#1 2016-11-29 16:46:34
admin
List of Devuan derivatives
Please discuss your experiences and ask questions about derivatives based on Devuan in this forum.  To make posts easily searchable, please preface you posts with the name of the derivative in brackets like this - [GNUinOS]
HERE IS A CURRENT LIST OF DERIVATIVES IN CHRONOLOGICAL ORDER:
Exe GNU/Linux - https://exegnulinux.net
GNUinOS - https://gnuinos.org
Refracta - https://www.refracta.org
Star - https://sourceforge.net/projects/linnix
EterTICs - https://gnuetertics.org
MIYO - https://sourceforge.net/projects/miyolinux
Crowz - https://sourceforge.net/projects/crowz
DecodeOS - https://decodeos.dyne.org
Maemo Leste - https://maemo-leste.github.io
FluXuan - https://sourceforge.net/projects/fluxuan
AVMultimedia - https://de.osdn.net/projects/avmultimedia
Forge (formerly Michaels Devuan Edition) - https://sourceforge.net/projects/forge-os
GobMis - https://distro.misiones.gob.ar
Peppermint OS Devuan Release - https://peppermintos.com/2023/10/pepper … n-release/
Vuu-do - https://sourceforge.net/projects/vuu-do
THE FOLLOWING ONLY PROVIDE BUILDS UP TO BEOWULF:
heads - https://heads.dyne.org/about.html
mini-mimo - https://github.com/imstanz/mini-mimo/wiki
ThomOS (formerly Crunkbong) - https://gitlab.com/souperdoupe/thomos
Virage - https://sourceforge.net/projects/virage-gnu-linux
THE FOLLOWING ONLY PROVIDE BUILDS UP TO ASCII:
Dowse - https://dowse.eu
THE FOLLOWING ONLY PROVIDE BUILDS UP TO JESSIE:
good-life-linux - https://sourceforge.net/projects/good-life-linux
Nelum-dev1 - https://sourceforge.net/projects/nelum-dev1
#2 2016-11-30 11:03:48
miroR
Re: List of Devuan derivatives
I have tried (or should I say "I had tried"; I work so slowly that it's Past Perfect Tense, really) a few Devuan images, but only one Devuan derivative I managed to install in a Virtual Machine.
Here:
http://www.croatiafidelis.hr/foss/cap/c … evuan/#No5
(I know it's not much, but I'm fresh --and slow-- also at Virtual Machines)
I have very high security standards though. I deploy grsecurity-hardened in my Gentoo (which is actually cloned from my Air-Gapped master system).
I look forward to making a similar scenario with Devuan... It's the only acceptable way for me for a  day-to-day used system...
And surely, Air-Gap installing and hardening could make it in the order of magnitude of manifold increase of time and work, maybe even for a programmer.... And yet, my top contributions in FOSS GNU/Linux (mostly in Gentoo) have so far been, (at times) good testing...
I can expand on the Air-Gapping and also on cloning (what a great security feature: you install from PGP-signed local repository in Air-Gap, and clone that system into same MBO --that is the condition, also compatible HDDs, similar peripherals-- another system for only online! ...
"I can expand on the Air-Gapping"...  I meant in another topic, I forgot that I was replying to a topic on Devuan-based distros... Moderators, feel free to split this topic away from:
Devuan Derivatives
https://dev1galaxy.org/viewtopic.php?id=9
I've been following Devuan since soon after its inception, and am very glad it's growing and getting appreciation around the world!
Regards!
Miroslav Rovis
Zagreb, Croatia
http://www.CroatiaFidelis.hr
Try refute: rootkit hooks in kernel,
linux capabilities for intrusion? (Linus?)
Devs/testers/users of FOSS, what might be ahead for GNU/Linux after we lost PaX Team and spender? spender wrote:
https://forums.grsecurity.net/viewtopic … 699#p17127
Google made the choice to engage in underhanded competition against us with our own code...
grsecurity ripoff by Google, w/ Linus approval https://lists.dyne.org/lurker/message/2 … 4b.en.html
#3 2016-12-01 23:13:21
To get expert install in gnuinos, select Install, hit TAB and add priority=low to the boot command. Then ENTER. (Looks like it works ok, I aborted early.)
#4 2016-12-10 14:40:21
figosdev
where to submit derivative-derivatives? there are at least a couple derivatives based on refracta already-- they may not be wholly unique (mine isnt) but they do have features out-of-the-box, some of which are worthy of note.
the best measure of success for devuan as a fork is if it has enough derivatives based on it, like debian had. i dont know how many ubuntu derivatives there are out there, but ubuntu was certainly a huge step forward (for a while) in terms of promoting debian. i may have never used debian if not for ubuntu (circa 2008 i mean.)
#5 2016-12-15 20:47:50
A derivative of a derivative is a derivative.
$0.02
I think figos is worth listing. It's the only distro I know that comes in a multi-boot iso. Maybe I've been spending too much time inside the box, but that just blows my mind.
#6 2016-12-16 10:54:25
FOSSuser
[MIYO] Nice basic distro that is basically just internet access out of the box, uses Openbox, you get to add the programs that you want.
[Refracta] Good lightweight desktop experience, uses xfce, has tools to create your own personal version. Some might have a problem with wifi as some (supplied) firmware may be needed to be installed before you can connect to the internet.
Edit: Installed Miyo to a pendrive, & Refracta to a laptop.
#7 2016-12-21 14:12:50
chillfan wrote:
$0.02
That does sound useful, do you have a link to the homepage of figos?
Cheers smile
I don't think there's a home page at this point. I pinged figosdev to see if we can get a definitive answer to this question, but meanwhile, here's a short discussion about it with a link to the script that is used to make the iso:
http://refracta.freeforums.org/fig-os-c … -t591.html
-fsr
#8 2016-12-21 14:33:15
Here's the link to figos.  It hasn't been posted in the list because there is not one mention of Devuan on that page and Puppy/Refracta seems a little too far afield.
#9 2016-12-22 18:03:38
Quote from the author of figos:
you can always get the latest script (because fig os was originally meant to be something you put together yourself-- and customized if you wanted-- after all, its an automated process but you can tweak it if you like) at http://unofficialdistros.freeforums.org … tc-f4.html
#10 2016-12-23 10:18:42
Golinux, thanks for the link. I downloaded the following iso:
http://archive.org/download/Puppy_Linux … gos0.9.iso
Cheers,
   Aitor.
#11 2017-05-14 04:49:32
I just updated the derivatives list.  Apologies for neglecting it for so long..  The list on the website should now be in sync with the one here.   Thanks for your patience.
#12 2017-05-17 11:16:27
zephyr
Didn't notice until now, good-life-Linux is sharing the Sourceforge link with Crowz in the List of Devuan Derivatives.
Thanks
zephyr
CROWZ
#13 2017-05-17 13:44:55
Oops.  Fixed.  Thanks for catching that.
#14 2017-05-17 21:58:11
This just literally made what was a darned frustrating day (chasing a bug I made myself somehow), into me being a happy camper, thanks Golinux!!
Okay, guess I better get back to the drawing board since I made the list and all. wink
#15 2017-05-18 01:32:00
pekman
Any news for GNuinos? Seems to be dormant.
#16 2017-05-20 12:01:18
Hi pekman,
First of all, thanks for your interest taken in Gnuinos. I'm the author of this distribution, and now i'm working on some applications in gtk. One of them is a new GUI for the backend of simple-netaid. Here you are the code:
https://git.devuan.org/aitor_czr/simple … ree/master
and here you are a video, comparing the behaviour of the status icon with the status icon of the original GUI (written in freepascall):
http://gnuinos.org/simple-netaid-gtk_2.mpg
The active wifis will be shown at real time in the future, as you can see in the following video:
http://gnuinos.org/simple-netaid-gtk.mpg
But, at the time being, there will be a "refresh" button for that, because i have to fix a Segmentation fault.
Another project is a new menu for openbox (also in Gtk), dynamic and multilingual. Here you are a video:
http://gnuinos.org/openbox-menu1.mpg
This menu will have also a static header (still not included), containing items like "gmrun", "terminal", "web-browser", etc... and a static footer, containig as a final item the "Exit" option (at the same developed in gtk, i.e. a new openbox-logout).
I'll also work on a device-manager-gui, for umout/eject,  mount/open... external devices.
Shortly i'll start learning "amprolla", developed by Nextime. Gnuinos will use amprolla, vdev, simple-netaid and linux-libre (and OpenRC, maybe). So, the release of Gnuinos will take some time smile
Cheers,
  Aitor.
#17 2017-05-20 18:49:40
Sounds exactly like obmenu-generator, check out Miyolinux, it already uses it and it's what i'm using in Vuu-do openbox.
#18 2017-05-20 21:21:04
pekman
Hi @aitor... Thanks for explanation. Best news.
I recommend Runit (another Openrc), is very best... See Runit in action in Void Linux. Is very impressive.
#19 2017-05-21 06:20:59
Void Linux... Steve Litt talked about it, i think. Downloading it...
#20 2017-07-22 00:50:54
mckaygerhard
Analising all the derivates Devuan based:
Winner: Dowse - http://dowse.eu/]http://dowse.eu/]http://dowse.eu/ ARM an rasberry focused, very featured linux, but not so light does not work well in older arm rasberry fist devices.. great project! but quite slower with older devices, specialized for those that need a rasberry and does not like debian with systemd
Second place: Exe GNU/Linux - http://exegnulinux.net featured! comes with something that other does not offer, trinity desktop, light but also some eye-candy, but as always slower with PIII and P4 laptops...
3rd: Refracta - http://www.ibiblio.org/refracta : featured the refracta software, nothing more that we cannot do in the current devuan
4th: dyne:bolic oh soon now a linux with dark theme with a ugly desktop, wel but YES FEATURED A LOT OF MULTIMEDIA SOFTWARE, well done at least
the rest:
Gnuinos - http://gnuinos.org : nothing special.. doe snot work well in some x86 older so why making light
MIYO - https://sourceforge.net/projects/miyolinux/ this can be analied due its a base system minimized.. mostly for those that wants to modify, not enought to start doint something only base tools.. does not featured nothing
Nelum-dev1 - https://sourceforge.net/projects/nelum-dev1 : very heavy, only devuan with some desktop pre-installed with custom theme, does not featured nothing that we cannot do in devuan install with 30 minuts..
Star - https://sourceforge.net/projects/linnix : ??? nothing more than a devuan with "light" desktop (mostly windown managers not more), bt 32bit does work slower in asus eepc and hp P4 based cpu
heads - https://heads.dyne.org/about.html : when user download all the preinstalled software are outdated (kakaka, nonsense)
good-life-linux - https://sourceforge.net/projects/good-life-linux/ only a Devuan with LXDE preinstaled with a custom dark (ohh anews) theme
Crowz - https://sourceforge.net/projects/crowz/:  only a devuan linux with openbox or jwm with another "dark" again theme
Vuu-do - https://sourceforge.net/projects/vuu-do/ ?? uff i'm tyred...
#21 2017-07-22 01:37:16
Yawn . . . and zzzzz
#22 2017-07-22 08:51:41
FOSSuser
Use what suits you, that's what choice is about.
Personally, I don't want anything other than to get straight online with my wifi, a GUI, mp3 player, & a browser, even if it is only Dillo. smile
Quite a few experienced Linux users are of the same opinion, they want to start with a minimal usable system, & just add the programs that they want.
Having that option as a live distro just makes life so much easier.
If you want a full desktop environment with everything in it, just go for it & fill up your disk. wink
#23 2017-07-22 11:30:53
MiyoLinux
Here's one I haven't seen mentioned before...
Alien-OS https://sourceforge.net/projects/alien-os-mnml/
Alien-OS MNML (MiNiMaL) is a lean Devuan based Linux distribution with Openbox.
ATTENTION:
German keyboard layout is used. :-)
Features:
Minimal
Devuan and Openbox
64Bit
Small File Size
Refracta Tools
Base for your own distribution
#24 2017-07-24 16:28:44
MiyoLinux
the rest:
I think you're missing the end-purpose of these spins/derivatives/distros. I can only speak for myself (yes, I saw your review on SourceForge, and I'm sorry that Miyo didn't perform as you wished), so let me briefly explain the reasoning behind MiyoLinux. As the description on SourceForge says, "MiyoLinux is a minimal and base system"; therefore, one should know that it doesn't "provide" much out of the box...and that's its sole purpose. The goal was to feature Devuan...not MiyoLinux...to give users a base system to build upon.
While many experienced users can certainly create their own Openbox DE from a Devuan netinstall, there are many users who are still learning. Spins like MiyoLinux (and others) allow these users to learn, explore, and grow in their knowledge...and as FOSSuser said, there are also experienced users who want to be able to quickly install a base system. Spins like these can be installed in just a matter of a few minutes...thanks to fsmithred's work on the Refracta tools. smile
I had a few "tools" that I could have included in MiyoLinux, but I chose not to for two reasons...
1. The goal was to bring more attention to Devuan...not MiyoLinux.
2. This is my own philosophy, so please take it as such. While "tools" are neat to use and see, they aren't really used that often. Plus, they negate a person learning and delving into figuring out how to do things.
In my attempt to shine the spotlight on Devuan, I also chose to use only the Devuan repositories...again...the spotlight was Devuan...not MiyoLinux.
While these spins/derivatives/distros may not provide everything for everybody, they serve a purpose...it just may be that they don't serve the purpose that a user needs...and that's okay. There are other users who are served by their purpose(s). If a distro doesn't suit a user's purpose, there are others that will. smile
Plus, I think it says a lot that Devuan lists them on their website.
It was all about Devuan in my case friend...not MiyoLinux. wink
#25 2017-07-24 18:50:36
mckaygerhard
i think so then that miyolinux must work directly in devuan and not divert the work.. its more productive as Debian does with derivatives projects
