#1 2024-04-05 20:47:52
oui
it works! it works well... CeresKDEminiOnJwmFull
build with the actual refracta nox ISO 32 bit (stable)
step 1:  actualized
step 2: snapshooted
step 3: fullfilled fat with all serious apps of KDE plus Xfce4-Appfinder, Xfce4-Terminal, mousepad and thunar (as I did renounce to install Konqueror, but it would be possible without inconvenient! It is only so, that I do all that primary for me and and don't will spend time to relearn dolphin. The file manager that I know is important for me to work fast enough...) that on an naked installation of Jwm with menu and a beautiful background. My actual kde base is the package for CLI (search with aptitude search kde!). It would be possible to procede analog with the analog package for Openbox or for Kde Standard or for Plasma Desktop. If the KDE menu does not appear, add the package qml-module-org-kde-kitemmodels!
step 4: snapshooted (1.9 GB)
you can probably risk to use it! it comes from "stable" (add slim or other one it it works well)...
step 5: change the content of /etc/apt/sources.list (keep the first active row and write "testing" where you read "daedalus")
step 6: remove slim if installed for your productive version!
step 7: actualize
step 8: do upgrade using synaptic (it seems to work better than apt itself) keeping all Refracta scripts!
more than 1000 package will be actualized,
step 9: a good apt autoremove!
step 10: perhaps an inspection with deborphan (be VERY prudent!)
step 11: snapshooted (2.2 GB)
step 12: try to reboot and start the "testing" stage
(it contains probably 3 kernels. For my PC I did have to reactivate the most older of the 3; to that, open the terminal and go to / and mv the 2 present kernel and initrd.img into ....new and ....last and (remake a link to to /boot/,,,,.img and /boot/vmlinuz-.... !)
probably it is good and you (already! actually, also today, the upgrade to "ceres" will make no change! Just continue to have an ISO more to "nurse" in the next times...) have success!
step 13: continue like step 5 and following steps with "ceres" instead of "testing" and nurse in the next times: you have a rolling mini KDE, enjoy it!
Contain of my /usr/share/applications:
breezestyleconfig.desktop calligra.desktop ceni.desktop com.rosegardenmusic.rosegarden.desktop feh.desktop gimagereader-gtk.desktop htop.desktop info.desktop kcm_breezedecoration.desktop kcm_cddb.desktop kcm_filetypes.desktop kcm_kamera.desktop kcm_kdeconnect.desktop kcm_trash.desktop kdesystemsettings.desktop krita_brush.desktop krita_csv.desktop krita_exr.desktop krita_gif.desktop krita_heif.desktop krita_heightmap.desktop krita_jp2.desktop krita_jpeg.desktop krita_jxl.desktop krita_kra.desktop krita_krz.desktop krita_ora.desktop krita_pdf.desktop krita_png.desktop krita_psd.desktop krita_qimageio.desktop krita_raw.desktop krita_spriter.desktop krita_svg.desktop krita_tga.desktop krita_tiff.desktop krita_webp.desktop krita_xcf.desktop ktelnetservice5.desktop links2.desktop marble_geo.desktop marble_geojson.desktop marble_gpx.desktop marble_kml.desktop marble_kmz.desktop marble_shp.desktop marble_worldwind.desktop mimeinfo.cache okularApplication_comicbook.desktop okularApplication_dvi.desktop okularApplication_fax.desktop okularApplication_fb.desktop okularApplication_ghostview.desktop okularApplication_kimgio.desktop okularApplication_mobi.desktop okularApplication_pdf.desktop okularApplication_plucker.desktop okularApplication_txt.desktop okularApplication_xps.desktop org.kde.calligrasheets.desktop org.kde.calligrastage.desktop org.kde.calligrawords_ascii.desktop org.kde.calligrawords.desktop org.kde.digikam.desktop org.kde.dragonplayer.desktop org.kde.elisa.desktop org.kde.falkon.desktop org.kde.gwenview.desktop org.kde.gwenview_importer.desktop org.kde.juk.desktop org.kde.kaffeine.desktop org.kde.karbon.desktop org.kde.kcolorchooser.desktop org.kde.kdeconnect.app.desktop org.kde.kdeconnect.daemon.desktop org.kde.kdeconnect.handler.desktop org.kde.kdeconnect.nonplasma.desktop org.kde.kdeconnect-settings.desktop org.kde.kdeconnect.sms.desktop org.kde.kded5.desktop org.kde.kdenlive.desktop org.kde.kdiff3.desktop org.kde.keditfiletype.desktop org.kde.kmix.desktop org.kde.knewstuff-dialog.desktop org.kde.kolourpaint.desktop org.kde.kompare.desktop org.kde.krita.desktop org.kde.kruler.desktop org.kde.kstars.desktop org.kde.ktrip.desktop org.kde.kturtle.desktop org.kde.kwalletd5.desktop org.kde.kwave.desktop org.kde.marble.desktop org.kde.okular.desktop org.kde.parley.desktop org.kde.plasma.settings.open.desktop org.kde.skanlite.desktop org.kde.skanpage.desktop org.kde.spectacle.desktop org.xfce.mousepad.desktop org.xfce.mousepad-settings.desktop pppoeconf.desktop python3.11.desktop synaptic.desktop systemsettings.desktop thunar-bulk-rename.desktop thunar.desktop thunar-settings.desktop vim.desktop xfce4-appfinder.desktop xfce4-run.desktop xfce4-terminal.desktop xfce4-terminal-settings.desktop
#2 2024-04-05 22:41:22
Re: it works! it works well... CeresKDEminiOnJwmFull
I am posting this at fsmithred's request.
Please cease and desist using Refracta*  in the title/name of your isos and instead create a unique name to identify your efforts.
Thank you
#3 2024-04-06 07:42:54
oui
Like on the bike path when you overtake a horse with the mountain bike: some riders are afraid that you rings because the animal bounces, and on the contrary, the others want to report in advance! This is how it is with the developers: some are bad if they are not mentioned (person or/and system), even if they supposedly call the software freely, and others like fsmithred years do nothing, then others do something out of pure enthusiasm (me If my first attempts in the first half of 2023 before the new Refracta-Isos were released, only my problems with the Devuan Kernel, I have to say, because there is no core problem with Ubuntu); in the announcement of this new isos, the author clearly explained that there was an overdue need. Linux has become that came from open and free source ...
Another note: I did not want to upload this ISO at all but only explain how to build it, because once explain everything else can replace everything! There are also forums for that too ...
(Google did above translate: Wie auf dem Radweg wenn man mit dem Mountainbike ein Pferd überholt: Manche Reiter haben Angst davor, dass man klingelt, weil das Tier hüpft, und die anderen möchten im Gegenteil, dass man vorab sich meldet! So ist es mit den Entwicklern: Manche nehmen übel, wenn sie (Person oder/und System) nicht genannt werden, auch wenn sie angeblich die Software frei nennen, und andere wie fsmithred tun Jahre nichts, dann tun andere aus purer Begeisterung was (ich tat meine ersten Gehversuche in der ersten Hälfte von 2023 bevor die neuen Refracta-Isos veröffentlicht wurden, nur meine Probleme mit den Devuan-Kernel, ich muss so sagen, denn bei Ubuntu gibt es kein Kernelproblem, haben mich verzögert; aus meinen Wortmeldung im Forum und den Datums kann man das aber gut ableiten)! In der Ankündigung dieser neuen ISOs hat der Autor aber klar erklärt, es gab einen überfälligen Bedarf. Ok, ich werde nie mehr von Refracta reden, aber den Stoff ungezügelt integrieren, da es sowieso ein freier Linux-Stoff geworden ist, der aus open and free source kam...
Noch ein Hinweis: Ich wollte diese ISO gar nicht hochladen sondern nur erklären wie man es baut, weil ein Mal erklären alles weitere ersetzen vermag! Dazu sind auch Foren auch da...)
#4 2024-04-06 21:26:44
Oui, please, stop bloating this forum with superfluous information. The list of your /usr/share/applications contents has no interest at all.
#5 2024-04-06 21:33:40
Well said, aitor. Closing this topic.
