#1 2023-12-23 18:58:25
linux-image-6.1.0-16-amd64
They forgot to enable some option in this kernel.
Adjusting the laptop brightness using the keyboard buttons, working with the linux-image-6.1.0-11-amd64 kernel, stopped working after the upgrade.
And powersave says "Brightness adjustment is not supported" with this kernel.
#2 2023-12-23 20:33:42
Re: linux-image-6.1.0-16-amd64
Perhaps they are wanting to see if anyone will notice on the way to deprecating these functions entirely? Maybe you could file a bug with the kernel folks . . .
