBUG: 21:48:06.581: LoadRemoteContent param - 1
No provider of eglCreateImage found.  Requires one of:
    EGL 15
Aborted
#4 2023-10-16 09:17:07
PedroReina
According to https://github.com/tauri-apps/tauri/issues/8013
this is worth a try:
WEBKIT_DISABLE_COMPOSITING_MODE=1
I hope it helps smile
#5 2023-10-16 10:07:47
Tad
Hi Pedro,
Yes, that has cured the problem indeed. Claws Mail is displaying messages correctly again.
Thank you very much for your help!
Tad
#6 2023-10-16 18:55:12
PedroReina
Glad to know smile
