#1 2024-11-29 14:04:32
Ron
[SOLVED] Just reinstalled - can't connect to repos
I just reinstalled the OS (crowz), and I can't connect to the repos to update the system. Does anybody know if the repos are down? I never had this problem before when reinstalling. Thanks.
#2 2024-11-29 14:55:43
Alverstone
Re: [SOLVED] Just reinstalled - can't connect to repos
Show your /etc/apt/sources.list or /etc/apt/sources.list.d depending on what you use. There isn't a Devuan release with the name 'crowz'.
#3 2024-11-29 15:11:44
Just updated my Daedalus, update worked fine.
#4 2024-11-29 15:31:41
But there is! Crowz is a Devuan derivative that has been around for years. You might want to have a look at this list of other Devuan derivatives. wink
#5 2024-11-29 15:48:37
Been some issues with dev.devuan.org for a while now, couple of other threads on here about it.
Here's what's working for me currently in sources.list:
deb http://gnlug.org/pub/devuan/merged daedalus main
deb http://gnlug.org/pub/devuan/merged daedalus-updates main
deb http://gnlug.org/pub/devuan/merged daedalus-security main
#6 2024-11-29 20:36:39
Ron
Yeah, in my haste I forgot. What threw me was having the problem immediately after a reinstall (which never happened to me before). Followed certain advice and got connected to the repos and updated. Thanks everyone.
