#1 2023-08-27 07:12:16
[SOLVED] Nvidia and Chimaera - driver 535?
Setting up a machine for Steam gaming with Nvidia 1070 card and I can only get 470.x driver. What's the best way to get Nvidia 535.x driver on Chimaera? I don't do Wayland and I'm not ready to upgrade to Daedalus (I think).
This is my third active Devuan machine, so terminal is not any problem.
#2 2023-08-27 16:23:17
Re: [SOLVED] Nvidia and Chimaera - driver 535?
Solved by upgrading to Daedalus. Surprisingly smooth and easy!
Thanks all Devuan guys and gals!
#3 2023-09-10 02:04:44
recklessswing
Nvidia 535 too much problems yet. Even for windows. Too much problems on latest games. Better go for 525 for a while.
#4 2023-09-10 18:49:56
brocashelm
For best results, you are better off just using AMD or Intel GPUs.
#5 2023-09-10 19:28:09
Good that you got it solved. However an note . . .
If "Chimaera" was any part of the setup and you typed "Chimeara" as you did in your initial post, perhaps that was partly at fault?
I am going to edit that post to prevent further confusion . . .
