#1 2023-10-31 10:12:02
Charon795
no sound on gnuinos
Hi all! Installed "Gnuinos" today - a distribution approved by the Free Software Foundation
And I ran into a problem: I have no sound.
In xfce, amixer-gtk is installed instead of pulseaudio. I tried playing with it in different ways, but nothing changes
I tried entering the following in the terminal to see the list of available devices:
 aplay -l
** List of PLAYBACK Hardware Devices ****
card 0: HDMI [HDA Intel HDMI], device 3: HDMI 0 [HDMI 0]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 0: HDMI [HDA Intel HDMI], device 7: HDMI 1 [HDMI 1]
  Subdevices: 1/1
card 0: HDMI [HDA Intel HDMI], device 8: HDMI 2 [HDMI 2]
  Subdevices: 1/1
card 1: PCH [HDA Intel PCH], device 0: ALC3223 Analog [ALC3223 Analog]
  Subdevices: 1/1
I am using laptop inspition7537
It has the following audio controllers:
Haswell-ULT HD Audio Controller and 8 Series HD Audio Controller
If I understood correctly, the problem is the lack of some drivers, but I don’t even know where to get them (I couldn’t find anything on the Intel website)
#2 2023-10-31 10:58:03
yemuyin
#3 2023-10-31 11:07:48
Re: no sound on gnuinos
The "problem" is that the machine has 2 cards and the ALSA default setup uses card 0 for playback.
The remedy is to change that to use card 1.
One way to do that (when there is a single user involved) is to make a file ~/.asoundrc that contains such reassignments, e.g.:
pcm.!default card 1
ctl.!default card 1
Note that the file allows comments as lines starting with '#'.
Read more about it at https://www.alsa-project.org/wiki/Asoundrc
EDIT: "pcm" refers to the audio channels (playback and recording) whereas "ctl" refers to "control knobs". ALSA is hugely configurable with an overly flexible configuration language and I believe anyone trying to delve into it very quickly enters into a state of deep confusion. Unfortunately.
#4 2023-10-31 13:28:55
Charon795
I created a file in /home/*** and pasted the following command into it then renamed the file to .asoundrc.
 pcm.!default card 1
ctl.!default card 1
Then I restarted the computer, but there was still no sound, so now amixer-gtk does not work.
I tried to write a command from the site
https://www.alsa-project.org/wiki/Asoundrc.
 pcm. !default {
    type hw
    card "Haswell-ULT HD Audio Controller"
ctl. !default {
    type hw
    card "8 Series HD Audio Controller"
no result either.
#5 2023-10-31 13:34:01
Charon795
ps: the issue has not been resolved, how to remove the mark
#6 2023-10-31 15:11:20
@Charin795 . . . done. You could probably have edited the post yourself . . .
#7 2023-10-31 20:33:42
I was wrong and too sloppy to actually test my suggestion.
It should really say
defaults.pcm.card 1
defaults.ctl.card 1
There is the tool qasconfig that presents the raw current ALSA configuration. I find it somewhat useful on occation (even if I don't fully understand it), but it in particular tells the configuration effect  of changes to ~/.asoundrc.
EDIT: corrected to say qasconfig as it should have been.
#8 2023-10-31 20:55:22
When amixer-gtk is launched without arguments, i.e. without specifying the audio device, it'll try to auto-detect the one capable for playback streaming via snd_pcm_open (...) that creates a handle and opens a connection to the audio interface. The selected card is printed in the command output together with the mixer controls. However, you can also specify the card in the command line if you wish. For example:
$ amixer-gtk --card 0 --systray
Simple mixer control 'Master',0
Simple mixer control 'Headphone',0
Simple mixer control 'Speaker',0
Simple mixer control 'Speaker+LO',0
Simple mixer control 'PCM',0
Simple mixer control 'Front Mic',0
Simple mixer control 'Front Mic Boost',0
Simple mixer control 'Line Out',0
Simple mixer control 'Beep',0
Simple mixer control 'Capture',0
Simple mixer control 'Auto-Mute Mode',0
Simple mixer control 'Loopback Mixing',0
Simple mixer control 'Rear Mic',0
Simple mixer control 'Rear Mic Boost',0
  Capabilities: pvolume pvolume-joined pswitch pswitch-joined
  Playback channels: Mono
  Limits: Playback 0 - 87
  Mono: Playback 0 [0%] [-65.25dB] [off]
  Capabilities: pvolume pswitch
  Playback channels: Front Left - Front Right
  Mono:
  Front Left: Playback 87 [100%] [0.00dB] [on]
  Front Right: Playback 87 [100%] [0.00dB] [on]
  Capabilities: pswitch
  Mono:
  Front Left: Playback [on]
  Front Right: Playback [on]
  Mono:
  Limits: Playback 0 - 255
  Mono:
  Front Left: Playback 255 [100%] [0.00dB]
  Front Right: Playback 255 [100%] [0.00dB]
  Limits: Playback 0 - 31
  Mono:
  Front Left: Playback 0 [0%] [-34.50dB] [off]
  Front Right: Playback 0 [0%] [-34.50dB] [off]
  Capabilities: volume
  Capture channels: Front Left - Front Right
  Limits: 0 - 3
  Front Left: 0 [0%] [0.00dB]
  Front Right: 0 [0%] [0.00dB]
  Mono:
  Mono:
  Capabilities: cvolume cswitch
  Limits: Capture 0 - 31
  Front Left: Capture 0 [0%] [-16.50dB] [off]
  Front Right: Capture 0 [0%] [-16.50dB] [off]
  Capabilities: enum
  Items: 'Disabled' 'Speaker Only' 'Line Out+Speaker'
  Item0: 'Line Out+Speaker'
  Capabilities: enum
  Items: 'Disabled' 'Enabled'
  Item0: 'Disabled'
  Mono:
  Limits: 0 - 3
Device: hw:0
'Master',0
'Headphone',0
'Speaker',0
'Speaker+LO',0
'PCM',0
'Front Mic',0
'Front Mic Boost',0
'Line Out',0
'Beep',0
'Capture',0
'Auto-Mute Mode',0
'Loopback Mixing',0
'Rear Mic',0
'Rear Mic Boost',0
#9 2023-11-01 07:04:18
Maybe I'm wrong, but in my opinion it's not a matter of settings.
The desktop with Audigy2 under Chimaera worked with alsa out of the box, but after updating to Daedalus it stopped.
And this is a netbook with Daedalus
root@AA:/etc# cat /proc/asound/cards
 0 [Generic        ]: HDA-Intel - HD-Audio Generic
                      HD-Audio Generic at 0xf0244000 irq 27
 1 [SB             ]: HDA-Intel - HDA ATI SB
                      HDA ATI SB at 0xf0240000 irq 16
uly_e@AA:~$ cat /etc/asound.conf
defaults.pcm.card 1
defaults.ctl.card 1
@AA:~$ aplay -D hw:1,0 Noise.wav
Playing WAVE 'Noise.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Mono
aplay: set_params:1358: Channels count non available
uly_e@AA:~$ cat ./.alsactl.conf
# ALSA library configuration file for alsactl tool
# (/usr/share/alsa tree is not necessary for alsactl)
ctl.hw {
        @args [ CARD ]
        @args.CARD {
                type string
                default "1"
        type hw
        card $CARD
uly_e@AA:~$ cat ./.asoundrc
pcm.!default {
  type hw
  card 1
ctl.!default {
   type hw
  card 1
#10 2023-11-01 08:08:26
You'd probably be better off playing on "plughw" rather than "hw" as it includes audio format translations.
But, when the card selection is done, the next is to look at the amixer settings.
#11 2023-11-01 09:09:41
ralph.ronnquist wrote:
You'd probably be better off playing on "plughw" rather than "hw" as it includes audio format translations...
Thank you very much, you are right!
I take my words back.
"plughw" works, after this command the sound from alsa started working.
#12 2023-11-01 10:15:01
Does amixer-gtk work with plughw, or are you using qasmixer instead? The ALSA amixer command doesn't work in my computer with this device:
$ amixer -D plughw
ALSA lib control.c:1528:(snd_ctl_open_noupdate) Invalid CTL plughw
amixer: Mixer attach plughw error: No such file or directory
#13 2023-11-01 11:10:37
I guess you mistakenly copied his ".asoundrc" and replaced "hw" with "plughw"... that's not what to do.
Rather you should use my (last) suggested ".asoundrc" to make sure the right card is selected for audio output. Then use "aplay -D plughw ..." for playing, because that PCM has audio format translations to map any input format into the format "hw" needs. ("plughw" channels audio to/from "hw" as its slave PCM)
EDIT: I'm not good at guessing and confused myself about "amixer" vs "aplay". There is no "plughw" CTL, and one would rather use amixer with the "hw" CTL. I.e., playback to "plughw" with mixer controls for "hw"
#14 2023-11-01 12:56:47
$ amixer -D plughw
I use TDE DE, so there is kmix. We have our own arts sound server.
Just ran the command
aplay -D plughw:1,0 Noise.wav
And everything worked.
Before that, I added the /etc/asound.conf file and edited the files in my home directory. Their content is in the post above.
Edit. Essentially kmix-GUI amixer if arts works through alsa.
Edit. Using the same method, I returned sound without pulseaudio on my desktop with Audigy2.
#15 2023-11-02 00:13:26
Just for the wider audience: it' not a good idea to redefine the "hw" PCM. (If it works for you then you should keep it)
The most common way to set the default card is by an ~/.asoundrc or ~/.config/alsa/asoundrc with content
defaults.pcm.card 1
defaults.ctl.card 1
Of course, that applies for that user only. A system-wide setting would be to add the same in /etc/asound.conf (or any of the other places that ALSA configuration loader looks in).
#16 2023-11-03 15:53:02
This is what worked for me when I ran my pure ALSA system, .asoundrc:
pcm.!default {
        type hw
        card 1
ctl.!default {
        type hw
        card 1
#17 2023-11-03 16:43:38
I'm not an alsa guru, just my understanding of the situation.
In the file /usr/share/alsa/alsa.conf there are lines
  defaults.ctl.card 0
defaults.pcm.card 0
defaults.pcm.device 0
  Therefore, if there is only one sound card, then the /etc/asound.conf file is not needed to select it.
The sound on my desktop with one card works without this file.
The netbook has two audio devices - HDMI and the actual sound card. Hdmi is defined as the first device, so to output sound to a speaker or headphones you need this same selection file /etc/asound.conf.
Here we can add that due to the flexibility of alsa settings in different wiki there are different tips, including placing the contents of the selection file (/etc/asound.conf) in the home directory under the name /.asoundrc.
This will work if all other settings in  /usr/share/alsa/alsa.conf   are are suitable for the specific case.
#18 2024-12-30 08:02:24
This is an Intel Corporation audio device. What is the output of the lspci command? In my computer:
# lspci -knn | grep -iA2 audio
00:1b.0 Audio device [0403]: Intel Corporation C600/X79 series chipset High Definition Audio Controller [8086:1d20] (rev 05)
	DeviceName:  Onboard Audio
	Subsystem: Dell C600/X79 series chipset High Definition Audio Controller [1028:0496]
	Kernel driver in use: snd_hda_intel
	Kernel modules: snd_hda_intel
03:00.1 Audio device [0403]: NVIDIA Corporation GF110 High Definition Audio Controller [10de:0e09] (rev a1)
	Subsystem: NVIDIA Corporation GF110 High Definition Audio Controller [10de:0780]
Do you have the same kernel driver in use? If so, try creating a file called /etc/modprobe.d/default.conf with this content:
options snd_hda_intel index=1
Then reboot. It worked for me.
#19 2024-12-30 08:10:04
#20 2024-12-30 13:28:49
s1mple
The good old game of random sound card musical chairs wink
