#1 2023-03-25 14:06:58
ribcage
Devuan doesn't have graphical user management
There was a topic called "Devuan: Existential issues." where a person had legitimate issues but was met with unfriendly responses. I had similar issues back when I tried Devuan and found some solutions, so maybe this will help someone.
I installed devuan_chimaera_4.0.0_amd64_desktop.iso, XFCE desktop environment, which was probably the default, I have no clue about all the different desktop environments.
I was surprised there is no way to change your password or add and remove new users and groups. Anyway, one solution is to install gnome-system-tools which seems to work quite well. After installing, the program will be found in Applications > System > Users and Groups.
So install it from the terminal with the command below or use the Synaptic package manager.
sudo apt-get install gnome-system-tools
The "Users and Groups" program has a setting called "Don't ask for password on login" but it's not functional. To make it work, go to Manage Groups and add a group called "nopasswdlogin". Then, in /etc/pam.d/slim, add the following line above @include common-auth:
auth sufficient pam_succeed_if.so user ingroup nopasswdlogin
The package gnome-system-tools is inside the .iso, so you can install it from there, but I had issues with package managers accepting the .iso as a source for packages. Anyway, what I did is modify /etc/apt/sources.list like this:
deb [ allow-insecure=yes ] file:/some/path/devuan_iso chimaera contrib main non-free
The entire path (/some/path/devuan_iso) needs to have no spaces in it. From the .iso, I copied the folder "Devuan 4.01" into the folder devuan_iso, or maybe I copied the contents of "Devuan 4.01" into it, forgot which it is.
#2 2023-03-25 16:09:50
boughtonp
Re: Devuan doesn't have graphical user management
It looks like they raised legitimate issues in XFCE, but blamed Devuan for those issues, and had a generally poor attitude.
You should report this at https://bugzilla.xfce.org
The place to report this one would be https://github.com/LStranger/gnome-system-tools
Did you try mounting it first?
mount -o loop,ro -t iso9660 '/some/path/devuan_chimaera_4.0.0_amd64_desktop.iso' /media/cdrom
After that, you probably just need to uncomment the existing "cdrom" entry in sources.list (or add one if it doesn't exist), including the allow-insecure option, something like:
deb [ allow-insecure=yes ] cdrom:[Devuan GNU/Linux 4.0 chimaera amd64 - desktop 20211012]/ chimaera main
No need to extract files from the ISO or worry about filenames (usual shell quoting rules apply for the mount command).
3.1415P265E589T932E846R64338
#3 2023-03-25 16:23:54
boughtonp wrote:
... raised legitimate issues in XFCE, but blamed Devuan for those issues, and had a generally poor attitude.
Just to add: I have experienced exactly that type of thing when reporting issues related to windows crashing in XFCE.
As a result, I decided to be rid of XFCE as soon as I can get together my Chimaera/Openbox act.
#4 2023-03-25 18:00:05
Most people just use the command line, as we always have, the programs are there already. wink
#5 2023-03-25 18:18:21
thierrybo
Also as far as I know Devuan goal is not to be a real distribution of its own and provide custom solutions to common problems. It is just Debian without systemd, they will not add "goodies" to be a full featured distribution, it is just plain Debian. I believe this is what many old Debian users are awaiting from this distribution, but it may surprise newcomers that are not fully aware of that.
#6 2023-03-25 20:14:03
thierrybo wrote:
... just Debian without systemd ...
... what many old Debian users are awaiting ...
No small feat by any means, an endless task.
Devuan survives today thanks to a small but very dedicated cast of knowlegeable individuals who devote their time and effort to keep it running.
Unfortunately, as systemd and other assorted crap (eg.: zeigeist) advance and dig their tentacles into the workings of Debian, that task becomes more and more difficult.
That is what newcomers are not fully aware of.
#7 2023-03-25 21:12:11
@ribcage . . . Thank you for sharing your solutions and reminding me that I should install gnome-system-tools. Haven't had a need but good to have it there if/when the need arises . . . smile
