#1 2021-09-19 21:31:44
oui
minimal installations: what is the minimal way to install sound
in my precedent installation, I did directly install pulseaudio. no sound!
later I did read here in that forum, some parts of alsa sound is a ABSOLUTELY NEEDING dependency sine qua non!
why not in the dependencies of the package?
next difficulty is that there are a lot of doc's in the web speaking about that problem but all speak / report on «alsa» and nothing more...
but there is no package (or pseudo package) with the name «alsa» in devuan!
why?
sound is a VERY IMPORTANT figure of an installation!!!
a distro where you meet difficulties on that figure can't be good!
#2 2021-09-19 22:04:26
macondo123
Re: minimal installations: what is the minimal way to install sound
oui, don't get your panties in a bunch!
I don't use pulseaudio myself for some reasons, I use alsa, never had any problems.
apt-cache search alsa
install alsa-utils alsa-tools and a couple more I can't remember, then lauch alsamixer, unmute with the letter M, configure your window manager accordingly and read, read...
This forums has some examples in Documentation for icewm, jwm, and ratpoison written by yours truly.
Ratpoison
https://dev1galaxy.org/viewtopic.php?id=1695
IceWM
https://dev1galaxy.org/viewtopic.php?id=1644
JWM
https://dev1galaxy.org/viewtopic.php?id=1632
Bon chance, mon ami!
#3 2021-09-20 09:05:23
PedroReina
May be helpful: Do not use pulseaudio
#4 2021-09-20 15:58:47
ALSA is part of the kernel. The user space utilities are already installed.
If you need help configuring it see https://wiki.archlinux.org/title/Advanc … sound_card
#5 2021-09-21 06:51:51
larsH
Hi
From console try alsamixer. It is controlling alsa
Have a nice day
Lars H
