#1 2024-02-18 18:01:24
torquebar
upgrade Chimaera with Daedelus?
After having had some issues with Chimaera on my AMD desktop I managed to recover a backed up disk image, got it updated and all is well. But progress is progress and rather than suffer through tweaking a new install I was just wondering if the Daedelus dvd can be used to upgrade a Chimaera system like Suse Tumbleweed can be updated from a dvd OR from the repos?
Who, has loved us more?
#2 2024-02-18 18:15:18
Re: upgrade Chimaera with Daedelus?
Can't you just do it in a terminal? A disc shouldn't be needed for a dist upgrade. Or so I remember seeing on this forum. I have not done it myself that I can remember.
#3 2024-02-18 18:19:18
When the PC is online on the internet, an update is easily done via the console, I have done it already without issues. Prepare yourself by reading the available documentation:
https://files.devuan.org/devuan_daedalu … _notes.txt
https://www.devuan.org/os/documentation … o-daedalus
https://www.devuan.org/os/install
#4 2024-02-18 20:04:43
torquebar
Thanks for the helpfulness but that's not what I meant. I do online updating regularly. Can I boot with a Daedelus installation DVD to upgrade my Chimaera system? The only thing I've ever done with Devuan is Chimaera as it was the first one I ever installed and am still using it (except my laptop which has Daedelus). Or, if I update each of a  Chimara and a Daedelus system will they in fact both become the same for all intent and purpose? Suse installation DVD's give me a choive top install, upgrade, or boot into a rescue system but I haven't done three Devuan installs to remember what was offered.
my Devuan desktop: https://imgur.com/x2A9zHw.png
#5 2024-02-18 20:27:20
The Daedalus DVD does allow to install Daedalus over Chimaera, its no upgrade. I am not aware of any easy way to use the DVD for the purpose of an upgrade. The DVD may be used as rescue system easily.
The upgraded Chimaera will be mostly like a newly installed Daedalus, except for specialities you may have installed and if you choose to keep the old configs. For sure you will have one or the other orphaned config or other remainders of older SW.
In some cases an upgrade will fail. The release notes usually give hints what to look for and what to pay attention to.
#6 2024-02-19 12:25:07
Maybe it's not my thing, but I think the easiest way would be to do a clean install of Daedalus.
#7 2024-02-21 06:42:02
definitely a clean install is best. when i prepare and partition a new hdd/ssd i always reserve several partitions for future newer versions(or completely different operating systems). and they are always there if i need to use them for some temporary purpose. don't forget a bullet-proof back-up plan!
#8 2024-02-21 13:51:25
UnixMan1230
While you cannot directly boot the CDROM and upgrade with it, you CAN upgrade your packages to a limited extent with it.
The following assumes you have the 4.5GB Desktop ISO, and that you have NOT added packages beyond what was available in Chimaera's Desktop ISO.
(I am putting this here in the hopes that others who look at this may find it helpful in some way)
Run the following:
sudo apt-cdrom add
from here, you will be prompted to insert the DVD into the DVD drive, at this point you should do so. If it is NOT on a DVD, but rather a flash drive, you need to open another terminal and run the following BEFORE proceeding further with apt-cdrom:
sudo mount /dev/(your usb) /media/cdrom
if that directory does not exist, create it with:
sudo mkdir /media/cdrom
and then mount the usb. Go back to the terminal that has apt-cdrom running, and press enter.
By this point, apt-cdrom will likely register the CDROM. From here, do:
sudo nano /etc/apt/sources.list
and ensure ALL Chimaera sources are disabled. After finishing with nano, and saving the new sources.list, run:
sudo apt update && sudo apt dist-upgrade
and look over what all will be upgraded and/or removed. If all looks good, you can press enter to proceed. From there, your system should upgrade, and once complete, a simple reboot will be sufficient to boot into your new Daedalus system.
"Less is only more when it's what you're looking for" -Unknown
"Who do I need to fuck to get standard font size and panel options?" - Linus Torvalds
#9 2024-02-21 16:10:33
Thanks Unixman1230, I'll definitely  try this soon.
One thing I've been doing for quite some time is backing-up /root, /boot and /etc to a folder in my home directory partition.
This allows me to reinstate any config files I have changed/customised.
Of course you will require a separate partition for /home and not format it during an install.
But this apt-cdom approach may alleviate that concern.
I have tried mounting iso's, but generally get an error about either no release file or checksums.
Thanks again.
#10 2024-02-22 01:12:01
UnixMan1230
@GlennW This is because you need to do one of two things, which I completely forgot to add to the above:
In order to NOT have issues with the untrusted CDROM source (Neither Debian nor Devuan can furnish release files in them, it would be pointless since they are static), you have to do one of the following...
When you update with apt, do
sudo apt update --allow-insecure-repositories
OR, alternatively, in /etc/apt/sources.list, change the cdrom entry from
deb cdrom_source_name daedalus main
to
deb [trusted=yes] cdrom_source_name daedalus main
I hope this helps! It will not cover all of your packages if you installed something outside of the CDROM from chimaera, but even if you only use this in conjunction with internet access on the actual daedalus repos, it can STILL save you trouble by not having to waste bandwidth on the packages you already have stored on the CDROM.
I should also mention that the above about saving bandwidth is also applicable to the server and netinstall ISO's, you can use those too!
#11 2024-02-22 21:55:38
Thank you, saving bandwidth is precisely why I want to try it.
#12 2024-08-14 00:15:36
torquebar
stargate-sg1-cheyenne-mt:
I do that too, there was a time when I booted a different distro every day of the week and had several backlevels of each ready to be booted. I'm now down to 5 as I leave only Suse as a sole systemd system.
A clean install means a LOT of tweaking, like two weeks worth, which is why I asked. Suse lets you upgrade a version with the DVD of a more recent one (getting a same system up to par is called and upDATE not an upgrade).
So now that I have done a Daedalus clean install I cant' get on line to even start tweaking.
lspci
Bus 002 Device 004: ID 13b1:003e Linksys AE6000 802.11a/b/g/n/ac Wireless Adapter [MediaTek MT7610U]
Bus 007 Device 004: ID 0bda:8179 Realtek Semiconductor Corp. RTL8188EUS 802.11n Wireless Network Adapter
Bus 001 Device 005: ID 0bda:b812 Realtek Semiconductor Corp. RTL88x2bu [AC1200 Techkey]
Those are the 3 USB wifi transceivers*, NetworkManager is running, but none of them work (using one of them in Slackware presently).
I use ONLY USB WiFi and only removable racked/backplane drives as they allow physical control and thus aren't the huge security hole that wired-in onboard versions are.
Edited addendum:
I have no idea how but wifi just works. Maybe NetworkManager isn't automatically restarted after every config edit and so next day's reboot is what did it.
As for upgrading without having to retweak everything:
There are two things that are important to ME
1
my favorite apps and of course all those they pull in as depends
2
my desktop and my custom icons*
I keep my home folder (but not all my user folders) on a remote drive. I just moved my data to a new ssd and on that partition mounted under /0/data  is a UserMe folder hosting among others a Dev folder. This Dev folder is my actual Devuan UserMe home so in my Dev system /home/UserMe is a link to /0/data/UserMe/Dev.  This means that on a fresh install such as what I just did all I have to do is get /0/data mounted in fstab and drop a link in /home as above. As soon as I log in my old home is my new home just like that.
This comes in to make things easy when I need my apps installed, many already being installed as part of most distros' standard fare; some will need my icons edited back into their configs, I just go down both sidebar panels and the ones that won't launch are the ones that need to be reinstalled.
This was my old Dev DT and is already my new one EXACTLY the same as before, zero changes.
https://imgur.com/screenshot-x2A9zHw
All I have to do nwext is install a small group of apps that don't sjhow in Synaptic (that'll be another topic).
* custom icons such as NedIt in the lower left panel and kdiff3 to its left.
#13 2026-10-23 00:57:25
SlySven
I'm about to try this as the PC I'm doing it for (not my primary machine) cannot update from the Chimaera repositories any more because they have been archived and the corresponding upstream Debian packages needed to update the existing Chimaera system are not in the expected place either - so it is not possible to do the sudo apt upgrade of the Chimaera installation prior to editing the /etc/apt/sources.list.
#14 2026-10-23 01:30:36
I'm sure you know that upgrade at any time is totally fine, with or without reason.
#15 2026-10-23 01:42:23
Mercury
I have done this recently, but not with a DVD image as the OP suggests. Only the regular 5.0 daedalus repositories need to be set up.
(Aside: I put them in /etc/apt/sources.list.d/daedalus.list instead of the main sources.list so they can be turned off and on by changing the file extension instead of going in and commenting lines.)
Even on a mediocre internet connection it doesn't take that long to pull all the necessary packages.
#16 2026-10-23 09:46:54
Where is the problem? Yes, Bookworm and Chimaera have been archived. The final update of Chimaera still is possible, you simply have to switch your sources.list to archive like this here:
# Changed to archive on Oct 23rd 2026, rh
deb http://archive.devuan.org/merged chimaera main contrib non-free
deb http://archive.devuan.org/merged chimaera-security main contrib non-free
deb http://archive.devuan.org/merged chimaera-updates main contrib non-free
deb http://archive.devuan.org/merged chimaera-backports main contrib non-free
Updating your installation against this sources will work fine.
#17 2026-10-23 11:21:54
pcalvert
I agree completely. I prefer to start over with a "clean slate". And my experience dist-upgrading Devuan (Refracta, actually) to a new major version has only served to reinforce that behavior.
The first time I tried this, the result was a totally trashed system that wouldn't even boot. That was several years ago. I briefly tried to repair the system, but my efforts seemed futile, so I ended up restoring the older system from a partition-image backup that I made just prior to the upgrade attempt.
More recently, I upgraded a Daedalus-based Refracta system to Excalibur. That worked, for the most part, and the system is usable. However, a few things did break, and they are still broken. Although I did try to troubleshoot and fix the main problem, my efforts led nowhere so I gave up. Since 99.99+% of the system is still usable, for my purposes, I didn't want to spend any more time trying to fix the parts that are broken.
Another one is called Luxxle.
#18 2026-10-25 13:03:34
SlySven
I also had a resolveconf problem which was producing all sorts of connectivity problems (hence not being able to download packages) and I had miss-spelled "daedalus" as "deadalus" in /etc/apt/sources.list - so multiple issues were impacting each other!
This is an old, limited, 686 32-bit machine with only the Devuan OS mainly used as a local (LAN) repository backup for some projects I code - and as an emergency backup machine when my main triple-boot Desktop has problems.
Anyhow the information on how to work from CD/DVD/Usb thumbdrive did help me resolve this and I was glad it was covered here.
