#1 2017-06-14 00:30:57
keb
how to install ffmpeg
i want to install ffmpeg, which doesnt show up in a search in synaptic or aptitude.
i tried to add the repository to /etc/apt/sources.list.d/devuan.list as
deb https://git.devuan.org/devuan-packages/ jessie main
but it gets an error with https not supported
so then i installed apt-transport-https
but after that i get a GPG error:
E: GPG error: https://git.devuan.org jessie InRelease: Clearsigned file isn't valid, got 'NODATA' (does the network require authentication?)
how do i get the repo keys or where is the correct repo?
#2 2017-06-14 00:50:54
Re: how to install ffmpeg
Hi keb,
You will need to get ffmpeg from http://www.deb-multimedia.org/
You'll need to install the deb-multimedia-keyring and add this to your sources.list
deb http://www.deb-multimedia.org/ jessie main
#3 2017-06-14 01:04:29
keb
thanks!
i will change the topic title to ffmpeg
#4 2017-06-14 03:27:25
jessie-backports has the same version of ffmpeg that's in testing.  7:3.2.5-1~bpo8+1
