Pages: 1
how fix it?
root@devuan:/home/freeartist-devuan# apt upgrade
libcrypt-dev libgav1-1 libgav1-1:i386 libsframe2 libsnmp40t64 libsnmp40t64:i386 libvdpau-va-gl1 libvdpau-va-gl1:i386 tracker-extract
Upgrading:
lxqt-panel
Not upgrading:
gstreamer1.0-plugins-bad libgstreamer-plugins-bad1.0-0 libonnxruntime-providers lximage-qt lxqt-qtplugin lxqt-session pcmanfm-qt xdg-desktop-portal-lxqt
Summary:
Upgrading: 1, Installing: 0, Removing: 0, Not Upgrading: 8
1 not fully installed or removed.
Download size: 0 B / 890 kB
Space needed: 286 kB / 53.9 GB available
Continue? [Y/n]
Reading changelogs... Done
(Reading database… 409885 files and directories currently installed.)
Preparing to unpack …/lxqt-panel_2.3.2-1_amd64.deb…
Unpacking lxqt-panel (2.3.2-1) over (2.2.2-1+b1)…
dpkg: error processing archive /var/cache/apt/archives/lxqt-panel_2.3.2-1_amd64.deb (--unpack):
trying to overwrite '/etc/xdg/lxqt/panel.conf', which is also in package lxqt-branding-debian (0.14.0.7)
Error: Sub-process /usr/bin/dpkg returned an error code (1)root@devuan:/home/freeartist-devuan# apt --fix-broken install
Summary:
Upgrading: 0, Installing: 0, Removing: 0, Not Upgrading: 9
Space needed: 0 B / 53.9 GB available
Setting up openrc (0.63-2)…
Add existing services ...
* rc-update: killprocs already installed in runlevel `recovery'; skipping
* rc-update: single already installed in runlevel `recovery'; skipping
* rc-update: bootlogs already installed in runlevel `recovery'; skipping
* rc-update: console-setup.sh already installed in runlevel `default'; skipping
* rc-update: service `aksusbd.rc' does not exist
dpkg: error processing package openrc (--configure):
old openrc package postinst maintainer script subprocess failed with exit status 1
openrc
root@devuan:/home/freeartist-devuan# Last edited by deepforest (2026-01-24 23:45:28)
linux/bsd at desktop its sado-mazo game/toy for geeks/nerds with absolutely no warranty and antifool protection ©![]()
devuan broken again?
debian sid never has such issues ![]()
Ceres is always broken. You should know this by now. Once Debian fixes something, Devuan has to fix Debian's breakage of Devuan.
@golinux
Ok, thanks for reply.
Fixed by bruteforce method
1. remove weird @aksusbd idk where its come from?
/etc/init.d/aksusbd
and links
/home/freeartist-devuan/Documents/etc/rc0.d/K01aksusbd
/home/freeartist-devuan/Documents/etc/rc1.d/@K01aksusbd
/home/freeartist-devuan/Documents/etc/rc2.d/@S02aksusbd
/home/freeartist-devuan/Documents/etc/rc3.d/@S02aksusbd
/home/freeartist-devuan/Documents/etc/rc4.d/@S02aksusbd
/home/freeartist-devuan/Documents/etc/rc5.d/@S02aksusbd
/home/freeartist-devuan/Documents/etc/rc6.d/@K01aksusbd2. apply this spells for fix lxqt-panel
360 sudo dpkg -i --force-overwrite /var/cache/apt/archives/lxqt-panel_2.3.2-1_amd64.deb
361 apt install task-lxqt-desktop
362 apt --fix-broken install
363 apt install task-lxqt-desktop
364 apt install task-lxqt-desktop
365 apt reinstall task-lxqt-desktop
366 apt reinstall lxqt-panel
367 apt reinstall lxqt-core
368 sudo apt -f install
369 apt update
370 apt list --upgradable
371 apt upgrade
372 historyLast edited by deepforest (2026-01-24 23:43:40)
devuan broken again
No, this is an obvious wetware error. Specifically, the user is running the unstable branch, but lacks the wherewithal to deal with the expected packaging flux or report bugs through proper channels.
Pages: 1
