#1 2023-04-26 08:43:32
brday
Add repositoy to daedalus?
Good morning
To add the non-free repository in the daedalus test system, how do I proceed?
Edit:
In this way I tried to add, but it gave me error:
En /sources.list
deb http://deb.devuan.org/merged daedalus main non-free contrib non-free-firmware
Typographical correction in the manual copy of the terminal output.
# apt-get update
E: The <<http://deb.devuan.org/merged daedalus Release>> file does not have a Publication file.
N:  It cannot be updated from such a repository in a secure way and is therefore disabled by default.
Now the default repositories are commented out like this:
# deb http://deb.devuan.org/merged daedalus-security main contrib non-free
# deb-src http://deb.devuan.org/merged daedalus-security main contrib non-free
The only repositories that work on the daedalus  test system are these, but it is insufficient!
deb-src http://deb.devuan.org/merged daedalus main
#2 2023-04-26 11:19:15
alexkemp
Re: Add repositoy to daedalus?
For those that realise that daedalus is *not* dead, do not copy brday's code.
The Devuan package information is here, and the sole Default configuration shown for daedalus is as follows on that page:
@brday:
If your code was copied from the terminal then you likely have a reason (speling), otherwise non-free & contrib are not available for deadalus, though they may be for daedalus.
#3 2023-04-26 11:24:45
daedalus does have contrib non-free and non-free-firmware but it does not yet have daedalus-security or daedalus-updates. Those will come when daedalus is released.
#4 2023-04-26 11:39:45
brday
alexkemp wrote:
@brday:
I said that the repository this does work although it is insufficient:
But the non-free repository does not work, let's be clear.
#5 2023-04-26 14:30:16
alexkemp
Well, now that you have edited it, it reads "daedalus" although when first posted it read "deadalus".
I was attempting to both be light-hearted in my response, and also warning other folks not to blindly copy your [ code ]'ed config since it contained a spelling mistake. Also, I personally only ever 'code' actual results without editing them so that others can trust that what I code is actually what I got as a result.
You need to address your remarks on the absence of non-free to fsmithred, since he states that yes, that does work whereas security & updates will not. I have no personal experience to be able to comment.
#6 2023-04-26 15:31:13
boughtonp
The error refers to a "Publication" file, which I've never heard of, and neither have any search results.
The text "It cannot be updated from such a repository in a secure way and is therefore disabled by default." also differs from the standard wording.
Are you translating this text? Don't do that. Instead prefix the command with LANGUAGE=en to have Apt output in the specified language (English), and then provide the exact verbatim command and output.
If you haven't yet got a terminal that allows you to copy text, you can do, e.g:
LANGUAGE=en apt-get update |& tee ~/output_of_apt_update.txt
Anyway, it looks like there might be an issue with Devuan here - not for non-free, but for non-free-firmware:
curl -isS http://deb.devuan.org/merged/dists/daedalus/Release | grep Release
There are no "Release" files under "non-free-firmware" directories, despite every other section having them...
Edit: Having checked the repository format specification, the "dists/$DIST/$COMP/binary-$ARCH/Release" files are legacy/no longer used (since ~2017), so this is a red herring.
3.1415P265E589T932E846R64338
#7 2023-04-26 16:02:51
I just installed faac from non-free and firmware-iwlwifi from non-free-firmware in daedalus without any errors.
Sometimes you get errors if you hit a mirror just when it's updating, and in those cases, it works again after a few minutes.
And sometimes a mirror is down. If it turns out that your sources.list is correct and you still have problems, you could select a specific mirror from this list: http://pkgmaster.devuan.org/mirror_list.txt
You can check the status of mirrors on this page: https://sledjhamr.org/apt-panopticon/re … t-web.html
#8 2023-04-26 17:28:31
Actually, I think that was me. When there are obvious misspellings of Devuan releases, I will correct them to prevent further confusion. wink
#9 2023-04-26 23:53:09
alexkemp
OK. Thanks to admin (although the OP has been further edited).
#10 2023-04-27 00:57:54
Not by me. The OP probably figured out he could do that himself, at least for a certain time window unknown to me. That doesn't apply to admins though . . .  big_smile
