#1 2025-06-24 00:05:34
LibertySysadmin
How to Install XLibre on Devuan Daedalus (MATE)?
Hi all,
I’m currently running Devuan Daedalus with the MATE desktop and I’m interested in installing XLibre. I wasn’t able to find much documentation on how to set it up, and wanted to ask if anyone here has experience with it.
Is there a recommended method for installing XLibre on Devuan?
Do I need to remove or disable anything MATE-related beforehand?
Any potential conflicts I should watch out for?
Thanks in advance for your help. I really appreciate how clean and sane Devuan is — this distro just makes sense.
#2 2025-06-24 00:48:25
Re: How to Install XLibre on Devuan Daedalus (MATE)?
Welcome to paradise erm Devuan! AFAIK, no one in this camp has experimented with XLibre. Perhaps you would like to lead the testing and adaptation of XLibre for Devuan?
#3 2025-06-24 00:56:08
sagemage
I would be inclined to wait until a bleeding edge distro like Artix Linux has it in their somewhat stable galaxy (main) repo, its still in testing there.
https://packages.artixlinux.org/package … e-xserver/
You could give it a try though, im sure if you joined xlibre mailing list,telegram,matrix chat they might be able to help you out.
https://github.com/X11Libre/xserver
https://www.freelists.org/list/xlibre
https://t.me/x11dev
https://matrix.to/#/#xlibre:matrix.org
#4 2025-06-24 05:24:35
LibertySysadmin
@golinux — Haha, paradise indeed! I might just take you up on that challenge. I’ll start poking around and see how far I can get with XLibre on Daedalus. If I make progress, I’ll report back here and possibly write up a guide for others down the line.
#5 2025-06-24 05:25:07
LibertySysadmin
@sagemage — Appreciate the links! I agree, letting it bake a little longer in the Artix galaxy repo might be the cautious route. But I’m also curious enough to explore, especially since I’m running this on non-critical hardware. I’ll check out the GitHub and join the Matrix or Telegram chats as I dig in.
Thanks again to both of you — great to see such a helpful community!
#6 2025-06-24 06:25:32
brocashelm
@LibertySysadmin:
If you use IRC, there's also an #xlibre channel at irc.libera.chat. smile
#7 2025-06-24 16:32:30
yurimodin
Kinda goes against the Debian/Devuan Stable philosophy but good luck. You would probobly have an easier time in Sid/Ceres.
Keep in mind this is the very first release and even they say its Beta out of caution because stuff will break with a hard fork like this. I would suggest you give them a couple months to get settled in and by then somebody will probobly get a repo spun up etc.
#8 2025-06-24 19:24:03
LibertySysadmin
Thanks @brocashelm — hadn’t thought to check IRC but I’ll jump into #xlibre on libera.chat and see what I can learn. Appreciate the tip!
#9 2025-06-24 19:25:40
LibertySysadmin
That’s fair @yurimodin, and I respect Devuan’s stable-first approach.
That said, I’d argue the current display server landscape isn’t exactly “safe” either.
Xorg is essentially frozen — it's stable, yes, but also unmaintained long-term.
Wayland is being pushed hard, but it's still missing critical features and app compatibility for many users.
So in a weird way, trying out XLibre doesn’t feel any riskier — especially since it’s actively being developed to preserve familiar X11 behavior with a cleaner codebase.
I’m definitely not planning to run it in production — just testing on spare hardware to stay ahead of the curve and contribute if I can.
#10 2025-06-24 20:27:53
yurimodin
@LibertySysadmin
No harm in testing. I usually get something exotic like that sorted out in a VM first then goto HW.
#11 2025-06-25 03:18:22
I am not brave enough to try running xenocara or xlibre from a source build myself.
So I say, you bold.
#12 2025-06-25 03:44:27
@golinux I hear steve_v was trying to compile it for that purpose.
I don't know if he did.
#13 2025-06-25 10:54:02
I built Xlibre on Gentoo, because that's my main these days and the only Devuan installs I have are headless servers I'm not about to screw around with for something they wouldn't even use.
There is now an overlay hosted at github.com/X11Libre/ports-gentoo, so trying it on Gentoo is no more difficult than installing any other live build.
I see no reason the xlibre devs would be against a similar arrangement for Devuan, were somebody with an appropriate build environment to adapt the Xorg spec files and build test packages. That shouldn't be particularly difficult to do (though personally I find the Debian packaging workflow somewhat convoluted and unpleasant), since the project structure is still very close to Xorg.
I mean I could probably do it in a VM or chroot, but not to put too fine a point on it... That's a lot of mucking about and the lack of effort from anyone else around here (who, unlike me, stand to benefit directly) isn't particularly motivating.
#14 2025-06-25 13:22:36
JWM-Kit
So true! Thank you for saying it. Creating a PKBUILD, RPM spec, and other type packaging build is so simple.  Yet Debian is so complicated.  Debian really needs a better system.
steve_v wrote:
I mean I could probably do it in a VM . . .
I've thought about trying a VM.  I just don't know when I'd find the time though.  I must say though, I am excited about Xlibre.
#15 2025-06-25 17:23:53
Bro, the project is literally in it's infancy, I only heard about it here when brocashelm posted about it. Cut us some slack, give us time to catch up...we all have busy lives outside of linux. There's plenty of Devuan folk on the xlibre IRC channel right now who are interested in helping, myself included.
#16 2025-06-26 05:33:11
Oh that wasn't meant for you, you're making things. It was for the "I bet it could be done", "not brave enough", "I do hope that SOMEONE will", "above my pay grade", "Perhaps you would like to" bikeshedding crowd.
#17 2025-06-28 00:56:41
@steve_v bikeshedding crowd? What the hell is that?
You sure use some unusual analogies
#18 2025-06-28 03:34:08
re: bikeshed, bikeshedding, i.e. law of triviality
https://en.wikipedia.org/wiki/Law_of_triviality
#19 2025-06-28 04:25:43
The ongoing trend of endless talk about politics, ideology, and trivia such as the personality of individual contributors or wording of a readme, all while "hoping" "someone" (else) will do the real work.
There is no "brave enough" in software development, and there is no danger in trying.
If you put as much energy into learning to compile or contribute to projects that you claim interest you as you do political ranting, you might even have some substance (i.e. technical points) to add to your usual "I hate [x], because feels/language/supposed power imbalance" nonsense.
Don't like "frog animations" (or whatever latest pointless rant was about)? Easy, don't look at them. Do something constructive instead.
Think xenocera is a better option for Devuan than xlibre? Cool, why not spend that energy compiling them on Devuan, testing them, and making a convincing case for one over the other?
You constantly spit bile at people and projects you don't like, yet those people and projects have, undeniably, made something. What have you made, besides noise?
You insult GNOME devs, but those GNOME devs made a complete desktop environment and gave it away for free, to all and sundry. You call youtubers you disagree with "parasites",  yet even they put effort into learning video production and built a following... Where's your channel? Where's your competitor for gnome or wayland?
The real "Irony, irony, irony" here is that you depend entirely on software built by others, to insult the people who build such software.
IOW, define:parasite
#20 2025-06-28 10:09:40
@steve_v wrong thread pretty sure. If you are going to get pissed at me, at least respond correctly on the thread where you say I offended you.
Also, I don't use GNOME. I never really used GNOME much. MATE? Yeah, but if GNOME disappeared, or for that matter, every DE, I wouldn't care at all.
Especially GNOME3 and forks of it or KDE 5+ or GNOME 4 and similar.
My point being, I find fault with GNOME precisely because I find it unusable without crap and it doesn't offer much to me in the first place.
I have tried it, but it sucks. Lumina Desktop, LXDE and XFCE4 and MATE look fine.
But DEs usually require unneeded dependencies anyhow so... its a waste.
#21 2025-06-28 10:47:33
What difference would it make, you do the same...
find fault
unusable
crap
it sucks
its a waste
Everywhere you go.
Then, if anyone should dare propose an improvement to this supposedly terrible situation, out comes the...
Why not try
You moan, but you do not do. You rubbish free software, but you do not work on it, even to help yourself. You insult groups and individuals, you belittle their achievements, but you will not even attempt works comparable to theirs.
Your sole contribution to a thread asking how to do a thing is to state that you're not brave enough to try, but someone else might... And even there, you misrepresent my statement.
In any case, I'm done with this thread, and I'm tired of the whinging and politics on this board in general. I'm currently running xlibre on Gentoo, and If anyone wants to try it on Devuan I invite you to read the extensive Debian packaging docs and figure it out.
Otherwise, feel free to hop over to a distro/board/irc channel with less moaning and more doing.
#22 2025-06-28 11:00:58
trinidad
Yikes!! There's actually no real peer to Debian packaging. I guess you mean better than itself?
TC
Often unawares.
#23 2025-06-28 14:06:51
Please keep off-topic stuff down in the off-topic section. Unless of course it's funny as hell like "Xlibre ate my ram".
#24 2025-06-29 03:01:56
@steve_v oh the humanity, I dare to have a different opinion than you! I won't stay quiet so I keep saying how I feel!
God forbid I do that!
I should just never say another word on here and let you vilify me as much as you want without any checks or balances.
I am sorry I didn't realize this!
/s
#25 2025-06-29 04:09:22
^^^FFS just stop, we're all in this together. Lets focus on creating something new and better instead of bitching and arguing.
