#1 2023-11-23 08:48:28
oneofthehorses
Making Devuan widely use
Hello!
I'm courious if i can find any entusiast person with who together we can make "fresh" modern looking build of Devuan with already installed software such ass librewolf (instead firefox and also cool addons and hardened settings), keepassxc, veracryppt, simplex chat, element and other useful daily programs so end user can be comfortable to openbox using it?
Also making icons and look in general closer to linux mint
All steps that were made will be in final .odt or pdf for transperancy
Thanks smile
#2 2023-11-23 10:36:25
Re: Making Devuan widely use
If you want it to look like Mint, just use Mint.....
Devuan has its own look & feel.... big_smile
But, you can modify it if you want, that's what Linux is all about. smile
#3 2023-11-23 13:33:31
manyroads
IMHO Cosmetics are always a matter of opinion.  FWIW I would suggest that it is more useful and productive to compare Devuan to Debian than it is to compare Devuan to LinuxMint.  Mint, to my mind, is more similar to Manjaro than it is Devuan....
Having said that, it is an easy task to make one distro look like another (enjoy the transformation process).
Pax vobiscum,
Mark Rabideau - ManyRoads
dwm, i3wm, openbox on debian test ~ Linux #449130
#4 2023-11-23 16:03:39
@oneofthehorses . . .
You are not the first to suggest a Mint Edition of Devuan. Back in 2018 someone contacted me about doing just what you are proposing but it never materialized . . .
Are you aware that Devuan has a thriving list of "Devuan Derivatives"? Feel free to do your thing and offer it there.
#5 2023-11-24 06:26:41
oneofthehorses
Cool!
I will try to present mine version into Devuan Derivatives when it be ready. Did't knew it before
At the moment collecting cool stuff and features so it can paint it a little bit more from other ones smile
#6 2023-11-24 07:52:09
oui
Note: You will probably need to compile a lot yourself and we will meet you soon here https://dev1galaxy.org/viewforum.php?id=26 ! Good luck...
