#1 2025-11-05 12:02:32
hevisko
[Solved] Debian Bookworm/(Trixie) -> Daedalus/(Excalibur)
Good day,
I'm doing quite a number of VPS deploys across various providers for anycast type reasons, and... Debian is always there... just me wanting Devuan obviously...
So: Is there some "how-to" to do a Debian-> Devuan conversion?
Typically it'll be Bookworm (Trixie still "new"), but just wondering about any gotchas documented my searchAIfu haven't yet find?
#2 2025-11-05 14:11:40
Re: [Solved] Debian Bookworm/(Trixie) -> Daedalus/(Excalibur)
Here you go!
Migrate from Debian Trixie to Excalibur
https://www.devuan.org/os/documentation … libur.html
#3 2025-11-05 15:19:16
If you're going from bookworm to excalibur, you're doing an upgrade at the same time as the migration, so it's probably a good idea to look over the upgrade instructions. One gotcha on upgrade is that you must install the usrmerge package before you upgrade.  I don't think it matters if your sources are pointed to bookworm or excalibur for that package. (I've done it both ways.)
Upgrade to Excalibur
https://www.devuan.org/os/documentation … -excalibur
#4 2025-11-05 17:38:30
rbit
This page https://www.devuan.org/os/install also contains links for bookworm -> daedalus
#5 2025-11-05 18:54:30
hevisko
Thank you all!!
Yeah, missed those pages, now I can go convert some...
Q: Any have an ansible playbook handy to do these ?
