#1 2022-04-03 08:33:32
bai4Iej2need
Scrolling Output in the Console Window
Since some time I miss the function of page-up and page-down in the console. I do not recall when this was gone. If you want to see some output, which has passed the uppermost line in the console window, this output is lost. If you are lucky, you can repeat the event and pipe the output into less, then you can navigate in the output.
I happened to put an old 486 Desktop in service again last week, which was bought in 1998 and had not been in operation since Nov 2007 or so. Luckily it worked and it showed a SuSE7.0 install with kernel 2.2.16 installed and a fvwm95 desktop. that makes ~ 40 tasks !
And there I could scroll the console window up and down, I remember with Shift-Page-Up/-Down, as much as the size of the console memory permits.
How can i get this scrolling function in the devuan console again, as i do all administrative tasks in the console ?
happens not in x-terminals
depends not on zsh or bash (echo $SHELL)
This concerns
1:2345:respawn:/sbin/getty --noclear 38400 tty1
2:23:respawn:/sbin/getty 38400 tty2
3:23:respawn:/sbin/getty 38400 tty3
4:23:respawn:/sbin/getty 38400 tty4
5:23:respawn:/sbin/getty 38400 tty5
6:23:respawn:/sbin/getty 38400 tty6
after a login
@admins : you may shift this to a more appropriate theme
broken by design :
#2 2022-04-03 09:28:28
Re: Scrolling Output in the Console Window
Well, there is no generic Devuan console. I guess you are talking about the terminals you can open on the graphical DE. There may of them, Gnome Terminal, Mate Terminal, xterm ....
Why don't you tell us a bit about the environment you are working on?
#3 2022-04-03 10:00:15
bai4Iej2need
see above
There is a server (beowulf) which does not even have an xserver.
Edit:
uname -a
Linux "$HOST" 4.19.0-20-amd64 #1 SMP Debian 4.19.235-1 (2022-03-17) x86_64 GNU/Linux
used mostly through ssh , where the problem does not exist.
I have Laptops with chimaera, but also here I do admin tasks in the console.
Edit : And here the problem comes up.
uname -a
Linux "$HOST" 5.10.0-12-amd64 #1 SMP Debian 5.10.103-1 (2022-03-07) x86_64 GNU/Linux
broken by design :
#4 2022-04-03 10:21:20
https://www.phoronix.com/scan.php?page= … Scrollback
Perhaps use tmux or screen instead?
#5 2022-04-03 11:11:10
alexkemp
Shift-PageUp / Shift-PageDown works for me.
$ cat /etc/devuan_version
chimaera
$ cat ~/.bash_history
(then Shift-PageUp, etc.)
Help | About: xfce4-terminal 0.8.10
#6 2022-04-03 11:30:45
Marjorie
Shift-PageUp / Shift-PageDown also works in gnome terminal (Cinnamon - Chimaera).
#7 2022-04-03 12:10:33
^ & ^^ the OP has mentioned twice now that they are not asking about terminal emulators in the graphical desktop but rather the console screen, also known as the TTY.
#8 2022-04-03 12:23:23
hunter0one
He's talking about the TTY not a terminal emulator. I also have this issue regardless of the Linux distro, even shift + pageup/pagedown does not work. Interestingly, FreeBSD's tty scroll works just fine.
#9 2022-04-03 12:42:52
bai4Iej2need
I tested tmux and screen on the DUT console.
They do not bring this functionality with them.
so Linus Tv is wrong, that nobody uses this functionality.
Anyone, who must access bare HW through  the keyboard without intervening ssh tunnels etc, falls back to the functionality.
This haṕpens mostly during the first manual install.
And it is annoying, if the function is there in all other forms of graphic terminals, shells and tunnels, but not during a direct access.
Who tells LTV ?
broken by design :
#10 2022-04-03 13:10:11
bai4Iej2need
and I made another test :
ssh'ed from the console of the kernel 5.10 laptop to the server with Kernel 4.19
and the scrolling function is gone.
As I tend to work on the lowest level necessary this is really a PITA.
broken by design :
#11 2022-04-03 13:18:00
hevidevi
command | less
or
command | more
#12 2022-04-03 15:05:53
yeti
Try harder.
Screen gives me a scrollback in "real texmode" and GUIy terminals.  Just not with PgUP.  Use doping: Read a bit more about it.  Look for ^A ESC or ^A [.
Tmux probably does it in a very similar way.
#13 2022-04-03 16:22:11
I've just pressed ctrl-alt-f2, logged on, typed ls to get a few screenfuls of ouput and shift-page_up and shift-page_down work. But if I press ctrl-alt-f7 to get back to the GUI, then ctrl-alt-f2 the scroll buffer is cleared.
This is on ascii (I run CUDA on an old GPU and dare not update it because Nvidia have probably removed support for the GPU from current releases of their drivers and runtime).
Chris
#14 2022-04-03 19:30:00
bai4Iej2need
https://www.phoronix.com/forums/forum/s … ost1207037
Not everybody is happy with dropping this code, when LTv makes a ... decision
AND : /usr/bin/less is not available in runlevel 1 !
broken by design :
#15 2022-04-03 21:05:32
bai4Iej2need
tested now with kernel linux-image-4.19.0-20 from beowulf, but the function is the same missing.
vgacon.c patch has been backported to 4.19. to remove the code.
broken by design :
#16 2023-01-24 15:47:12
bai4Iej2need
My headless X-less server sent me a mail this morning, it had a new kernel from unattended upgrades in the last night.
Told me I should restart. Which I did. Which failed.
I had to move the server to a place with kbd mouse and monitor. Fixed it. Scrolled up and down on the local console and it works again.
Explanation : The unattended upgrade was not the cause of the failure. This would have happened on any restart. It was an error in one of my scripts. (file not found)
new is 5.10.0-21-amd64
Wonder still happen.
Server is now back in place.
broken by design :
#17 2023-01-24 16:00:12
blackhole
Unattended upgrades: What could possibly go wrong?  (ask Microsoft)
#18 2023-01-24 20:33:23
IME, very little. unattended-upgrades has been available (as opposed to mandatory, ala microsoft) in debian and derivatives for as long as I can remember, and I have several machines that have been running it for well over a decade without any drama (with one notable recent exception, but that was a "devuan shipped nonfunctional configs", not "unattended-upgrades ate my lunch").
I probably wouldn't bother with it on a desktop pc, but for headless boxes, especially if you have many headless boxes you can't be arsed updating manually one at a time (or remembering they exist for that matter), it's pretty dang handy.
Wait, what? Are you telling me that this stupid "nobody uses TTYs any more" regression has actually been fixed?
#19 2023-01-24 20:36:45
It's been enabled by default since stretch, at least for the GNOME desktop.
I've been using it for about five years on both the family laptops (running stable ofc) with no problems at all. It's really nice, I don't have to touch those machines at all, which is the ideal for me.
EDIT: the only caveat would be if the kernel was upgraded and then a device needing a new module to be loaded was plugged in, which would then fail. I've never actually encountered that though.
#20 2023-01-24 20:43:38
I was unaware that it's enabled by default now, but then I would be, because "expert" mode netinstalls with --no-recommends, and, well, GNOME *shudder*.
#21 2023-01-27 06:41:08
^ This is a lie. I've just remembered https://bugs.debian.org/cgi-bin/bugrepo … ug=1022042 — I had to boot up an Arch live ISO image, mount the root partition, arch-chroot in, downgrade the kernel and hold it to that version for a few days until the fixed kernel was pushed. A simple fix but the system was effectively un-bootable without intervention. So that's one breakage in five years. Not bad, I suppose, but not perfect either.
#22 2023-04-11 19:20:48
bai4Iej2need
No sorry , I must have been in another -what ever - world
Today  I have seen that busybox still can do the scroll, but pure kernel tty console cannot.
So I must take that back.
broken by design :
#23 2023-04-11 22:07:59
Has anybody worked out how to get the tty's to stay after updating/upgrading Daedalus?
I use them sparely, but very often it's the only way to edit configs and/or install required packages.
Sorry for the hijack... it is a pita.
