#1 2024-07-10 21:48:43
Carolina In My Mind
does the Brave browser work here?
The reason I ask is: I was going to try the Devuan-based version of Peppermint, but Brave won't install in it. I don't have the error message to quote, but it indicated that the problem wasn't the installed browser (obviously not, since I didn't get to install it) but an issue with the relevant repository. It had to be specific to Peppermint, because my Brave browser installs and upgrades perfectly well in MX, my current distro.
Anyway, can anyone tell me whether Brave is expected to work in Devuan, before I get Devuan running on my computer?
#2 2024-07-10 23:56:20
nixer
Re: does the Brave browser work here?
It runs fine for me on ceres (unstable).  I also have it installed on excalibur (testing), and daedalus (stable).  It is installed with apt with the brave repository active.  But note, I have not booted into the stable and testing install in a while so I don't know if it runs, but it installs and updates without error.
#3 2024-07-11 00:53:48
There are quite a few Brave users here but alas, not me . . .
#4 2024-07-11 03:05:53
zephyr
Carolina In My Mind wrote: Anyway, can anyone tell me whether Brave is expected to work in Devuan, before I get Devuan running on my computer?
Yes, I have it installed on Crowz, daedalus.  Thought I would go ahead and check and see if it would. No problems.
This is from https://brave.com/linux/
sudo apt install curl
sudo curl -fsSLo /usr/share/keyrings/brave-browser-archive-keyring.gpg https://brave-browser-apt-release.s3.brave.com/brave-browser-archive-keyring.gpg
echo "deb [signed-by=/usr/share/keyrings/brave-browser-archive-keyring.gpg] https://brave-browser-apt-release.s3.brave.com/ stable main"|sudo tee /etc/apt/sources.list.d/brave-browser-release.list
sudo apt update
sudo apt install brave-browser
cheers
zephyr
CROWZ
#5 2024-07-11 11:40:01
Hello.
Just install Brave browser as flatpak. They released official flatpak images
https://flathub.org/apps/com.brave.Browser
#6 2024-07-11 18:40:14
pl
Flatpak tows far too much bloat into the system (and don't play well with doing desktop entries and the like (At least I've heard so...))
In fact Brave itself discourages from using it anyway:
https://brave.com/linux/#flatpak
Brave is available as a Flatpak package from Flathub. While it is maintained by Brave Software, it is not yet working as well as our native packages. We currently recommend that users who are able to use our official package repositories do so instead of using the Flatpak.
Doing it with .deb packages is simply better
Bound for better weather...
#7 2024-07-12 06:45:25
EDX-0
perchance.
fetch_keyrin (){
  curl -fsSLo \
    /usr/share/keyrings/brave-browser-archive-keyring.gpg \
add_sources () {
  debsrc="deb [signed-by=/usr/share/keyrings/brave-browser-archive-keyring.gpg] https://brave-browser-apt-release.s3.brave.com/ stable main"
  echo "$debsrc" \
install_brave () {
  apt update
  apt install brave-browser -y
main () {
  fetch_keyrin
  add_sources
  install_brave
case "$1" in
  run)
    main
  install)
    if [ ! "$( id -u )" -eq 0 ]; then
      main
    else
      pkexec sudo "$0" "run"
    fi
esac
the script is very dumb and the use of pkexec is if for example you want to run the script from some graphic prompt or program like a welcome center or the sort that is running unpriviledged.
it also detects if it was ran with sudo directly and skips the whole pkexec business.
#8 2024-07-12 07:46:55
grafiksinc
I am actually running Pep Devuan, with Brave you do have to run the stuff the folks posted above but its work smooth....  smile
#9 2024-07-13 23:57:05
Xenguy
Brave works fine here.  The best option is to install by adding the Brave repo to sources.list and then install with apt-get.
Follow the instructions on the Brave web site.  Avoid flatpak, it is bad advice.  Neither are bespoke scripts necessary.  Good luck, and if you have further questions, post here again.  Feel free to let us know if things worked out or not.
#10 2024-07-31 13:16:37
igorzwx
Brave works without problems
_https://brave.com/linux/#release-channel-installation
Release Channel Installation
Debian, Ubuntu, Mint
sudo apt update
#11 2024-07-31 18:56:52
sgage
Brave works fine in Daedalus (and every other distro I've tried it on). I just use the recipe on their website - you get the latest version, plus updates with all your other packages.
#12 2024-08-27 21:05:27
Thought i'd add a quickie tip:
Installed a little earlier, but when opening it gave me a message explaining keyring wasn't unlocked, and wanted a password, had to hit "cancel" to clear it and it popped up again, I canceled again and browser finally opened. But it would do this every time I opened it, found a simple solution on another forum.
Open your menu editor (I use mozo on MATE) and find your properties tab, then edit the opening command with this appended to it:
a space, then
--password-store=basic
That turned it off for me, current Daedalus.
#13 2026-01-27 12:14:34
commentary on browsers, see especially regarding Brave
https://pivot-to-ai.com/2025/12/23/firefox-browser-falls-to-ai-what-do-we-do-now/
I’m going to get a bunch of gullible fools recommending Brave. Brave was founded by Brendan Eich, the inventor of JavaScript, after he was kicked out of Mozilla for being a massive homophobe. Brave is into weird cryptocurrency nonsense and I’ve written up their dodgy behaviours in the past. Brave also has a whole webpage about how much they love AI. So Brave is not the non-AI option. Stop recommending people use Brave.
#14 2026-01-27 13:33:30
Okay, a year and a half on, still using it, nothing about crypto or AI either one intrudes on my use, the built-in adblocking is very good, the browser hasn't acted homophobic yet, and best part of all: It's NOT Firefox, it actually has human useable scrollbars that don't act retarded.
#15 2026-01-27 14:12:45
Intresting. How many websites use javascript? I hope he doesn't use any of them
SOURCEFORGE rations
#16 2026-01-27 14:40:44
tux_99
be careful what you write, calling somebody a "massive homophobe" just because he donated to California Proposition 8 which called for the banning of same-sex marriage in California, could be considered slander, even if you are just quoting somebody else as you aren't distancing yourself from the content of that quote.
Being against "gay marriage" does not at all mean being a  "massive homophobe".
“Either the users control the program – or the program controls the users” Richard Stallman
#17 2026-01-27 21:49:52
We'll stop here.
